Question about Singer Commander 18-5 Dishwasher
Insinger 18-5 will not leave the fill cycle and go into the wash cycle
2 Suggested Answers
sodeep
  • 3267 Answers
SOURCE: I recently purchased a insinger
Follow the steps below to ensure proper dishwasher detergent selection and usage.
Use only powder, liquid or tablet detergent designed specifically for automatic dishwashers. Any other types may cause a sudsing and as a result, poor wash performance and possibly suds and water on your kitchen floor. GE recommends either Electrasol®, Cascade® or Cascade Complete® detergents.
Use the right amount of detergent for the job. Soft hot water requires less detergent - perhaps a quarter of a cup in the main cup. Very hard water requires a full main cup and a full open cup to get good wash performance. Conditions between these require judgment. Use enough to get the job done, but don't use more than you need.
Too much detergent in very soft water will cause etching of glassware. This is a permanent clouding of the glass. If you experience this condition, use less detergent.
Keep your detergent fresh and dry. Store the detergent in container away from moisture to prevent lumps. Do not put detergent in the cup until you are ready to run a cycle. If powder detergent gets old or lumpy, throw it out; it will not clean effectively. Liquid detergents do not age.
As a rule of thumb:
Harder water requires more detergent
Cooler water requires more detergent
Softer water requires less detergent
Hotter water requires less detergent
Posted on Jun 15, 2011
My Indesit washer model no IWC61651 ECO fills with water but does not do the wash cycle will run for hrs keep filling water but programme never moving
Lynne,
The drain hose for the washing machine is pushed too far down the standpipe causing the water to siphon out of the machine. Look at the diagram below:
-make sure standpipe is at least 18-30inches high
-only push drain hose in 4-6inches
Aug 16, 2016 | Indesit Washing Machines
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
I recently purchased a insinger 18-5 dishwasher, what type of detergents should I use ??
As a rule of thumb:
Jun 15, 2011 | Singer Commander 18-5 Dishwasher
Machine starts to fill then stops and beeps
try it on rinse cycle if goes ok then the hot water valve is faulty
Dec 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
Insinger commercial dishwasher ...water keeps overflowing when unit is off. cannot find a repair manual for GS 14
Most likely a leaking fill valve...the seat may be worn out or there may be some debris in it causing it to not fully close.
Perhaps Insinger offers a valve rebuild kit. parts@insingermachine.com
Sep 17, 2009 | Dishwashers
After it fills and starts to wash my dishwasher
Reseat the little rubber gasket along the door. Pull it out a little bit
Aug 16, 2009 | Whirlpool DU930PWS Built-in Dishwasher
Washer won't start to cycle after initial filling
Did you check if lid switch is closing? You'll need a meter to do it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Washing Machines
Washer fills, but won't start wash cycle....makes buzzing sound
Try replacing the timer switch..I had the same problem on my Simpson 175..
Dec 26, 2007 | Washing Machines
Front load washing machine
There's usually a little drain hole tucked away out of sight at the lowest point of the gusset between the inner and outer seals. Before you try anything else, suggest you check this hasn't got blocked with wet lint (the place I'm trying to describe is the bit that's filling up with manky water). A.
Mar 28, 2007 | Frigidaire GLTF2940ES Front Load Washer
Singer Commander 18-5 Dishwasher Logo
26 people viewed this question
Top Singer Dishwashers Experts
Owen Barnes
Are you a Singer Dishwasher Expert? Answer questions, earn points and help others
