Question about Panasonic KX-TG4753B DECT 6.0 Plus Expandable Amplified Phones System with Talking Caller ID, Digital Answering System and Range Extender - 3 Handset Pack, KX-TG4753-B, KXTG-4753B, KXTG4753B, KX-TG4753-B
Voicemail put in wrong code ....need to input correct VM activation code
  • Official Brand Answer
  • 350 Answers
To erase your voice mail access number press the handset's [MENU] button, then press [#], [3], [3], [1], then press and hold the [CLEAR] button remove all entries seen. Then enter your voicemail access code and press [SAVE].
Posted on Apr 23, 2014
MOTOROLA WX416 HOW CAN I SET UP VOICEMAIL FOR THIS PHONE
I would suggest to contact your carrier, sometimes VM needs to be reset so you can have access. If you are activating it, make sure you've been provided with the correct number to dial.
Jun 13, 2014 | Motorola Cell Phones
How do I set up a private line v/m?
If others have voicemail on their phones then you know your system has a VM circuit card. To activate your voicemail you have to go to the individual who has admin rights to the voicemail. When they log in to their voicemail, they have manager options to reset passwords, activate or delete mailboxes, re-record the main greeting for your business, ect. Hopefully they keep a notebook with this info 'cause no one ever remembers all the steps. Also, make sure your ext is forward-no-answer to voicemail or it'll still just ring and ring. Usual code for FwdNA is 43, and 44 to cancel. Usual ext for voicemail is 200 or 300.
May 05, 2014 | NEC Dterm DTP 16D-1 Corded Phone
I switched my phone to another outlet in another room. I changed all the extensions to match the phone and the voicemail will not work. How do it program the voicemail button on my phone?
What happens when you dial 500? If that happens to be your VM access code, then try PROGRAM button and dial the following 90+500 STORE for 2-way record 91+500 (#ext optional) STORE for 2-way transfer to a mailbox, and 94+500 STORE for VM Transfer.
At the minimum you need VMT. I give the customer all 3 buttons.
Carl
Aug 30, 2010 | Panasonic KX-T7633 Corded Phone
It does not seem that my voicemail is working and i cannot remember my password for voicemail on iphone
Reset voicemail password from AT&T's automated system
Call 611 or 800-331-0500.
Enter the wireless number starting with area code .
Press 3 to "get help with voicemail."
Press 3 to reset your VM password.
Enter the Billing Zip code for the account.
After a few seconds, iPhone will display "Password Incorrect - Enter Voicemail Password."
Enter the last seven digits of the wireless phone number and tap OK.
Reset voicemail password from AT&T's website
NOTE: You must be registered and logged into myWireless Account to view this information.
From the myWireless Account home page, select Phone/Device then choose the Reset Voice Mail PIN link from the left column.
IMPORTANT: If there is more than one line on the account, make sure the correct wireless number is displayed in the Wireless Number list before selecting Reset Voice Mail PIN.
To reset the password for any of the lines on the account, choose a wireless number from the dropdown menu
Click Submit.
Aug 08, 2010 | Vtech 9009111 Cordless Phone
Why won't my voicemail password does not work
Enter the wireless number starting with area code.
Click Submit.
Jun 24, 2010 | Lands Phones
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Voicemail answering
Contact your mobile service provider's helpdesk for further assistance on activating your VM
Aug 28, 2008 | Motorola Mobility RAZR V3
DKT's wont ring from transfer
put an "H" after the extension in the voicemail, i.e. 200H, you have to put in your #656 #657 codes into the phones to integrate the voicemail. #656 91, ext of voicemail pilot, hold #657 92, ext of voicemail pilot, speed dial button (program one on the phone if it doesnt already have it), enter the number of seconds before the phone should forward to voicemail, i generally do 16, hold. that should fix that!
May 22, 2008 | Toshiba DKT-2010 Corded Phone
No input during Voicemail
Under 'Settings>Initial Setup>DTMF', if it is turned Off, change it to short or long and it might help.
Feb 24, 2008 | Motorola Mobility SLVR L7 Cellular Phone
I can't get the voicemail button to work
You are describing two different things. The "speaker 43" is the default code for Busy/No Anser Set. The correct syntax should be Speaker - 43 - 399 - Speaker. That should set CFWD B/NA to VM. Next, if you have a button programmed to call VM, it is probably a speed-dial or one-touch button. It would have to be programmed to dial 399. If that is not working, try calling VM (399) and make sure you can get into the box that way. If that works, but the button does not, press the Feature Key and the button for VM. It should display what is programmed for that button. If it needs to be changed to call VM, the syntax is: Feature - Redial - the button to program - "1" - "399" - Feature.
Feb 07, 2008 | NEC DTU 8D-2 Corded Phone
Panasonic KX-TG4753B DECT 6.0 Plus Expandable Amplified Phones System with Talking Caller ID, Digital Answering System and Range Extender - 3 Handset Pack, KX-TG4753-B, KXTG-4753B, KXTG4753B, KX-TG4753-B Logo
116 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
