Question about SWANN Home Security
Playback When I select playback from the menu it says no files available. Everything was fine until a power cut
    Sergeant:
  • 333 Answers
Your hard drive went bad during power outage, you need to replace the DVR hard drive.
Posted on Dec 08, 2014
How do i delete pictures from a samsung ES30 digital camera
To delete pictures, follow these steps:
To delete single file, 1. In playback mode (while viewing you pictures or videos), select a file and press the {Fn} key 2. Select YES to delete the file
To delete Multiple files, 1. In playback mode, press {Fn} 2. Select Multiple Delete. 3. Select the files you want to delete and press {OK} Press {OK} again to cancel your selection 4. Press {Fn} 5. Select YES
To delete all files, 1. In playback mode, press {MENU} 2. Select File Options > Delete> All > Yes
Sep 14, 2011 | Samsung ES30 Digital Camera
Can you please tell me how to delete individual frames without deleting everything. I have had a bad experience and don't want to repeat it. I can't find my manual....Thanks
Video clip cutting (extracting)
Display the video clip from which you wish to extract a segment.
Display the NORMAL Mode
Playback Menu (page 37), select
"EDIT VIDEO, and press the
button.
Select CUT!! and press the SET
button.
The Cutting Screen appears.
Specify the start point of the extract.
Use the procedure below to specify the frame from which the video clip extract will start.
• Play the video clip until approximately the desired point, pause the video clip, then play the video clip one frame at a time, stopping at
start point of the extract. This will be the first frame of the extract.
• If the start point of the video clip is also the start point of the extract, proceed to step 5.
Play:
After pausing playback, press and hold the SET button to the right
about 2 seconds for forward playback, or to the left for reverse playback.
Pause:
During playback, press the SET button.
Accelerated playback:
During playback, toggle the SET button to the left or right to change the playback speed.
Single frame:
After pausing playback, toggle the SET button to the right to move forward one frame, or to the left to move back one frame.
5
Toggle the SET button up.
• The start point of the video clip
extract is set, and the screen
•Specify the end point of the
extract by following the same
procedure as in step 5.
a. Toggle the SET button down.
Each time the SET button
toggled down, the sections
delete and the sections to
save are reversed.
b. Specify the end point of the extract. The frame following
end point of the extract will
the start point of the latter portion to be joined.
6
Press the VIDEO CAMERA button.
A screen appears for you to select either to save the edited video clip as a new (separate) file, or to delete the original video clip and replace it with the edited video clip.
SAVE AS NEW:
The edited video clip will be saved as a new file. The original video clip remains unchanged.
OVERWRITE:
The original video clip will be deleted. Only the edited video clip will be saved.
REVIEW CLIP:
Play back the edited video clip before saving it.
7
Select the desired option, and press the SET button.
• Editing starts.
• When editing ends, you are returned to the NORMAL Mode Playback
Menu.
I think this is what you are after if this isn't what you need you can find the manual at
http://www.retrevo.com/support/Sanyo-VPC-CG9-Camcorders-manual/id/18378dj397/t/2/
Jun 17, 2011 | Sanyo Xacti VPC-CG9 Digital Camera
Can't play back videos on my experna; memory card Sandisk class 4 8Gb. Have a canon Vixia HFR10 camcorder
Okay, ours is a different brand (JVC) but they may have some basic similarities in function. To playback video clips stored on the memory card, put the memory card in the card reader slot of the computer and put the files onto the computer. Playback the clips from your computer video or photo file. (Ours won't playback video stored on the memory card through the camera.)
To playback video clips stored on the camera hard drive through the camera, we open the viewer screen, look at the function keys on the camera body, select the "Play" button. On the screen it displays thumbnails of the various video clips. We use the toggle/function key to select from the menu containing options for playback, edit, delete, protect, etc.
May 16, 2011 | Canon Vixia HFR10 Silver Dual Flash Memory...
How to transfer images from exlim to sd card
Press the Playback button (right-pointing triangle) to bring up the playback screen. Press MENU. Select the PLAY tab, then the "COPY" entry. Full details are in the "Copying Files (Copy)" section of the manual (page 108 in my copy).
