Ls-180 x factor karaoke mic
Works through iPod touch on all tv's in house except logik tv /DVD . Have connected red white and yellow connectors directly to tv , nothing. Tried connecting these points r t-shirt to scart connection , still nothing. Have tried through DVD, atv, and dtv , cannot hear iPod or voice through mic or tv.
    Problem Solver:
  • 13 Answers
A lot of newer tv you'll have to change the input of the tv to receive the signal. Most should be labeled. If it's red and yellow connectors it will be a composite connection. Some tv companies require a signal to be present before they will switch or even show the different inputs
Posted on Apr 22, 2014
shaggyrat
  • 1224 Answers
SOURCE: yamaha dsp-a1
you need to set the ntsf or pal settings for hdtv and s-video is video1 video 2 or video 3 seting on input on remote
Posted on May 13, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
lynchms
  • 93 Answers
SOURCE: Connecting tv/to a receiver and a dvd
First are they two seperate units, ie. a TV and a DVD unit, if so you are connecting the dvd to the TV and the TV audio to the receiver, anyway the yellow connector is composite video, you can run this from your tv to the reciever video INPUTS, the RED and WHITE connectors are for AUDIO ONLY, hence WHITE LEFT CHANNEL and RED RIGHT CHANNEL, what to keep in mind is AUDIO OUT OF TV into AUDIO IN on the receiver, same on a DVD unit AUDIO OUT of the DVD unit into an AUDIO INPUT on the receiver, but take the DVD VIDEO OUT to the TV VIDEO INPUT, other routes are possible but just keep the in and out in mind when connecting.
Posted on Feb 02, 2009
SOURCE: Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Posted on May 08, 2009
mlapres
  • 757 Answers
SOURCE: Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Posted on Dec 23, 2009
Testimonial: "You where right on the money, I did what you said and it worked. You are the man!"
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
How to connect enter tech model ls 3700T karaoke to tv
connect the RCA-cable to the TV one by one;
yellow (video),
white and red (audio).
Change the TV mode to "AV" or "Video" after
the magic sing is turned on.
Oct 03, 2012 | EnterTech Enter Tech Magic Sing Mic...
I bought a quantum fx adapter for my iPod how do I connect it to my TV
Hi.
Its really easy just plug the color connectors(red,white,yellow) where you plug the connectors of your DVD.
Aug 28, 2011 | Quantum Televison & Video
UNABLE TO CONNECT IPOD TO TV
You need a converter for this one end is a headphone jack the other to plug in to your tv...you only having a red and white cord already covers you sound and video
Sep 15, 2009 | Apple iPod touch
I simply don't understand how to hook up the DVD
OK simple mind maybe this will help. Cable bos to DVD and DVD to TV. A set of red and white cables are for hearing (audio) ( red is general right and white is left) the holes that you plug them into should also be color coded the only real trick is that they are flowing in the correct direction. They should go out from the cable box in to the DVD and then a set should go out from the DVD and into the TV. The Yellow is for video on some units. Not all units need the yellow. Since it is cable there should be a cable connection from the wall to the cable and the only place that might need the yellow is from the DVD to the TV depending on your model of TV. Mine for example, uses an HDMI cable instead of the yellow plug ins. Hope this helps!!
Jun 15, 2009 | Supersonic SDAT SC-25 DVD/Karaoke Player
I'm trying to connect my denon dvd player to tv
The yellow plug is composite video; the red and white are analog audio. Not knowing specifics about your TV or Denon model number, I would suggest:
-- the red and white connectors go to the audio in on the DVD, and to the audio out on the TV. There will be a left channel and a right channel. Make sure you connect the same color plug on the same channel. In other words, if you put the red plug in the right audio out on the TV, also put the red plug in the right audio in on the DVD, the white in the left audio out on the TV and in on the audio in on the DVD.
-- the yellow connector will go on the video out on the TV, video in on the DVD.
For better audio, consider using gold connectors, if you don't already have same.
Alternatively, you may wish to purchase and use an S-video connector if your equipment allows. This would replace the yellow composite video cable, and enhances your image.
Hope this helps!
May 22, 2009 | Philips Magnavox DVD/VCR Dual Player
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
How to connect Apple iPOD to Sony Bravia LCD
http://www.applesource.com.au/ipod/soa/Play-back-iPod-videos-on-your-TV/0,2000070791,339287576,00.htm
Connect your iPod to your TV with a DIY cable
The iPod A/V Cable is stylish and handy, but you may feel it's not worth the money; the Belkin cable gives you twice the value per foot but costs the same overall. For a less expensive alternative, find a standard A/V cable with three RCA plugs at one end (coded red, white, and yellow) and a 1/8-inch A/V plug with three bands at the other end.
To set up your iPod for playback, plug the 1/8-inch connector into your iPod's headphone port, and then plug the yellow, white, and red RCA connectors into the RCA jacks on your TV in this non-color-coded way:
Jan 19, 2009 | Durabrand DU1301 TV
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Set-up wireless karaoke Mic.
I can't seem to find any technical details on the output specifications of the karaoke mic, but IF it outputs in consumer standard RCA format (a cable with two ends, one red and one white - often seen with a third yellow cable for video), then you should be able to plug it into the back of the receiver without trouble. Simply choose one of the audio connectors in the back to function as your microphone playback system - I suggest the DBS connector, unless you have a satellite system already plugged in.
Connect the Red RCA cable to the RIGHT channel port on your receiver and the White RCA cable to the LEFT channel (Red = Right). Now, select the DBS (or whatever port you plugged it into) using your receiver remote control. Hit the "ANALOG/DIGITAL" button on the remote until "ANALOG" mode is displayed.
If you want to connect the mics to a Karaoke system using the same receiver, simply unplug the White RCA cable from the Microphones, and plug in the White RCA cable from your karaoke device. Now, you'll get music playing from one side of the speakers, and mic playback from the other side, simulating the karaoke experience.
NOTE: If the microphones do not have a RCA plug on the back, please post a picture of the reverse of the Microphone receiver, and I will see what I can do to help you further.
Dec 28, 2007 | Trident JT-306A Microphone
57 people viewed this question
 Grubhead
Grubhead
