Question about Tablets & eReaders
Panasonic toughbook cf-74 blue error screen loop
After the startup screen seems to boot up correctly, a blue error screen comes up. The screen isn't even on long enough to read it. It shuts down and tries to start up again. It does that over and over until it's shut down.
    Problem Solver:
  • 18 Answers
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Posted on Apr 22, 2014
JLBeertender
  • 56 Answers
SOURCE: Trouble booting!
You could attempt to boot to safe mode, and run the Start> System Recovery > PC Recovery Application.
Otherwise, I'd boot to safe mode, select start, run, type: msconfig, select the startup tab, remove any unwanted startup items that may be causing the system crash.
Hope this helps.
Posted on Apr 16, 2009
pagebor
  • 2785 Answers
SOURCE: setup password
i think the computer is asking for bios pc if it is bios then you have to open the case and remove the bios battery for five sec.before this you have to remove the power plug.after five sec. just resit the battery and put the power plug back and switch it on.
plz post your findings
Posted on Apr 23, 2008
  • 3 Answers
SOURCE: I Have 2 Panasonic CF-19
Go here and download the drivers and calibration tools.
https://eww.pavc.panasonic.co.jp/pc/cgi-bin/itn/toughbook/dl01.cgi
Posted on Jan 19, 2009
SOURCE: panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Posted on Feb 25, 2009
  • 309 Answers
SOURCE: panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Posted on Jan 09, 2010
I need to the Panasonic cf-18 drivers for a sounds, video and gps and touch screen os
Go there :
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
or there :
http://www.panasonic.com/business/toughbook/computer-support-search-downloads.asp
Choose your model, OS, language.
Select Category=All Drivers.
From the list, download and (re-)install the driver and utility related to your device.
Don't forget to comply with the Install Instruction (beginning of the list) :
it indicates the correct drivers installation order.
Jul 13, 2011 | Panasonic TOUGHBOOK CF-18 Tablet PC
Toughbook cf-18 cannot boot thru window. it come out with a start using safemode, then go into window , then blue screen with "a problem has been detected and windows has been shut down to prevent damage...
Yu possibly have a virus
You will need to format the hard drive and reload Windows if this doesn't work you will need a new hard drive.
Try to "defragment the hard drive 1st. check the disk for errors.
Apr 27, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic toughbook cf 18
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic cf 18b toughbook,touch screen do not work,help
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Trouble booting!
Hope this helps.
Jan 08, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Touch screen
Send me your email address. I have all of the drivers. I ran into this problem, be cause the tablet drivers from panasonic would not work. I downloaded a driver direct from WACOM and it solved the problem.
Dec 01, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic CF-18 screens
Maybe you should try re-installing the drivers.
Here's a link
Jun 16, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Tablets & eReaders Logo
103 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