Apr 19, 2011 | Casio Exilim EXZ90 121 MP Digital Camera...
How do I clear the memory on the player?
To clear the Memory of the Walkman Player, try formatting it with the Menu items.
The Steps to format the Player is, 1. Press and hold the BACK/HOME button in the pause mode until the Home Menu appears. 2. Press arrow keys to select "SETTINGS" and press the Playback/Pause button to confirm. 3. Press arrow keys to select "COMMON SETTINGS" and press the Playback/Pause button to confirm. 4. Press arrow keys to select "FORMAT" and press the Playback/Pause button to confirm. 5. Press Up/Down arrow keys to select "YES" and press the Playback/Pause button to confirm. "All Data will be deleted" Proceed? message appears on the display. 6. Again, press Up/Down arrow keys to select "YES" and press the Playback/Pause button to confirm. Now, Memory formatted message will be displayed.
I hope you find this information useful. Thanks,
Pradeep
Nov 18, 2010 | Sony Walkman NWZ-S616F MP3 Player
Hi.i have a really important question and im hoping you can help me.everytime i try to review my videos on my camera it says(video management file is broken to record/playback video,recovery is...
Select "OK" to restore. (Videos that cannot be restored will not be displayed on the index screen, but you may be able to play them back using "PLAYBACK MPG FILE" in the menu.
if the file is damaged....
Select the playback mode.Select video mode.Touch to display the menu.Select "PLAYBACK MPG FILE" and touch.Select the desired video and touc.
May 12, 2017 | JVC GZMS230 Camcorder (Black)
When previewing my video in adobe encore, it looks fine but when i burn to dvd, the video jumps everytime the camera moves. What can i do?
This is everything from adobe encores website.
Playback issues in Adobe Encore DVD 2.0 have a variety of symptoms. The following symptoms may occur when you use the preview feature, when you play video in the Monitor panel, when you play to an external device, or when you edit a menu or slide:
-- Video or audio exhibits stuttered playback.
-- Video or audio cut in and out.
-- Audio is out of sync with video.
-- Video displays as black in the monitor panel or after burned to disc.
-- There are general redraw problems in the user interface.
-- Encore DVD returns the error message, "Invalid requested time," when you transcode a file.
Beginning troubleshooting
1. Test the DVD on a variety of players.
Not all DVD players behave the same way. By testing the DVD on a variety of players, both set-top and software, you can determine if the problem is related to the DVD itself or just the player.
2. Make sure that the system meets the requirements for digital video.
Video may not play correctly if your system doesn't meet the following requirements:
-- Intel Pentium 4, 1.4 GHz processor or faster
-- Windows XP Professional or Home Edition with Service Pack 2
-- 512 MB RAM (1 GB or more recommended)
-- Hard disk with at least 16 GB of space for installation and ongoing work (RAID recommended for HDV/HD editing)
-- 1280 x 1024 or greater color monitor resolution, 32-bit display adapter
-- QuickTime 6.5 required to support import and export of QuickTime files
-- Supported DVD burner *
-- Stereo sound card
* For a list of supported DVD burners, visit the Adobe website at www.adobe.com/products/encore/systemreqs.html.
3. Update video display card drivers.
Outdated or flawed video display card drivers may incorrectly display motion video and textures, or incorrectly report their ability to display motion video or textures to Adobe Encore DVD. Contact the video display card manufacturer for the latest display drivers and driver information.
4. Select an appropriate Playback Quality setting.
You can display playback in the Encore DVD Monitor panel at either High quality, Draft quality, or Automatic quality. By default, the Monitor panel displays video at High quality; that is, it displays all the pixels of each frame of video. When Encore DVD plays back unrendered video at High quality, the video may stutter or ****. When you select Draft quality, Encore DVD always displays video at one-half resolution in the Monitor panel. When Draft quality is selected, playback is smooth but the image quality is affected. When you select Automatic quality for the Monitor panel, Encore DVD dynamically adjusts image resolution between High quality and Draft quality to best address the available system resources.
