Question about Danby DKC645BLS Compact Beverage Cooler
Hotpoint mistral plus EE error code - Danby DKC645BLS Compact Beverage Cooler
Hotpoint mistral fridge freezer flashing EE. I don't know what it means. Both fridge and freezer still seem to be working.Do you know what needs to be done?
It's probably timed out on defrost, take everything out (borrow a neighbours or friends freezer and transfer food) switch off, do a thorough manual defrost and check all pipes etc are clean and clear, (and if you are able clean and vacuum around the back while it's off to get rid of all the dust on cooling coils)
it'll prob be ok after that.
May 08, 2014 | Refrigerators
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
Errorcode EE in display. Whats wrong?
E1 - Freezer thermistor open circuit.
E2 - Freezer thermistor short circuit.
E3 - Fridge thermistor open circuit.
E4 - Fridge thermistor short circuit.
E7 - Evaporator thermistor open circuit.
E8 - Evaporator thermistor short circuit.
E9 - Temperature set switch open circuit
EA - No feedback from Baffle
EB - Fridge Baffle motor operating continuously
EE - Defrost time out
This was the only code listing with an EE error code - which is a Hotpoint - so if your's isn't a Hotpoint it is probably incorrect.
If you do have a Hotpoint Refrigerator then either the defrost timer is not functioning correctly or your heater element is malfunctioning.
Jun 20, 2011 | Refrigerators
Freezer high temp light is on. So is fast freeze. It's been plugged in at least 24 hours but not freezing.
FREEZER HIGH TEMPERATURE WARNING LIGHT DOESN'T GO OUT.HOW TO CANCEL OR RESET?FOR HOTPOINT FFA74.THANK YOU
Mar 11, 2011 | Hotpoint FFA70 Bottom Freezer Refrigerator
HOTPOINT MISTRAL plus 8596 fridge E2 code
Go to this site: http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewforum&f=35
Type "Mistral Thermistor" into the search and help will be availible. You have a very common problem which is an easy fix in most cases. Good luck.
Mar 13, 2010 | Hotpoint Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
I have a 10 year old hotpoint mistral plus frost free fridge freezer whic keeps coming up with EA as an error message in the display screen. We have turned the appliance on and off which sometimes solves...
thanks for the question yes it very well could i would pull fridge away from the wall and clean the condenser if dirty makes all the difference especially in that heat thanks the appliance doc
Sep 24, 2008 | Hotpoint Refrigerators
Lookin for hotpoint mistral plus schematic diagram
i have a hotpoint mistral plus 8596 a couple of days ago it started defrosting and showing a diagram of a box with an arrow pointing to the top compartment next to it is a minus 13 degrees
Jun 28, 2008 | Refrigerators
My hotpoint mistral fridge/freezer is freezing very will, but ther fridge is not cooling. What could be wrong?
Hi. I had the same problem (funnily just as my warranty had run out) hotpoint wanted about £90 plus parts for a call out. You need to replace the Yellow thermistor in the freezer compartment (quite easy with a cross screwdriver and thin fingers). I got mine from Uk White Goods for about £20 they give advice too. Solved it instantly. Thanks HOTPOINT, wont be spending £600 with you again. Good Luck.
Jun 20, 2008 | Refrigerators
Danby DKC645BLS Compact Beverage Cooler Logo
88 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
