Question about Black & Decker 1700 PSI Electric Pressure Washer
Pressure washer runs for 15 minutes then shut itself off. Overheating? I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can b
I have a B&D pressure washer model PW1600 that runs fine for about 15 minutes then shut itself off. I have to let it cool for 30 minutes before it can be used again, may be for 10 minutes before shutting down again. What can be wrong and how can I fix it? Thanks
  • garfield jones
    garfield jones Apr 26, 2014
    Thank you Fasteddy. I will try the pressure wassher with a new larger and shorter garden hose and let you know how it goes. Thanks again.
  • 29 Answers
Not enough water VOLUME and pressure to supply the pump with a steady flow of water. Water is cavatating (adding air to the water) and the piston is heating up and jambing. Try using a larger size hose diameter and a shorter hose to supply the pump.
Posted on Apr 23, 2014
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
Pressure washer shuts off overheating
If you are using an extension cord this will happen. If using an extension cord make sure it is a 12ga.If you are not using an extension cord then it could be a bad motor or low voltage from the source.
Apr 19, 2014 | PowerStroke 1700 PSI Electric Pressure...
John Deere 3000psi pressure washer stalling
Mine is having the same issue...I googled and found this with no answers. I'll update if I can find a cure on my own...
Have you checked your oil level?? Small engines have a cut-off switch if your oil is low...mine is topped off so this is not the solution for me..but it could possibly for you.
May 01, 2010 | Garden
I have a Honda GX 390 with 13 hp power washer. Overheating.
Make sure the engine is not full of paint or dust debris in it's cooling system. If the fuel mixture setting is very lean, it can cause overheating. Make sure the fuel tank vent is open to prevent fuel starvation. Does the engine seem to be running at full operational speed? If not, it will be short on developed horsepower. Make sure the water source is not partially shut off. Hope some of this helps!
Feb 25, 2010 | Air Tools & Compressors
My xbox has 2 red lights it keeps overheating but the heat sinks dnt get hot
Wrap it in a couple of towels and let it run, 10-15 minutes, it will overheat and shut down and the three red lights will be flashing, then turn it off, let it cool, 15-30 minutes, turn it back on and bam, it should work, granted its not a permanent thing but it will work from a week-month, from then on the red ring of death will appear when it shuts down instead of the 2 lights, and you can either fix it yourself, do the towel trick again, or just send it to Microsoft if the warranty is still intact. trust me it works.
Jun 11, 2009 | Microsoft Xbox 360 Console
Electric power washer shuts off
Sounds like a coil.Run till it shuts off, then check for spark.If there is no spark you will need a coil.
Mar 17, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
WD 52525
This is a sign of a failing capacitor set on the power board. there may have been a small or minimal pulse that went threw the set during the power outage and when the power was restored. this could also be overheating as well due to dust forming on the power boards components. i would remove the back cover and clean as much dust off the power board as possible with some sort of canned air if possible. make sure the cooling system is working properly as well.
please rate and god bless.
Mar 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Dryer shuts off after 10-15 minutes
The motor is overheating and shutting down, cooling down, overheating again. Motors are expensive and tricky to install. PLEASE rate my solution as solved if you feel I answered your question accurately.. Thanx
Oct 02, 2007 | Kenmore 62872 Electric Dryer
Black & Decker 1700 PSI Electric Pressure Washer Logo
361 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
