Behringer pmx880s Tr 1 (transformator)burnt out. Please send me the specifications of this item. thanks Nico
  • 42 Answers
Behringer Powerplay Pro-8 HA8000
Most behringer transformers are 18Volts 1-2 amps to my knowledge, specially in the smaller units. If you are not sure start with reconnecting a 12 volt (AC) external supply and see how you go. Behringer uses (indicated) 17Volts transformers but that is neither here nor there. Good Luck.
Aug 13, 2014 | Behringer HA8000 POWERPLAY PRO-8
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
Behringer BXL900 Ultrabass keeps blowing fuse. I have the correct fuse, but they blow as soon as I install them. I looked inside to see any obvious issues and I couldn't see anything. Has anyone else...
We found a "Short" Power Transformer..and we are looking for one..Here are the part #:Model BXL900...ID TR-TOR-LAP190-EU...or ID-TR05-0022....You can write to us at : nuevonuevonuevo@aol.com
Aug 29, 2013 | Behringer Audio Players & Recorders
I need to replace the transformer. What is the specification and where can I get one? Thanks
The internals run on +/-15 Volts and +5 volts. While schematics show the audio and digital circuits they fail to show the power supply. I suspect the supply uses regulators such as the 7815 family so one would want around 18 to 20 volts DC of each polarity.A transformer would likely be about a 28 to 30 VAC centertapped. HOWEVER transformers rarely fail. There should be fuses to protect the transformer. Some Behringer equipment uses a switching supply. Common failures in those is the switching transistor. When testing these units, it is useful to place a 25 watt incandescent lamp in series with the power cord to save fuses and act as a resetable fuse that will send a limited current into the unit for testing.
Jun 14, 2011 | Behringer Pro Mixer Djx750 Professional 5...
Both fuses burnt and both clip and signal led on? seems to have full power behringer ep2500
Suspect an overload in either the power supply section or the devices on the main heat sink. In the power supply you are either looking at a transformer problem or semi-conductors associated with it. However since the clip and signal lights are on, I would go to the amp devices on the heat sink. If they are transistors test them with a Ohm Meter on the 1K setting in circuit even! You will soon notice which ones are gone! The meter will show like you had touch the test probes together!
May 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
Need schematics for honeywell s861ou3009
Those terminals are the power to the module. The tr should be the 24v (hot) line coming from the transformer. The tr/th is the common from the transformer and the th is the 24v line coming back from the t-stat. So tr stands for transformer. the th stands for thermostat. And the th/tr is the common.
I know you ask for schematics but I felt that I could easily explain it to you. It really isn't all that hard. In some cases the tr does not need to be hookup. if you only have two wires there than just hookup the th/tr and the th and it will work.
Nov 18, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My Behringer ADA8000 Ultragain Pro-8 stopped working all together
Hi. I have an 2 ADA 8000 and one went down with the same fault after 7 years.
Firstly, there is a slow blow fuse in the back above where the kettle lead goes in. CHECK THIS FIRST!
If, like me, you change it and it blows again, change it a second time and it maeks a "crackling noise internally. There is a problem with the internal transformer.
From a lot of talking and searching, I've found out what you need to do. Either yourself or and electronics expert needs to do this.
First of all, you need to order a NEW transformer. You need the specific one from Behringer.. I am in the UK and obtained it from EMS. Their number is 01702 613 172. While waiting for this to be delivered, you need to check the power regulator and the 100Nf capp and the 10Nf caps as these can go faulty and cause the transformer to "over work", meaning that as soon as you put in the new transformer, it could go again pretty soon.
These caps I'm told are generic and do not need to be obtained from Behringer. THE TRANSFORMER DOES.
I Hope this helps you all out as I could not find this information online, this is from genuine experience, from people "in the know". Please spread this info about to help others like us who are stuck in a tight place.
Apr 07, 2009 | Behringer Ada8000 Ultragain Pro 8 Ch...
Need a manual for a tr 440 bread maker
Hi grover_quinn,
I recommend trying
http://www.breadmakerguru.com/
They have a very good selection, and there's a Chefmate link that leads to a page with a manual as well as spare parts specific to the model you listed above. I'd recommend seriously considering any wear-items/parts, as they wear out in inverse proportion to their availability - - see also Murphy's Law).
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Feb 20, 2009 | Chefmate TR 7000 Bread Maker
I lost the manual of my oven
Hi kathyaco,
I recommend trying
Jon
Jan 22, 2009 | Chefmate TR 7000 Bread Maker
46 people viewed this question
 Grubhead
Grubhead
