Question about Casablanca Fan Metropolitan 6445T
Is there a reason not to use LED lights in my Casablanca fan with Intellitouch controls?
I am trying to conserve energy and have switched all of our lights LEDS. Can I harm my fan controls by using them. The lights are rated for use in fans and they are dimmable, although we never dim the lights using the intellitouch-- we just turn it on and off and rotate the direction of the fan.
  • 1 more comment
  • Ellen Friedman
    Ellen Friedman Apr 25, 2014
    Thought I would try the dimmer despite the fact that there is never enough light for me in that room. The dimmer on the Intellitouch does not work with the LEDS.. The button just turns them full on or off.. The button does work with the incandescents.
  • Fan Fair Of Boca
    Fan Fair Of Boca Apr 25, 2014
    Are the bulbs dimmable LED's? Not all are dimmable.
  • Ellen Friedman
    Yes, they most certainly are dimmable. Cree bulbs. They dim in all of the other fixtures.
    Genius:
  • Casablanca Fan Master
  • 1,617 Answers
Don't see why they wouldn't work.
Posted on Apr 23, 2014
4 Suggested Answers
MN_Jack76
  • 45 Answers
SOURCE: Casablanca Ceiling Fan
I've never heard of the light and reverse buttons being reversed. Normally It's the fan and light thats swapped (but your aware of that already). I would try a working w-32 from one of the other fans. There's also a shop called Fan Man Lighting in Minnesota who has a guy named Jason who has been fixing fans for over 20 years, He helped me with my Casa problems. Their website is www.FanManLighting.com Hope this helps.
Posted on Feb 06, 2009
  • 4 Answers
SOURCE: fan only buzzes when intellitouch control is used
if you have it on a dimmer and not a fan controle then the motor will buzz try to put it on a on and off switch see if that stops the buzzing if it does the go to home depot in the fan section and get a fan controle switch also caled a reastat
Posted on Aug 30, 2009
  • 57 Answers
SOURCE: Casablanca Intellitouch Fan was working fine..
Sounds like either the IT wall switch has malfunctioned, OR the IT board inside of the fan has shorted out. This is actually a fairly rare problem with the boards and you may get it covered under warranty. Try calling Casablanca. This fan is worth repairing rather than buying a new one.
Posted on Jun 10, 2010
Is there a reason not to use LED lights in my Casablanca metropolitan fans with intellitouch controls fans
I think the fan should be fine. If the fan is set to have a dimming option and the bulbs you use are dimming bulbs, I don't see the problem. They may be from different manufacturers but they should cause damage to each other. LEDS shouldn't be a problem.
Elisa Jed ' http://fancfans.com/fans/huggers
Apr 22, 2014 | Casablanca Fan Metropolitan 6445T
Casablanca intellitouch 3 light flicker
Call Casablanca at 1-888-227-2178
Feb 19, 2013 | Dryers
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
I have a Casablanca Panama fan with Intellitouch wall control (W-32). The control correctly turns on and off the lights, but when the button for the fan is touched, the fan makes a quick noise (like the...
There are different parts that might became bad and cause your problem like relay contact, starting capacitor, running capacitor. However all these parts are included in one unit the PCB printed circuit board or electronic board? So you need to replace this parts in attached link is also called RMM.
We have here below a link with service manual for the fan at which on the bottom you will find the parts diagram and parts list. You should try to confirm the part code for your model with Casablanca service department before confirmation of order.
Also please note that you will need a little experience with electronics before proceeding with above operation.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ConversionKit.pdf
Oct 31, 2010 | Casablanca Fan Panama II 50" Ceiling
Casablanca Intellitouch Fan was working fine.. Then only the light worked and fan switch made a quick bleep and started the blades moving but then both light went off and fan stopped. Now nothing works and...
May 15, 2010 | Casablanca Fan 3245T Ceiling
Fan only buzzes when intellitouch control is used
Aug 23, 2009 | Casablanca Fan Dryers
Nov 01, 2008 | Casablanca Fan 3245T Ceiling
Panama 5 12444T
try to replaced the dimer switch with new one.
Jan 19, 2008 | Casablanca Fan 74U9D Four Seasons® III...
Casablanca fan is not working!!
The controler board has gone out due to either a power surge, overheating or too much wattage in the lamps. There are two types of of controlers and both are subject to this kind of failure. Here's a troubleshooting link
http://www.lampdepot.com/service/intellitouch.htm
Dec 18, 2007 | Casablanca Fan 3245T Ceiling
Dryers Logo
129 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
