Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
My DGB-500bk cuisinart grind & brew coffee maker shuts off in middle of brewing cycle
The unit shuts off as if no electricity. I have to restart
SOURCE: Coffee maker shuts off during brew cycle
I to have been battling this same problem on and off for a couple of years, and have been trying to find out why it thinks it id done brewing. I have had some success but exactly what fixes it I don't know.
I called Cuisinart and they told me to change the water filter in it. This didn't work, but I did see some grounds and even a bean had gotten under the filter. I cleaned that out and it fixed it, that time. If you don't have a filter, shine a light down the water reservoir and make sure you don't see anything.
Other than that I do a bunch of cleaning cycles with, Brew Rite Cleaner, Whink Automatic Drip Coffeemaker Cleaner, and vinegar. Don't mix them, just follow the directions on each. Follow with a bunch of rinse cycles. I still don't know which one does the most to fix the problem. For all I know it could just be all of the rinse cycles.
Just keep trying, there is hope that you won't have to tend to your coffee maker forever.
Posted on Dec 13, 2007
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
SOURCE: Leaking cuisinart grind and brew
Our Cuisinart grind and brew was leaving a puddle under it after making a pot of coffee. I called Cuisinart this week and it turns out the handle of the carafe has to be lined up in the middle of the opening for the carafe. It will be under the word Cuisinart, in the middle.
We have now made several pots with NO residual puddle of water or coffee. It also seems to be making the pots quicker.
Before trying this I had run 2 pots of water with 1/2 cup white vinegar in it also. But it still puddled until we lined up the carafe as noted above.
Posted on Jan 16, 2009
SOURCE: Cuisinart DGB-300 coffee maker brew pause valve
I just called Cuisinart and they will send me another brew basket for my DCC-100 (it has a Brew Pause valve also) for $9.14 (part + S&H). Did you try to contact Cuisinart?
Posted on Feb 03, 2009
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
My DGB-700BC cuisinart coffee maker grinds beans but then gets stuck and will not continue brew cycle. keeps beeping. please help!!!
We bought our Cuisinart 12 cup grind n brew less than a year ago. Almost as soon as we started using it we began having problems with it hanging up between the grinding and brewing cycles. It would sit and click. I tinkered with it incessantly and usually could, after fiddling long enough with the filter lid, get it to brew, but it was aggravating, to say the least.
When one morning it would NOT work I called Cuisinart and was relieved to hear that there is apparently a problem with some of the filter lids not seating properly. They are sending us a new one. The rep I spoke with told me that if this did not work they would replace the unit, so at least it sounds like their customer service may be on the ball.
So, call Cuisinart for a replacement of your filter lid and see if that solves your problem.
May 12, 2010 | Cuisinart Grind Brew DGB700 12Cup Coffee...
Problem with a Cuisinart Coffee Maker
Hi I have a dgb600bc coffee maker the beans do not grind all the way and it makes a funny noise when grinding. thanks
Nov 28, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
NEED oWNERS mANUAL FOR gRIND & bREW SO i CAN SET IT
if you go to this address you can download a manual...
http://safemanuals.com/user-guide-instructions-owner-manual/CUISINART/DGB-300BK-_E
if the address doesn't go just go to safemanuals.com and in drop boxes choose cuisinart/dgb-300bk. will take you to thie page.
enjoy your coffee.
Dec 02, 2008 | Cuisinart Grind and Brew DGB-300BK 10-Cup...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a dgb600bc grind and brew. It will initially grind and brew the coffee hot, but as soon as the brewing is done the heating element shuts off causing the coffe to slowly get cold.
When the cycle is finished, the coffeemaker will beep 5 times, indicating that the coffee is ready. The unit will turn off automatically.
The insulated carafe keeps the coffee warm for four hours. The aroma of the coffee is preserved thanks to the hermatic cover. It is not necessary to remove the cover to pour coffee.
Hope this will help you.
/Mirran
Jul 24, 2008 | Cuisinart DGB-600 Coffee Maker
Delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Oct 04, 2007 | Cuisinart DGB-500 Coffee Maker
Machine shuts off after beans are ground & sometimes when pot is 1/4 full
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. Serial number is engraved onto the very bottom of the coffee maker - hard to read. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
PS: The DGB-550BK is better
Jul 17, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
54 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
