Question about VinoTemp VT-60 Wine Cooler
Settings on cooler are not holding and cooler only reads room temperature
  • 884 Answers
Need more info - is the compressor running?
Posted on Apr 22, 2014
Why will my MaitreD winer cooler temp not lower
Is the fan coming on? Is the condenser coming on? Sounds typical of a t stat to immediately return to room temperature display on the display.
Jun 04, 2016 | Heating & Cooling
Breeze air wkl 3000 blinking temperature al
NEW UNITS HAVE A VISUAL ALARM PRE SET TO KICK ON AT 62 DEGREES OR ABOVE, WHE THE WINE COOLING UNIT READS 62 OR ABOVE IT WILL FLASH "AL" AND THE TEMPERATURE NUMBER THAT FORVED IT TO KICK ON, IT IS JUST A VISUAL ALARM IT WILL NOT TURN UNIT OFF OR STOP IT .
THIS FEATURE WILL SHUT OFF ONCE THE UNIT READS ANY TEMPERATURE BELOW 62 DEGREES.
Dec 27, 2013 | Breezaire WKL-2200 Wine Cellar Cooling...
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
I have a MCWBC77DZC magic Chef wine cooler 2 years old all of sudden stopped cooling. The power is ok but as I adjust the temperature it does not hold and goes back to room temp. It seems liek the relay,...
I have a MCWBC77DZC that stopped cooling too. After reading several post on websites, I replaced the compressor start relay and is now cooling again. Horray! Ordered the start relay from www.RepairClinic.com Item number 1795921 Part #: 6R8MG $20.55
May 10, 2011 | Magic Chef MCWC44DZ Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
We got a Haier 42 wine cooler. The motor doesn't run.
This is something you can not fix yourself. Remember it might cost as much as a new wine cooler to repair. As for free estimate on repait. That way if it cost to much your not out anything. Rus
Jun 17, 2009 | Haier BC112G Wine Cooler
Improper Termperature Readings during AC run
personally i'd just replace the thermostat, but try pulling the front panel off and look on the circuit board and see if there is a jumper for F/C or any other settings. you may try changing its position. you can also remove the batteries for 15 minutes and see if it resets itself. the only other thing it could be is a wiring issue.
May 29, 2009 | Heating & Cooling
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Jan 11, 2009 | Heating & Cooling
My appartment does not have cenral AC/heat, it has a GE cooling/heater unit in each room. You can set up low heat or high heat but it continues runing on until you manually stop it when is to hot. Is there...
the unit runs all the time because of the fan (ventilation motor)-but it is not working on cooling or heating all the time - The ventilation motor pushes the air from the room through the machine and when the termostat is reading that you set it up for cooler air or warm air it will turn on the air conditioning part or the heating part of the machine-it is very good system actually
Oct 04, 2008 | Heating & Cooling
The Honeywell Programmable Heat Pump Thermostat CT3611R is not adjusting the temperature to a cool setting. Cool air is coming out of the vents however the temperature on the thermostat remains the same...
if your problem has existed since the begining of installment it could be a return/ thermostat placement problem. if the return is to close to any supply vents it will run like that and your thhermostat will read like that
Apr 24, 2008 | Heating & Cooling
VinoTemp VT-60 Wine Cooler Logo
150 people viewed this question
Top VinoTemp Refrigerators Experts
Ilia Bichin
richie46
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
