Question about Moulinex chrono jet iron 220 volts chronojet
How to fill water in moulinex chrono jet 102 steamiron. I am unable to find any openings.
Iron is leakin onto clothing while ironing
Leaking irons happen more frequently when performing lower temperature ironing. Minimize the chances of this happening by doing the articles that require less heat with a dry iron. When you're ready to do the articles that require higher heat settings, add distilled water to the iron after allowing it to cool first (some folks suggest using rain water as it will lack the minerals contained in the soil - where water pumped from the ground picks them up).
Distilled water is recommended by manufacturers for irons. Use of regular tap water will cause mineral deposits to form inside the iron that can build up and even clog the openings on the bottom plate. These can contribute to stains on the material being ironed, too. If you are unable to obtain distilled water, you ought to descale the iron regularly to remove deposits that will form by heating water or allowing it to simply evaporate. Distilled water lacks the minerals to be deposited by either of these situations. If distilled water is used - there is no need to empty the iron before storing. Tap water - whether supplied by the locality or a well is loaded with minerals and may be treated with fluoride, chlorine, etc.
Descaling
an iron is pretty straight forward - no more difficult than descaling a coffee maker. Empty the iron of any water. Partially fill the iron with white vinegar and turn on to heat. Iron and old towel or rag to allow all the vinegar to pass through the steam openings.When empty, repeat once or twice - but with fresh distilled water to flush any remaining vinegar from the iron. When satisfied that the vinegar is out, store the iron. You can purchase products expressly made for descaling irons - just like you can for coffeemakers, but vinegar is a great low cost solution that works very well.
I hope this helps & good luck!
Oct 14, 2011 | Micro Pro 7599 Iron
How to feel water in iron??couldn't find opening way?its Moulinex iron
To fill an iron which doesn't appear to have an opening with water - such as the moulinex chronomate 35 - you need to pull off the sprayer button. That should reveal the opening!
May 04, 2010 | Moulinex Brio IM3070 Iron with Auto...
How to clean brown water coming out of iron
The reservoir of your iron needs cleaning if it looks as though small deposits are being left in the small holes on the soleplate. Typically, the deposits are minerals from the water that you are using in the reservoir. The deposits may have a white color, and they may resemble salt.
Cleaning the reservoir requires the use of white vinegar and a clean rag. Fill the reservoir of a cold iron at least one fourth of the way with white vinegar. Turn the iron on and place it on the steam setting. Steam iron the clean rag until the reservoir is completely empty.
If the deposits are still visible to you, you will need to fill the reservoir with clean water and steam iron a rag again. If the deposits are still visible to you after this, you will need to repeat the process with vinegar until the deposits are no longer apparent.
Rinse the reservoir thoroughly with clean water by filling it completely and then emptying it completely. In order to avoid mineral buildup and deposits, use only distilled or purified water in the reservoir. If you continue to use tap water, simply remember to clean the reservoir periodically.
Vinegar has a strong smell associated with it, especially when it is heated. Ventilate the area where you are working as much as possible, by opening windows, turning on vents or fans, or keeping the door open.
The water you use to fill your iron is causing this problem. Once you clean it use distilled water available by the gallon at the grocery store. Joe
Apr 09, 2010 | Rival IR620 Iron
The cap is stuck unable to open to fill?
I had the same problem. I sprayed up into the bottom of the cap with liquid wrench, let it work for a while, then had to use large pliars to twist the cap off.
Jan 27, 2010 | Steam Fast SF-220 Iron
How to open to get water inside
No need to open iron! You just unplug the iron. Hold the iron upright. Using a clean cup, pour water into the "open" WATER FILL HOLES just above or in front of the Temp. Select Dial. Watch the water window on the left. When water level reaches MAX, you are filled. Plug in and use. Refill as needed. Ref. - Page 8 in the instruction pamphlet.
Oct 18, 2009 | Black & Decker Quick N Easy X420 Iron
How do you fill the water tank on the steamer conair model GS15RN?
FOR HOUSEHOLD USE ONLY
FILLING INSTRUCTIONS
1. Place the unit on a stable surface.
2. While holding the water tank with one
hand, move the release lever toward the
power cord.
3. With the reservoir released, pull up on
the reservoir to remove it from the body of
the unit.
4. Turn the reservoir over, revealing the rubber
inlet cover.
5. Open the inlet cover and fill the tank
with everyday tap water (filtered water may
reduce hard water problems).
6. Close the inlet cover and return the
reservoir to its place, making sure that the
reservoir is secure.
Hope this helps! Hal
Jun 04, 2009 | Conair Compact Garment Steamer Iron
EuroPro Steamiron
I need to find parts for the europro ep 8001
Sep 28, 2008 | Euro-Pro Steam Generator EP8001 Iron
Morphy richards jet stream iron
We have a water filter and softened water. Our iron is clean and went after 2 months.
A Morphy Richards Jet Stream Elite pro.
It is just the steam generator that has gone.
May 27, 2008 | Irons
Moulinex chrono jet iron 220 volts chronojet Logo
227 people viewed this question
Top Moulinex Irons Experts
Are you a Moulinex Iron Expert? Answer questions, earn points and help others
