Question about Fellowes Powershred PS-70
Fellows PS-70 shredder basket ajar light is on
The basket ajar light is on and the shredder won't work. I've removed the top and placed it back and still nothing.
  • 31 Answers
Here is some general advice. Shredders have an interlock to be sure they don't run while the basket is not in place. They don't want you holding the head unit and it starts running and shreds your fingers. So you need to look for the switch that tells the head unit that it is in place over the basket. I'm guessing here but it might be something like a little plastic protrusion that pushes into the head unit to activate a swith. It is possible that the little plastic piece is broken and is not activating the head unit. That would explain why the display thinks that the basket is ajar or misaligned. BE CAREFUL if you tinker with the interlock and be sure it is unplugged!! That is an ORDER!
Posted on Apr 22, 2014
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
My fellows PS-65S electric eye has been cleaned and still won't take paper to shred
I have had the electric eye come out. they kind of lock in there. I have had a couple push back. I had to take glue the electric eyes into the slot. like I said I have had this happen on two fellows shredders.
good luck
Jul 18, 2012 | Office Equipment & Supplies
Need a new (3 way) switch for my fellows ps 60cc shredder where can I buy one from...can you send me a email address?
fellows # 800-955-0959 they take credit card.
Hope this helps leave feedback. Have a nice day
May 15, 2010 | Office Equipment & Supplies
MY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH PAPER.WENT TH SHRED ENVELOPES AND TOO MUCH PAPER WAS INSIDE.hOW DO I UNJAM THIS? iVE TRIED REVERSE SLOWLY THEN FORWARD,ETC.IT IS STUCK BADLY.I SAW AN ANSWER...
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Apr 21, 2010 | Fellowes OD1200 Shredder
I have a Fellows Powershred ps 60cc and removed the shredder top to empty the shredded documents. When I put it back on, the red light will not go out and it will no longer work. It was working perfectly...
the shredder has a safety switch that closes when the unit is put back on the basket. check under the cutter head for the hole that has the switch and check your basket for the acuator put together so they will line up
Nov 03, 2009 | Fellowes Powershred PS-60 Shredder
My PS-65C,won't work because.............
Don,
Sorry, no spare parts are available.
Sep 17, 2009 | Fellowes 3011001 Shredder
Basket ajar light stays on even when the door is closed. How do we get the light to go out?
The door sensor could be bent or broken. There is also a thin piece on the door that pushes the sensor switch. Check to see if it is broken. Try pushing a thin object into the sensor **** opening and listen for a click.
Jun 18, 2009 | Fellowes Powershred 120C-2 Shredder
The empty basket light stays on all the time
Try cleaning the bin full sensors. located on both sides of your machine, inside the bin,under the cutter head. If that does not solve problem, you need to replace bin full sensors.
May 04, 2009 | Fellowes Powershred 320 Shredder
PS-70 Shredder problem
Make sure that the shredder is locked down in its case by pushing down on all 4 corners.
Since the basket slides forward to empty it, I would think the safety switch is located in the front but not positive since I don't have a unit right in front of me.
Check to see if you see a slot in the top part of the shredder unit. Usually the basket has a piece of plastic that will line up with the slot when the basket is in place (Safety switch) so that the top part of the shredder knows that the basket is in place.
Look around with a flashlight, If you are going to feel around with your hand, PLEASE MAKE SURE YOU UNPLUG the shredder just to be safe.
Hope this helps.
Good luck.
Mac =)
Feb 10, 2008 | Fellowes PS-70 Shredder
PS-70-2 not working
Make sure the pull-out wastebasket is all the way in. Also, make sure the basket is less than half full. A paper jam could also cause this symptom.
Jan 22, 2008 | Fellowes P70CM Shredder
Fellowes Powershred PS-70 Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
