Question about Sony Cybershot DSC-W320 14.1MP
DSC-W320 CYBERSHOT IMAGE RECOVERY - Sony Cybershot DSC-W320 14.1MP
fotomohamed
  • 321 Answers
SOURCE: I have a sony cybershot dsc- w55,all works well
screen strip broken or change LCD cost 100$
Posted on Jun 18, 2009
  • 11967 Answers
SOURCE: I'd like to change de resolution from 72 dpi to
Set the camera for the highest megapixels and picture quality to the highest level.
Posted on Mar 16, 2010
sonyfsd
  • 161 Answers
SOURCE: No image on LCD Screen - Sony Cybershot model DSC-T1
if there is no picture at camera mode so in this case camera ccd imager ic is defective so please go to your nearst sony service centre & fix the problum
Posted on Apr 25, 2010
hmerchant110
  • 7191 Answers
SOURCE: user manual for sony cybershot dsc w320
You can download the user manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Thanks for using FixYa.
Posted on Oct 03, 2010
  • 11967 Answers
SOURCE: I have a SONY CyberShot
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 09, 2010
IMAGE RECOVERY
Photo Recovery from Sony Cybershot is very easy using Remo Recover tool. I have used this application on my camera to recover deleted images many times and I was successful every time.
Apr 22, 2014 | Sony Cybershot DSC-W320 14.1MP
Dsc-w320 photo recovery software
Most memory card producers do have free recover software on their site. Look under support.
I recently I downloaded from Transcend, for my memory card. I remember, the asked for the product code and serial number, before I could download. But just visit the website from the firm your card came from.
The lens in going in and out
Was there any type of impact damage? Any lens error message? This doesn't sound like a home fix.
Dec 08, 2013 | Sony Cybershot DSC-W320 14.1MP
Cyber-shot DSC-S930 doesn't read on my laptop. Why?
put the memory card into a card reader that should work ok.
Oct 05, 2012 | Sony Cybershot DSC-W320 14.1MP
Sony cybershot camera flash not working
The flash bulb is the likely problem, take it to a camera shop to get the correct part, they may even install it for you.
May 07, 2012 | Sony Cybershot DSC-W320 14.1MP
Sony Dsc h2o dropped in water
you need to replace the card or dry it out samewhere warm
Apr 03, 2012 | Sony Cybershot DSC-W320 14.1MP
Hi, I have Sony Cybershot DSC w320 digital camera of 14.1 MP. Can you please tell me how I can take the pictures on less Mega Pixcal so that the size of file get reduced. Thanks, Prateek
The image size determines the size of the image file that is recorded when you take an image. The larger the image size, the more detail will be reproduced when the image is printed on large format paper. The smaller the image size, the more images can be recorded. To change the Image Size in the Camera, press and select the MENU-->Image Size-->Desired Size [(640×480)VGA or (2592×1944)5M] The quality of the VGA Image is very less when compared to the 14M.
Good Luck
Nov 09, 2010 | Cameras
C:13:01 Memory stick formatting error
Try to format this card in your PC first using a standalone read/writer then place back into the Cybershot DSC-W320
This can happen sometimes after you have wiped the card using Google Picasa
Aug 26, 2010 | Cameras
Cameras Logo
15 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
