Question about Dometic Refrigerators
My refrigerator keeps ticking
My dometic rm6271[7]refrigerator the ignition process is activated automatically accompanied by a ticking sound the indicator lamp will flash upon successful ignition the sound and the flashing will stop but my ticking and indicator light keep going
  • 884 Answers
Blow through the jet and heater gauze to make sure the flame is reaching the end of the thermocouple. If the flame is going out all the time suspect the thermocouple is at fault
Posted on Apr 30, 2014
Dometic rm2652 re-ignitor
Dear sir/madam,
Turn the refrigerator off and remove the wire
between the electrode and igniter. Now turn the
refrigerator to the gas mode. If no internal
clicking sound is heard the igniter is defective.
It is important to remove the high voltage wire
that goes to the electrode from the igniter when
you are checking the igniter for operation. The
high voltage wire and the electrode can be
shorted to ground causing the igniter reigniter
to think that the flame is lit, resulting in no
spark on gas operation.
thanks
good luck
Sep 14, 2008 | Dometic RM2652 Refrigerator
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Dometic RM2652 keeps shutting dowm while running on the electric side
It sounds like you have a bad circuit board. You will need to take it to an authorized repair center and have them test the board.
Dec 08, 2013 | Dometic Refrigerators
Does the 2652 constantly burn LPG when in gas mode. For some reason (probably told so erroneously?) I was under the impression that the fridge automatically switches off and on the LPG flow/ignited as it...
The RM2652 should shut down when the fridge reaches proper temperature. So yes the flame should go out when operating on propane. If the refrigerator does not get cold enough, then the flame will not ever shut down. It is posible that you may require a replacement cooling unit. WEB SITE: ArctiCold Refrigeration We keep it cold
ONLINE STORE: http://www.rvfridgerepair.com/ 0d79856c-1b32-4d85-a920-5d4fdb51f083.jpg
Aug 03, 2013 | Dometic RM2652 Refrigerator
Dometic s 1621 works on shore power but won't work on lp gas
What exactly happens when switched to propane? Have someone switch to propane while you stand by vent cover outside and listen for sparking when switched. Make sure it's calling for cool, as in maybe leave door open for a few minutes prior to trying. Let me know if you hear any "ticking" sound as if trying to light on propane.
Oct 29, 2011 | Dometic RM2652 Refrigerator
No ignition
Remove cover from igniter (follow thin wire from electrode,back to it) and test for 12 VDC at + terminal on igniter box. If you have 12 volts at + terminal, replace igniter box.
Jun 04, 2010 | Dometic RM2620 Refrigerator
Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
Feb 08, 2010 | Dometic RM2652 Refrigerator
Refrigerators Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
