Question about Panasonic KX-TG4753B DECT 6.0 Plus Expandable Amplified Phones System with Talking Caller ID, Digital Answering System and Range Extender - 3 Handset Pack, KX-TG4753-B, KXTG-4753B, KXTG4753B, KX-TG4753-B
VM access entered and saved incorrect access code.....need to change to correst code
  • Official Brand Answer
  • 350 Answers
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voice mail access code and press [SAVE].
Posted on Apr 23, 2014
  • Harry Johnson
    Harry Johnson Jun 04, 2014
    Can't find save button
  • Harry Johnson
    Not working same message
Voicemail
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voicemail access code and press [SAVE].
Apr 22, 2014 | Panasonic KX-TG4753B DECT 6.0 Plus...
I AM NOT CELLPHONE SAVVY ! I have an LG CG225. If someone is calling me and I do not answer and they want to leave a message, what do I need to do? create a voicemail box so they can leave a message? ...
Issues of accessing/setting up VM on your mobile or Inquiries on accessing your VM using your mobile phone?
I can help you w/that.there are 3 ways on accessing your VM via your mobile phone:
1st:
Long press the number 1 key on your phone's keypad then it'll dial your VM number and would ask for a PIN if PIN is setup.
Follow recording instructions or voice prompts and key presses until you get to hear your voice messages.
2nd:
For some mobile phone service providers,dialing your own mobile number automatically transfers you to your VM.again,if PIN is set up?it'll ask you to enter it,if not it'll automatically proceed to your VM.
Follow recording instructions or voice prompts as well as correct key presses until you hear your voice messages.
3rd:
Almost all mobile phone service providers has a so called "Voice mail Access Number"
This number can be dialled and goes straight to VM.
Voice prompts might ask you to enter your mobile number following the star key or pound sign on your mobilephone keypad.
Voice prompts might also ask you to enter your VM PIN(if seup).
Just follow Voice prompts and you're good to go.
Hope this helps.
Thanks,
FixerDelta
Sep 15, 2011 | LG CG225 Cellular Phone
Hello I was wondering how to use the VM acess with my phone. I want to be able to call from a different number and listen to my messages how do I go about doing so
I have a similar model. You need to configure a remote access code on the phone. Then, when you call your phone, you enter the pin after your message starts.
(From the manual)
Using a touch-tone phone, you can call your phone number from outside and access the unit to listen to messages or change answering system settings. The unit's voice guidance prompts you to press certain dial keys to perform different operations.
Remote access code:
A 3-digit remote access code must be entered when operating the answering system remotely. This code prevents unauthorized parties from listening to your messages remotely. The default
setting is "111".
Important:
To prevent unauthorized access to this product, we recommend that you regularly change the remote code.
1 {MENU} {#} {3} {0} {6}
2 Enter the desired 3-digit remote
access code.
3 {SAVE} {OFF}
Below is a link to the manual. The remote access instructions are on page 35.
http://static.highspeedbackbone.net/pdf/KXTG4031-MUL.pdf
Mar 05, 2011 | Panasonic KX TG4031 Cordless Phone
I have gotten and hdtv from a friend and when I turn tv on it says I need a pin number to enter. I can not get a hold of them to get pin. Is there anyway I can override this in the settings program?
The Factory code number is 0 0 0 0 If the code has been changed, You can select to reset it using the Setup Code either under the channel blocking or setup code section.
Once there, Press 0 7 1 1
You will be given a message "INCORRECT ACCESS CODE" Press 0 7 1 1 on the remote again
Next, "enter your new access code" shows on screen.
Now you can enter a new 4 digit code. (write it down somewhere)
Dec 03, 2010 | Philips Televison & Video
I have a Asus P5VD2-VM SE and when i boot my pc this show me a message Chasis intruded System Halted someone can help to solve this problem
You will need to go into your system BIOS and disable the Chassis Intrusion Sensor. BIOS is accessed by pressing the "del" key during the initial POST screen (or when giant Asus logo is on the screen) .
Look through there and located and disable the chassis intrusion sensor. If you can't find it, reference your manual for the board. If you don't have one, one can be downloaded in PDF format from the Asus website.
Be careful when in the BIOS, changing anything to an incorrect value could render your system useless! Don't play with anything, unless you explicitly know what you are doing, and what the setting does...
Be sure to "Save and Exit" in order foe the changes to stick.
Dec 18, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Samsung iDCS 28D Voicemail Problems
If you have administrator access use the following steps to change the code:
Access the Administratin Main Menu and select 4 for mailbox programming.
Select the mailbox to program. Dial option code 1402. The current value will be played. To hear the current value press 1, to enter a new value press 2, to hear the range of valid values press 3. Press 2 to enter new value. Enter the access code for the mailbox. The value you entered is played back. Press1 to save or 2 to re-enter. Press 3 to exit without saving. Press # to exiit or hang up.
Aug 03, 2009 | Samsung DCS 12 Corded Phone
LUCENT PHONE 18D PARTNER/CAN'T GET VM MSSSAGES
Has someone changed the password by accident?
To figure this out for sure, we need to know the model of the voicemail.
When you dial into the voicemail to check messages, the recording voice comes on and says "Welcome to Partner......."
Fill in the blanks.
Sep 24, 2008 | Lucent PARTNER18 Corded Phone
I have a Samsung U520 and I accidentally activated NAM2. Now my phone does not work. When I try to deactivate NAM2 it asks for a password. Can you help? It needs a 4 digit code. It also states Initial...
hi sir have you done restore factory settings firstThe Nokia 2160 series hand portable CMT uses an EEPROM NAM that can be programmed directly from the standard user keypad. In order to access the
NAM, you must enter the special access code currently programmed into the
phone. Once the programming mode is accessed, NAM parameters are loaded
by entering them into the display and "storing" them to selected memory
locations. Be sure to obtain all parameters before proceeding.
EASY NAM PROGRAMMING
1. Turn on phone.
2. Enter the Easy NAM access code. Access code is: *#639#
3. Verify the display now reads "Cellular Number" and enter the 10 digit
MIN for the phone.
4. Press the softkey under the word "OK" in the display. If less than 10
digits are entered an error message will prompt you to reenter the
number.
5. Verify the display reads "Enter code" and enter the five digit SID
followed by four zeros. (Example 001750000 is a SID of 175 followed
by four zeros). An error message will display if an incorrect entry
is made. Do not add more than four zeros to the code.
Note: Change the Lock code by adding a pound sign and new lock code after
the code. (Example: 001750000#7788. Lock code = 7788).
Change the Language code by adding a pound sign (#) and new
language code after the code. (Example: 001750000#2. Language = 2)
Language Code: 0 (default) = English, 1 = French, 2 = Spanish,
3 = Portuguese
Change the Lock code and Language code by separating each set of
numbers by a pound sign. (Example: 001750000#7788#2). The SID =
00175, Lock code = 7788, Language = 2 (Spanish).
6. Press the softkey under the word "OK" in the display.
7. The display will tell you t
Sep 10, 2008 | Samsung Cell Phones
Lock access code
Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
Panasonic KX-TG4753B DECT 6.0 Plus Expandable Amplified Phones System with Talking Caller ID, Digital Answering System and Range Extender - 3 Handset Pack, KX-TG4753-B, KXTG-4753B, KXTG4753B, KX-TG4753-B Logo
119 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
