Question about Vehicle Parts & Accessories
Uconnect 430n no sound on phone - Vehicle Parts & Accessories
I can’t download my iPhone 8 phone book into my 2012 Grand Cherokee Uconnect.
Turn iPhone Bluetooth On:First you want to make sure that Bluetooth is functioning on your iPhone. Click on the Settings icon from the iPhone desktop. From the settings screen click General to show the iPhone General Settings as displayed in the below image. Notice you can see if Bluetooth is on or off from this screen. General Settings screen you can click on Bluetooth to configure the Bluetooth settings. On the Bluetooth screen shown below click to the left of Off to turn Bluetooth On.
  1. Begin Uconnect Setup:Now that Bluetooth is operational on the iPhone you can start the Uconnect process. Click the Uconnect button on the rear view mirror to begin. The voice from the Uconnect system will ask you to verbally select one of the options from the menu. Once Uconnect asks for your input say "Setup" to begin the process of syncing the iPhone.
  2. Start Phone Pairing:Once you say setup in the above step the Uconnect system will list numerous options available from the setup menu. One of these options is "Phone Pairing" so when the Uconnect system asks for the choices from the setup menu say "Phone Pairing".
  3. Pair a Phone:In the Phone Pairing menu you can modify current entries or begin pairing a new phone. After Uconnect lists all of the choices you should say "Pair a Phone" to begin the process of pairing the iPhone.
  4. Uconnect Pin Code:The first step in pairing a phone is setting the Bluetooth Pin Code that authorizes that phone to pair with the Uconnect system. When asked for the Pin Code say any four digit combination such as "1 - 2 - 3 - 4". Uconnect will repeat back the Pin Code so you can verify it has recorded properly.
  5. Connect iPhone To Uconnect:After you have set the Pin Code for the Uconnect system you need to view the iPhone's Bluetooth Settings screen which you can get to following the steps in Step 1 above. Before the Uconnect system shows up in Bluetooth the Bluetooth Settings screen will look similar to the below where you may have other Bluetooth devices showing or not.After a couple seconds the Uconnect system will display as "Hands Free" as shown in the below image. Notice it states that it is not yet paired,,,,,
  6. Click on the Hands Free device showing in the Bluetooth devices list above. This will open a new screen as shown in the below image that prompts you for the Pin Code you specified in Step 5.
    Enter the Pin Code and then click the Connect button in the top right corner of the above window. This will pair the iPhone with Uconnect and take you back to the Bluetooth devices screen where the Uconnect Hands Free device will now show Connected as shown in the below image.
    After the device is connected you will be prompted by the Uconnect voice again so proceed to the below steps.
  7. Phone Name & Priority: After connecting the iPhone you will then name the phone and set a priority between one and seven. Name the phone anything you would like and if this is your primary phone set the priority to one so this phone always connects at a higher priority than any other phone.
  8. Verify & Test:Now have a friend dial your cell phone while you are in your car to see if the music volume lowers and the Uconnect voice tells you there is an incoming call from a certain number. To make calls you can press the Uconnect button and follow the voice prompts.
  9. The Uconnect system is a great way to safely use your cell phone in the car.
Jan 13, 2018 | Cars & Trucks
When will UConnect be available with the iphone
Uconnect® Access for Chrysler, Dodge, FIAT , Jeep & Ram https://www.driveuconnect.com ... the next generation of in-vehicle connectivity system for Chrysler, Dodge, FIAT, Jeep & Ram ... There are several Uconnect ® Systems available ... iPhone and ...
  • Services and Apps from Uconnect® Access www.driveuconnect.com/features/uconnect_access UCONNECT ® Access. Learn how Uconnect ... Check out the features and applications that are available on your Uconnect ... iPhone and iPod are registered trademarks ...
  • Uconnect Access on the App Store - iTunes - Apple https://itunes.apple.com/us/app/uconnect-access/id550295151?mt=8
    • 1.7/5
    • 106 REVIEWS
    • FREE
    • LIFESTYLE
    2016-02-25 · Download Uconnect Access and enjoy it on your iPhone, iPad, and ... and if/when they will be available inside ... a compatible Uconnect 8.4 or ...