To choose the Monitor panel playback quality, select File > Preferences > General, and then select an appropriate Playback Quality setting.
5. Deselect the Automatic option in Audio/Video preferences.
1. Choose File > Preferences > Audio/Video Out.
2. Under Video Playback, deselect Automatic.
3. In order for the change in preference to take effect, you must close the Monitor panel and then reopen it.
The Automatic option is selected by default, allowing Encore DVD 2.0 to play video in a Standard Direct3D mode. When it is not selected, video plays in GDI mode.
6. Troubleshoot slideshow playback issues.
Many DVD players, both set-top and software, handle playback of slideshows differently. To conserve disc space, Encore DVD creates an MPEG I frame for each slide then assigns a duration for that frame based on the slide's duration. Many players cannot accurately display these and will instead display only a single frame of the image before reverting to a black screen for the duration of the slide.
If you are experiencing playback issues with your slideshow, be sure to play it back using a variety of players. If you determined that slideshow playback is the issue, then you can try the following workarounds to ensure the slideshow will playback correctly on all players:
Note: The following workarounds will increase the amount of space used on the DVD.
Add zooms or pans to each slide.
When you add a zoom or pan effect to a slide, Encore DVD will render the slide as a video file instead of an MPEG I frame with duration.
Create the slideshow in Premiere Pro.
You can import all of your slides into Premiere Pro and create a slideshow there, then export the file as an AVI, import it into your Encore DVD project, and add it to a timeline.
If you create the slideshow in Premiere Pro, users cannot manually advance through the slideshow the same way they can if it was created with the Encore DVD slideshow editor. However, if you add chapter points for each image, then viewers can skip ahead before the timeline automatically reaches the next image.
Create menus from each slide and link them.
By creating menus from each slide and linking them in the desired sequence, users will have complete control over when they can advance to the next image. You can set up invisible buttons with invisible highlights to give the impression that only the image is on screen, or you can include visible navigation elements for the next and previous slide, as well as any option that is available for a traditional menu.
If you create menus for each slide and link them, then you cannot have a continuous soundtrack playing throughout the slideshow. Menus can have audio but they are specific to each menu and will start from the beginning each time you access a new menu.
Intermediate troubleshooting
7. Optimize hard disks.
Optimize hard disks by defragmenting them, updating their drivers, and configuring the disk drives. These procedures improve playback speed and performance in Encore DVD. For further assistance with these tasks, contact the hardware manufacturer or an authorized repair service facility.
-- Defragment hard disks by running the Disk Defragmenter utility included with Windows or a third-party disk utility such as Symantec Norton Utilities. If you use external (non-system) disks for video, you can reformat them instead. Be aware that formatting erases all information on the disk. For instructions, see Windows Help or the documentation for the utility.
-- Update disk drivers to ensure that they aren't damaged or incompatible with the system. If a disk was formatted with a third-party disk utility, you must use the third-party disk utility for this procedure. For instructions, see the documentation that came with the utility.
8. Test digital video playback in a third-party digital video utility.
Play your video clips in an application other than Encore DVD to try to isolate the problem. If playback is problematic in an application other than Encore DVD, the problem is not with Encore DVD; troubleshoot your system or that video file.
9. Optimize Encore DVD.
For information about optimizing Encore DVD, see the Encore DVD User Guide, Online Help, and document, "Optimize performance of Encore DVD (on Windows XP)."
Aug 20, 2009 | Brady CODESOFT 7 Premier (cs7-prem-usb)
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
No Sound
The camcorder may be in what may be called "narration mode." This function mutes the playback audio so you can narrate with you own voice when playing tapes back. Check for a function like this in the playback sound menu.
Nov 06, 2007 | Panasonic NV-DS60 Mini DV Digital...
Home Security Logo
118 people viewed this question
Top SWANN Home Security Experts
Electro Med Services...
L Pfaff
L Pfaff
Da Doc
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
