Does the Onn Cd Boombox with Cassette Player have a repeat function to keep my cd's playing? I don't see any buttons and I can't find anything in the manual. I find it odd that a cd player would not have this function, is there something I'm not seeing? Any help would be greatly appreciated.
  • ladebug62 Apr 22, 2014
    Somehow this got put in the "router" category. All this is is a cd boombox from Walmart. Thanks
fairlane
  • 50 Answers
SOURCE: CD PLayer won't play CD's
Hi First of all, you must find all the screws for the top cover and remove it. Make sure the unit is not plugged in! Then, making sure that you are not touching anything inside the unit, plug it back in,put a Cd in the drawer, and watch what happens. If the drawer closes, but you can still hear a motor running, then it is a belt drive unit, and the belt is slipping, if that part is ok, listen carefully for a ticking noise, which is the laser lense going up and down trying to focus on the CD, if the disk starts to spin then the mech has closed properly, and the unit is trying to find the directory. If the unit then spins the disk for a while then ejects it, then the laser is dirty or faulty. I would suggest getting it cleaned at a shop if the lense appears dirty. ***Never look straight down at the laser lense if it is exposed on your model of CD player, it is a class 3 laser, and you will be doing some harmful home laser surgery to yourself!!!*** Hope this helps! Good Luck! P.S. When following the steps above, if you hear the ticking of the lense moving up and down, but the disk does not spin, gently spin it clockwise with your finger, if it starts to play, or finds the directory, then the spin motor is bad.
Posted on Aug 16, 2006
fairlane
  • 50 Answers
SOURCE: Boombox CD player
Hi Could be bad spin motor, but the first thing to try is load the cd and put your ear to the unit and listen for a ticking sound...if there is, then the laser is trying to focus. If not ticking, there is likely a serious problem, and the whole unit should be replaced. If you hear the lense bouncing up and down, then it is likely a dirty lense or bad laser. To clean it, use a cotton swab and wet the end with at least 70% USP rubbing alchohol(99% better). Touch the swab to the lense and a drop should form on the lense, gently move the drop around to loosen any debris, and then use a dry swab and touch it to the lense to absorb the drop. Try the unit, and if it was dirt on the lense, it should work, if not the boombox should probably be replaced. Good Luck!
Posted on Sep 27, 2007
SOURCE: cd player not playing some cds: denon cd player ucd-77
It's not the cds that are the problem as they work in other cd players. Its seems to be the denon cd player itself that doesn't seem to be reading the cds.
Binap
Posted on Jan 31, 2008
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
  • 99 Answers
SOURCE: NAD C541i CD Player plays but...
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Posted on Feb 02, 2009
Why does my cd player on my Radio/Cassette/CD boombox keeps reading ncd on all my CD's even on my disk cleaner cd?
The laser assembly is not reading the disc, as the laser ages it becomes weaker until it can no longer scan the disc and can not play, you have done everything that I would have recommended, at this stage it is far cheaper to replace the boombox than replace the laser pickup assembly.
Mar 28, 2012 | RCA RCD147 CD Boombox
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
I can't get any volume from the boombox. It's like the volume is muted for all functions. Any suggestions?
Please make sure that you have selected the correct function.Press the Function/Standby button to select Radio,Tape or CD mode in the boombox.Press the volume +/- buttons to increase or decrease the volume on your RCA RCD135 Cassette/CD Boombox. Also check the display and make sure that the volume level is adjusting when pressing the buttons.
Hope you are satisfied with my solution.Thanks for choosing Fixya.
Jul 03, 2011 | RCA RCD135 Cassette/CD Boombox
Cassette player doesnt play or record, ff or rewind. CD player, AM/FM radio works fine.
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Jan 14, 2011 | Memorex MP3227 Radio/Cassette/CD Boombox
I'm a dodo, don't know how to use a CD player. Uhg.
maybe there is a switch in the which you can set whether you want to use radio, cassette, or cd
May 05, 2010 | Sony CD Radio Cassette Boombox, CFD-E90...
How do you start a tape to play ok..i turn on...put in a tape....now, how do i get it to play
Look for a symbol that looks like this >I. or just this>, and push. Make sure you have selected "tape" function
Apr 10, 2010 | Sony Boom Box With CD Player & Cassette...
How to record a cassette from cd on a sony xplod boombox cfd-g505
Insert a tape.
Select the program source you want to listen/record (CD).
Insert a cd, press stop.
Press record on the tape player.
Press play on the CD player.
The volume control or any audio emphasis buttons will not affect the record level.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CFDG505
Mar 17, 2010 | Sony CFDG505BLACK Xplod CD Radio Cassette...
Play mode
Tape the play button down (better if you have a repeat button) I have done this and used a marble under the tape to simulate a thumb-like pressure imitation
Apr 11, 2008 | Sony CFD-S200 Cassette/CD Boombox
99 people viewed this question
 Grubhead
Grubhead
