Question about Urban Trend Waterfall Wine Chiller 10-275
Not powering up
The DC Converter is ok, but it doesn't power up
Can Huawei AC to DC Power converter ETP48100-B1-50A model support battery?
Yes, ETP48100-B1-50A is the latest Huawei AC to DC power converter, but it doesn't has battery slots, only Huawei EPS30-4815AF-15A and Huawei EPS30-4815AF-30A can support this function.
More products:
Huawei EPS75-4815AF-45A
Huawei OLT
May 24, 2017 | Huawei Computers & Internet
How to find problem on vl470m will not power up
Unless you have an ESR meter and can check all the capacitors in the PSU for ESR, your voltage readings are not valid.
Apr 07, 2017 | Power Up Computers & Internet
It does not seem to be charging the batteries. 12 volt lights work good for about 2 days then go dim until I put a charger on the batteries and bring them back into working order. The battery connect...
The Parallax 7155 converter should not require battery support for any 12 volt load amperage that is less than the maximum amperage capacity of the converter. A standard RV incandescent 12 volt lamp draws about 1.5 amperes for each bulb. With the battery disconnected and other 12 volt loads off, turn on lamps (not fixtures) and calculate the number of bulbs which can be turned on. If you run out of lamps, turn on vent fans etc. The idea here is to try to get to 55 amperes of DC load if possible without going over 55 amperes. At a sustained DC load of about 25-30 amperes or higher, the fans should cycle on continuously after about 5 -10 minutes. Lamp brightness should be normal and the measured voltage from the converter should be above 13 volts if under 55 amps of DC load. If the voltage drops with only a few lamps on, a converter issue would be likely.
Diagnostic tests an RV technician should make would be to:
1. Disconnect the battery system.
2. With the converter system powered on, measure the DC amperage with a DC ammeter capable of reading at least 60 amperes DC from the blue lead at the DC fuse panel terminal VCC.
3. Measure the DC voltage at terminal VCC and DC ground.
4. Record both readings.
At any DC load amperage less than 55 amps, the voltage should be above 13.0-13.2 volts DC. This method should take out all guesswork and confirm a DC converter section issue or not.
Nov 04, 2013 | Parallax Power Supply Parallax 7100 Series...
Bought new power supply still power light won't light up and laptop will not turn on new battery as well it worked until new battery power was drained when i try to power it on the battery light...
Look to see if the charge light is on when you connect the power.
If not, try moving the power jack around slowly in a circle.
If you get power with the cord/connector at certain angles, then the motherboard will need to be removed in most cases and the power connector on the motherboard will need to be resoldered to the board, and then the unit will have to be reassembled.
If moving the connector doesn't ever put the charge light on, then there is either a picofuse blown or more likely some SMT MOSFETS are blown.
If you have the skills, identify and replace the MOSFETS and you should be ok.
If a picofuse is blown, replace it with the same type and rating fuse.
DO NOT JUMPER the fuse...sometimes they just go, but most often they go for a reason.
If the new fuse blows, start looking to the MOSFETs and electrolytic capacitors in the DC/DC converter section.
Jul 19, 2011 | Computers & Internet
Will not power on at all. When plugged in theres a
What model? If it is under warranty, return it to Acer.
Mar 14, 2010 | Acer Aspire 5315 Notebook
Powering car stereo using AC to DC power converter
your power supply may not have enough power to run the radio.
Mar 31, 2009 | Car Audio & Video
DC-DC converter problem
You need to get the converter changed. But before you change, try a different power source
Sep 09, 2008 | Gateway MT3705 Notebook
Wont turn on
Make sure you dc to dc converter is ok and installed or your unit will be dead in the water ...
Apr 01, 2008 | Alpine IVA-D300 Car DVD Player
Urban Trend Waterfall Wine Chiller 10-275 Logo
59 people viewed this question
Top Urban Trend Computers & Internet Experts
David Payne
David Payne
Are you an Urban Trend Computer and Internet Expert? Answer questions, earn points and help others
