Question about Whirlpool Refrigerators
Fridge to cold how do you change this - Whirlpool Refrigerators
  • 884 Answers
Is it a thermostat or a digital controller?
Posted on Apr 22, 2014
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
My Westinghouse RS662V fridge is not cold at all. I have turned the dial to full cold but it has made no difference. The freezer seems to be working OK. Could it be the thermostat in the fridge?
Yes you need to adjust the thermostst located inside the fridge compartment to change the temp. setting of the fridge.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 19, 2011 | Frigidaire FRT18G4A Top Freezer...
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
FREEZER IS COLD BUT NOT THE FRIDGE
If your freezer is cold and not the fridge, then your duct is frozen between them. This piece of junk is faulty and Sears has been out 5 times to fix it. They changed almoust all the parts in this fridge, but the problem is still there. Basicaly it does not defrost and the cold air can't get throught the duct. I have to defrost every week.
Apr 05, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Hotpoint ffa97p - the fridge is too cold and not responding to temperature changing
I'm assuming you're meaning that you reset the "cold control" in the refrigerator area and it is not responding. Try resetting the T stat in the freezer to between 2 1/2 and 3 1/2 and see if the unit continues to run on. If I have this the other way around, set the "cold control" the same as the T stat. The "cold control" is just a flapper door, it doesn't control the compressor only the T stat in the freezer does..
If the T stat is set as I said and the unit just keeps on running and never shuts down except to defrost, the T stat is bad and needs replaced.
There is a chance that the flapper door in the "cold control" is stuck wide open. Removing the cover and inspecting it might tell you if that's happening.
Jul 09, 2009 | Hotpoint Refrigerators
I have a fridge-freezer. the fridge is working fine but the freezer isn't very cold, its about the same temp as the fridge. I have changed the temp dial but this makes no difference.
I Have a fridge-freezer, the freezer is now filled with ice/frost on sides and top, as if it were not frost free. I addition, the fridge is not very cold
Jul 29, 2008 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