  • Iphone and Uconnect ' Apple Support Communities discussions.apple.com > iPhone > Using iPhone
    • 6 POSTS
    • FIRST POST: 2011-01-19
    2011-11-16 · ... Just an update to everyone experiencing connection issues with the iPhone 4 and the Chrysler Uconnect handsfree ... when it became available a couple ...
  • Set Up Your Phone for Voice Texting ' Uconnect ... - YouTube www.youtube.com/watch?v=R8SaEXTJiTE
    • BY UCONNECT®
    • 3 MIN
    • 50K VIEWS
    2013-12-23 · Video embedded · We'll show you how to set up your phone for Voice Texting† once ... ††Uconnect® Access is available only on equipped ... iPhone uConnect ...
    • 1.7/5
    • 106 REVIEWS
    • FREE
    • LIFESTYLE
    • 6 POSTS
    • BY UCONNECT®
    • 3 MIN
    • 50K VIEWS
  • May 14, 2016 | 2015 Jeep Cherokee
    How to connect my phone to my car system?
    Not all Chrysler products have uconnect; it may show the button on the radio, but if the uconnect system isn't installed you get the error you're getting; My Dodge Nitro is the same. You can buy the uconnect from the dealer or off of eBay (they run about $300, plus it has to be installed) Details about Dodge Chrysler Jeep Ram Hands Free Uconnect Kit OEM MOPAR
    May 24, 2015 | 2010 Chrysler 300 Touring
    How to enable address input on 430n uconnect while driving
    you can't, safety First!! pull over, when you stop you can do it!!
    distraction causes accidents!!!!!
    Dec 14, 2014 | 2014 Dodge Grand Caravan
    Uconnect 430n Will not pairing with my cell phone LG
    when you press the phone key do you hear the instruction
    Nov 19, 2013 | 2008-2013 Dodge Grand Caravan Designer...
    How do you hard reset the uconnect?
    My Uconnect is factory installed on my 2005 Dodge Truck. There are two control buttons on the rearview mirror for the uconnect. For a long time my uconnect would not fully function with my bluetooth phone and then lately it quite working most of the time. I did a bunch of research adn found this procedure to do a hard reset. After doing this the uconnect came back fully and all functions are working. I now this sounds stupid and you feel stupid doing it, but it did work for my vehicle.
    1- Turn on ignition w/doors closed
    2- Press both buttons on mirror for 15-20 seconds
    3- Shut off ignition
    4- Open door for 5-10 seconds
    5- Close door and restart car, Uconnect is now reset
    Dec 30, 2011 | Chrysler 300 Cars & Trucks
    Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
    I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
    http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
    Linking to UConnect – Required for First-time Use of Each Mobile Phone
    To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
    • Press the Phone icon button to begin
    • After the Ready prompt and subsequent beep, say Set Up Phone Pairing
    • When prompted, after the voice or beep, say Pair a Phone
    • You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
    • For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
    • You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
    Making a Phone Call
    • After the Ready prompt, say Dial
    • The system will prompt you to say the number you wish to dial
    Making a Phone Call Using Your UConnect Phonebook
    • After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
    Terminating a Phone Call
    To end a call in progress, press the Phone icon button. All calls in progress will
    be terminated.
    Phone Redial
    • After the Ready prompt, say Redial
    • The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
    Answering or Rejecting an Incoming Call - No Call Currently in Progress
    When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
    UCONNECT
    CHRYSLER GROUP TECHNOLOGY 17
    Dec 29, 2009 | 2005 Chrysler Pacifica
    Uconnect has stopped working completely. will not activiate.
    when i press the voice recognition button or the the phone button on my steering nothing works not even sound
    May 07, 2009 | 2006 Jeep Grand Cherokee
    Vehicle Parts & Accessories Logo
    29 people viewed this question
    Top Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
