SOURCE: Graph a cubed root fuction on ti-89
Here it is
[Diamond][Y=] enter y1=(2-X)^(1/3)
[Diamond][GRAPH]
Hope you liked the graph
SOURCE: What is the cube root function on the ti-86
look under math calc and there should be an x^3 key
SOURCE: entering a cubed root into a ti-83 plus
You can enter any root by typing the number, then hitting MATH and 5, which brings up the root symbol with the x in front of it: x√. So the fifth-root would be 5 -> MATH -> 5 and then whatever number you want to get the fifth-root for: 5x√10 for example. As someone else had mentioned, you can also raise it to a rational power: 3^(1/3) which would be the same as the cubed root of 3, but you could also type: 3 -> MATH -> 5 -> 3 and get the same answer, but looking like this in your calculator: 3x√3. The option for 4 actually is a predefined cubed-root, and the one for option 5 there is the root symbol that can be used with any number before it to get any root you want. There are no parenthesis as you get when using the predefined square-root and cubed-root functions, though, so you may want to type them in yourself if entering a long string of operations in the calculator at one time to make sure the calculator doesn't include numbers under the root that you don't want it to. But I guess it depends on preference in terms of what method you choose between the rational exponents or the root symbol (and most would go with whichever seems easiest and quickest to enter), but you asked specifically how to get the cubed-root on the TI-83 Plus, so there's my best attempt at answering your question.
SOURCE: how do I find the cube root button on my TI- 86
There is a relation between roots and fractionary powers.
2nd root (square root) of X = X^(1/2) power 1/2
3rd root (cubic root) of X = X^(1/3) power 1/3
4th root of X = X^(1/4)
n-th root of X = X^(1/n)
Use the raise to arbitrary power key labeled as a caret [^] or [X to the y] or [Y to the x]
Hope it helps.
SOURCE: how to find cubed root on a TI-89 calculator
To find the cubed root (or any root) of a number, use the root() function.
If you want the cubed root of 125, you would type:
root(125,3)
