Question about Canon DC50 DVD Camcorder
Dc50 disc will not open
Dvd will not finalize can not open disc?????
I recorded my sons wedding with a dvd-rw. I went through the finalization steps. When I tried playing it on a dvd player it wouldn't recognize the disc. I tried to finalize again or unfinalize and the...
There is definitely a solution for this but you must use a computer to recover the information on that disc. It also depends on the software you are using to recover such information from the disc. My recommendation would be that you start by simply inserting your disc in the DVD Rom on the computer see what happens when you open My Computer on the Desktop then you click on the DVD rom icon to see if the DVD opens. If it opens it means the information on the disc can be read. so you click again on the folder that appears. If you have a media player installed then that media player will play back those video files. These files can then be transferred to the computer then authored by a computer software like Nero. There are many other programs that can do this job. Also such software can open sometimes such a disc if and when the windows operating system's My computer fails to open it.
Oct 18, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Finalizing a DVD-R blank disc
try changeing the disk name and then see if the finalize option is availalbe.
Jun 18, 2008 | Sony RDR-GX315 DVD Recorder
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Cannon cam dc50 cannot finalize the disk
your disk has a small scratch it has to be changed..
Jan 26, 2010 | Canon DC210 DVD Camcorder
Windows media player burned a dvd for me now when i tried to play it on my dvd player it wont work what do i do it says disc is not finalized please finalize the disc on the recorder which was used for the...
Most DVD player can't read open session discs, meaning when you burn your DVD movie there's an option there that when your disc is not full you can still add files on it, it's open session, in your case if you want to play it on dvd player you must select the finalize the disc to close the session and you can play it in any dvd player you want.
Oct 30, 2009 | Microsoft Windows Media Player
Finalizing disc
In order to finalize the disk you must have it plugged in. So no one does it on accident. After it is finalized you will be able to open it up on the computer or on most DVD players. I had the same problem at first, I have the same camera, I love it now...
I hope this helps you, let me know..
Jun 16, 2009 | Canon DC220 DVD Camcorder
Can not get the 'Finalize Disc' option on the
Do not worry about no Finalize Disk option. You may have it under another guise.
A recording session can be specofied as open ( Default ), or closed. If closed DATA cannot be appended to the disk.
No matter how many sessions have been written, if the last session is closed no more can be written. Your software automatically finalizes each session, in fact must.
Feb 23, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
No disc kicks disc out
I have the problem of it refusing the disc if the door opens before I have filled the whole disc and finalized it. As long as I don't open the door till the disc is full and finalized, it works.
Aug 30, 2008 | Samsung DVD-R130 DVD Recorder
Canon DC50 will not accept canon dvd-rw disc
Had the same problem went to the Disk Menu and Inialized the disk, Problem solved.
May 07, 2008 | Canon DC50 DVD Camcorder
Canon DC50 won't finalize
Have you tried connecting the camera to power supply before you try to finalize?
Jan 24, 2008 | Canon DC50 DVD Camcorder
Open Questions:
Canon DC50 DVD Camcorder Logo
15 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
