Question about Philips Televison & Video
L01.1A philips width jumping in and out - Philips Televison & Video
  • 668 Answers
The L1 series chassi has had issues with the 130v Regulator IC and associated componets in the powersupply . This all I am able to help with.
Hope this helps,
Skyassoc
Posted on Jun 20, 2009
Replacement part
Hi there. The part is an optocoupler. Try to replace it with a CNX83A
This device also has a footprint width of 10 mm. I assume it is used
in the feedback circuit fom the switch-mode power supply. For safety
reasons the width is 10mm as one side is as mains potential.
Jan 28, 2014 | Philips CDR770 CD Recorder
Not sure which philips i have, but suddenly lines have appeared at the top of the picture, going the width of the screen, about 4 inches down the screen, and moving downward.
It seems you may have a vertical linearity problem. Check all electrolytic capacitors around the frame output stage. The frame output ic may be at fault but this is less likely.
Regards Vintie
Aug 22, 2010 | Philips Televison & Video
The tv will not turn on. I need to change the bulb in the tv
Snap-off lower front panel ( about 4" tall x width of TV.) Door behind there with philips screw. Philips screw for lamp itself.
May 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Red strip on right of screen
If the line is only one pixel in width then the panel is bad. If the line is an inch in width or more then there is a possibility it is a bad data driver board. This issue should be looked at by a technician.
Nov 13, 2009 | Philips Televison & Video
The clock on my Philips DVDR3575/37 jumps 20 years into future
yes you could but you need to replace the battery inside the unit to make it keep time it's the same as the batteries for mother boards.
Jun 25, 2009 | Philips DVDR3575H/37
Philips - dvp 642/37
Player goes back to standby because the power supply still has a problem.Run checks on semiconducters in primary cct. of chopper transformer.If ok, replace the pulse width modulator.That should fixya.
Jul 23, 2008 | Philips DVP642 DVD Player
Philips 104E width uncontrollable
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 16, 2008 | Computers & Internet
Find the Price for cabinet door
If you dos program can support Structured Query Languange (SQL) that's possible to do it. example sql statement below:
SELECT * from Cabinet WHERE height='numeric' AND width='numeric' ORDER BY Height, Width
But since it doesn't work with your existing programming language, much better if you will migrate to GUI programming language such as Visual Basic, Visual C++.
Hoping for your kind approval to make my rate solved.
Best regards,
Philip
Nov 05, 2007 | Computers & Internet
1998 27' magnavox tv/combo
Frame width is normal means. Check aspect ratio is changed in menu options. Even width is also enlargement means there is high output from power supply section. Check and change the high voltage filter capacitor.
Sep 09, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
