Question about Xerox Office Equipment & Supplies
Workcentre 3220 system error
I"m getting the error NIC_bridge_gzip.c1334 root, what should i do?
  • Alex fox
    Alex fox Apr 24, 2014
    the prinetr does not respond to anything i do. it's a xerox workcenter3210
  • Gary
    Gary Jul 06, 2014
    Is this error displayed on the printer or on your PC?
4 Suggested Answers
  • 2072 Answers
SOURCE: workcentre c2424 is showing system error 39,003.40:117010
That is a document feed or scanner fault. Often times it is simply that molex connector working loose. It is the connector mounted vertically next to the main power cord on the right rear side of the machine. That bottom screw can be dificult to tighten. What I would try first is to shut the machine off, unscrew and disconnect that conntecot totally then firmly slide it in and get both the top and bottom screwss tight. Like I said, the bottom thumb screw can be hard to tighten even with a screw driver because it is a pretty soft rubber the tighteners are made out of.
If that doesnt work. go to the back and disconnect the document feed to scanner cables and reconnect. Other than that, you pretty much have to replace the feeder/scaner assembly since very very few parts are spared for that .
Posted on Oct 23, 2008
  • 5 Answers
SOURCE: My problem are a printer.
check if ur using the correct driver. do not use the one that is automatically installed.
Posted on May 05, 2011
SOURCE: i get "Send Error (SMTP)"
It took me a while to figure this out. Your 3220 must be connected to ethernet (I havent tried it with the 3220 connected directly to the computer). Also, this works with a free email with domain Godaddy account, so YMMV.
1. Open your web browser and navigate to the 3220's CentreWare IS. 2. Click on "Protocol/SMTP Server" 3. Check "Host Name" 4. Type smtpout.secureserver.net/80 for server/port 5. Check "SMTP requires authentication" 6. Enter your username/pw 7. Click "Save Changes"
If you are asked for a username/pw to save the settings, the 3220's default are admin/1111.
Now click on "E-mail/E-mail Setup" on the navigation. Make sure your default [From:] address is your sender email address (they must match). Click "Save Changes"
As a final recommendation, I strongly suggest that you create your address book (E-mal/Local Address Book on the navigation) to make it easier to send by email, otherwise you will have to manually enter email addresses using the 3220's keypad (very slow!). Create groups for sending scans to several emails without having to select each individual email from the 3220's panel (also slow!).
Hope this helps.
Posted on May 13, 2011
HOW TO RETRIEVE ITEMS IN MEMORY IN XEROX 3210/3220 WORKCENTRE FAX ?
dear Is there any error or masage disply on the screen. Pl. revert back.
Thanks.
Dec 18, 2014 | Xerox WorkCentre 3210/3220 Multifunction...
What to do if this is coming in between ( gzip.exe has stopped working) ?
re-install gzip if this is for ubuntu
type sudo apt-get remove gzip this removes it
sudo apt-get update
then run
sudo apt-get install gzip
this re-installs it then log off and log back in and see if you get the same error.
Jan 25, 2012 | Microsoft Computers & Internet
My problem are a printer. System error while power on display. Xerox: workcentre 3220
May 05, 2011 | Office Equipment & Supplies
I get "Send Error (SMTP)"
Hope this helps.
Dec 31, 2010 | Xerox WorkCentre 3220 All-In-One Laser...
Audio bridge runs for a while then goes down
What is the error at console ?
Can you run "dcbps" when the bridge is running and let me know the output ?
Any alarms there on dsp or nic card ?
Sep 29, 2010 | Spectel -Conference Bridge System 780 W...
How can I reset the NIC on the WorkCentre 4150? I'm experiencing network configuration problems on the printer, and I was told a reset of the NIC would fix them. But I don't find in 'Tools' a command to...
  1. From the WorkCentre, enter the Tools mode. See the Related Items below for additional information. The Tools Mode screen will be displayed.
  2. Select [Software Reset] from the Touch Screen.
  3. Select the [Reset System Software] button. A popup window will be displayed warning that jobs on the machine may be lost and asking for a confirmation before the reset is performed.
  4. Select [Confirm]. The WorkCentre will reboot the system software.
Feb 01, 2010 | Xerox WorkCentre 4150 Black and White...
124 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
