Frigidaire Model # GLTF1670ASO dosent drain and makes horrible grinding noise.
From what I've found on the web, its a clogged drain pump/line. I'm the original purchaser & have kept up on the service contract since purchase. What repairs the contract will cover decreased every year. Wondering if this 'repair' would still be covered?
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
  • 126 Answers
SOURCE: DISHWASHER NOISE
A noise could be created by something getting down into the motor-pump assembly piece of glass, piece of bone, wire tie anything really. If this is the case and you can remove it before it causes further damage problem solved. At ten years old the problem may be the motor and or pump one thing to consider before putting money into it is disheashers average 7-10 years these days. Good Luck.
Posted on Jan 10, 2009
  • 3 Answers
SOURCE: FRIGIDAIRE MODEL #FTF2140ES2 FRONT LOAD
Did you check that the door lock switch is working?
See this thread:
http://www.applianceblog.com/mainforums/showthread.php?t=3124
If it's not the door-lock switch, you need a new speed control board.
Posted on Jan 19, 2009
dam14n
SOURCE: I have had a Samsung
do what i did, bought the part on Ebay 13 pounds can give u the link if you want or stiil have
Posted on Mar 05, 2009
  • 492 Answers
SOURCE: Main Burners completely rusted out; control knobs to burner...
Get replacement burners and preheat them once. Then paint them with high temp enamle paint to withstand the temps of the grill. The burners are regular untreated steel and not the stainless that one would expect. Painting them will prevent them from rusting out after 2 years. Just make sure you temper them once before you paint them as they will expand a little. Then paint them and enjoy!
Posted on May 06, 2009
Frigidaire front load washe makes an awful noise when water starts to drain
Yes normally remove the bottom panel and the pump is in the front on the right side. Some companies recommend you clean it every few months. Also some will let out water when you open it up, so have a towel ready.
Apr 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire GLTF1670ASO will not aggitate or spin. It will pump water in and out just wont spin.
Good Morning Carol, thank you for allowing me to assist you!
Often when your washer does not spin, it is because your appliance cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise as well? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your washer.
Dec 26, 2013 | Frigidaire GLTF1670A Front Load Washer
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
We recently purchased a new pump for our frigidaire gld4355rf dishwasher. The old one started making grinding noises. When we moved the dishwasher it had leaked due to a failure of an interior seal. Our...
it could be a crinkle in the drain pipe or slight block, the pumps do make some sounds from time to time. it some time can even be the rubber grommets were the pump sits.
Jun 19, 2017 | Frigidaire GLD4355RF Dishwasher
Which panel is removed on a Frigidaire Front Load Washer (Gallery, Hvy-Duty), Model# 417.39012891, as I need to inspect the pump and motor. It made grinding noises for 3min and since operates but fails to...
There must be two probabilities, clogged drain line or water pump. Check to see if there's something stuck inside the water pump or the drain hose connected to the pump. The pump is usually located at the bottom and towards the back of the washing machine .
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Thanks for contacting fixya.com
Jan 27, 2010 | Washing Machines
I have a LTF2940ES1 horrible noise and wet clothes
you ahve a clogged pump
remove the toe kick
the pump will be right there on the right
get a towel and disconnect the hoses
you will see a sqaure sump take that hose off
and clean it out
check to make sure there is nothing in the pump
reassemble and should be fine
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Loud grinding noise from unit when flushed like
take the pump out and haul it outside and spray it off and check in the bottom of the pump to make sure there isn't anything stuck in there. then shop vac the bottom of the tank out to make sure there isn't anything funky in there that would get clogged in the pump. sometimes the out let line gets clogged as well you can buy a drain king ( it's a rubber deal that hooks on the end of a hose and when you turn water on it swells up and sprays water out) then stick it in the outlet pipe and let her rip and see if it lets the water through.
Jul 28, 2009 | Saniflo & Saniplus& Macerator Pump
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
check you drain / drain pump... slow drain will cause a long time wash
Aug 05, 2008 | Frigidaire ATF6000ES Front Load Washer
My washer was in the process of draining after it had rinsed and the washer starting making a horrible grinding noise. What do you think the problem is?
Most likely a bad pump. Or something drained into the pump and was grinding in it. This is common, coins, sock etc..
May 01, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
