Question about Samsung DLP HL-P5663W 56" TV
Is there a reset button because tv won't come on
THE TV WAS WORKING FINE AND WHEN i WENT TO TURN IT ON ALL i GOT WAS A SCREEN THAT FLASHED.
    Top Expert:
  • Samsung Master
  • 74,473 Answers
There is no reset button to this TV. If you wish to do hard reset to it, just unplug the TV from AC mains wall socket, and re-plug it back after 30 minutes or so. This procedure should make it a hard reset.
If you want to do a system reset [factory reset]; you have to enter its service mode option to do this.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Apr 23, 2014
I have a 55 inch JVC tv,today the screen went black but still have sound, also the buttons on the back wont work, but the channel down button turns it on and off? What is wrong with it?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary..
Jan 15, 2017 | JVC Televison & Video
10yr old Sanyo tv working fine then "mute"flashed on screen,tv went mute and wouldn't respond although everything else works normally.Not a flat panel-
try reseting the tv and remote.....unplug tv from the wall plug for 5 mins. then remove batteries from remote.....from left to right at the top of remote hit all the buttons on remote then put batteries back in try that......
Jan 16, 2016 | Sanyo Televison & Video
I have a sony KP5375 TV and the screen flashed and went dark. Now it won't turn on and there is a electrical smell coming from the TV. Reset doesn't work. Does this sound like it is more th
yes bulbs dont smell unless they pop plus its 3 bulbs in there, plus the tv would still have power/standby lights, and it's not that type of smell, replace the bulb but im sure this will not fix the problem, also my experience with dlp set it is often not worth repair, good luck you need more help or question just ask good luck
Mar 30, 2013 | Sony KP-53S75 53" Rear Projection...
TV went off, standby timer light flashing
Try unpluging from the wall and theplug back in and try turning back on to reset. Sometimes holding the power button in while pluging back in will reset it, every brand is different for the hard reset.
Scott
Apr 17, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Hi, My philips 42'' plasma won't turn ON. I went to turn it on and the ''on'' button flashes red 7 times 4 seconds apart
I just had the same problem. I downloaded a service manual and give this a try http://www.servicemanuals.net . Turn on your TV and with the remote do the following Key in the code “123654” via the standard RC transmitter. This get you into a customer service mode and you can check your error codes.
After I got out this mode my TV worked. I think the TV was stuck in protection mode for some reason and by entering the service menu's it reset it.
I then entered the SAM Mode
How to Activate SAM
Via a standard RC transmitter: key in the code “062596”
directly followed by the “INFO” button. After activating SAM
with this method a service warning will appear on the screen,
you can continue by pressing the red button on the RC.
It will give you more info.
The TV worked fine after I exited these menu's.
I also did a software update as per the user manual and the TV seems to be working fine again.
Hope this helps
Sep 09, 2009 | Philips 42PF9631D 42 in. Plasma Television
TV NOT TURNING ON
COUNT THE LIGHT FLASHES // FOR THE CODES
Oct 18, 2008 | Mitsubishi WD-62528 62 in. LCD Television
Mitsubishi WD-52725
Manual should be available here to look at or dwonload. I copied the reset instructions. You may have to go through some set-ups after a system reset. Good Luck.
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
System Reset
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
Sep 23, 2008 | Mitsubishi WS-65819 TV
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Aug 22, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
46 people viewed this question
Henry  Thomas
Henry Thomas
