Question about Crosley Audio Players & Recorders
Automatic stop on my turntable is no longer working, record just spins. Player is still in the first year of purchase. Any ideas? Thanks.
  • Crosley Master
  • 5,190 Answers
If it is still under warranty then it's best to get in touch with Crosley and get them to send an engineer out. It's perhaps an out of place switch or broken one.
Posted on Apr 27, 2014
5 Suggested Answers
  • 5 Answers
SOURCE: KD-67F fully automatic turntable--servo mechanism has suddenly stopped
I wish to help but I "NEED MORE INPUT". mgfr, model, type,ect.
Posted on Sep 18, 2008
johncaman
  • 201 Answers
SOURCE: Turntable will not turn (spin)
It would appear this is a belt drive turntable - here's a link to a site where you can order a replacement, although you may be able to find a cheaper one.
http://www.elexatelier.com/panasonic.htm
Hope this helps!
Posted on Mar 26, 2009
SOURCE: mid 70's sears turntable. plate will not spin.
take a soldiering iron and touch it to the metal in the center of the platter for a few seconds. this will heat up the grease on the inside and allow the platter to budge. should work fine afterwards. what happens is over time the grease hardens and locks everything up. applying some heat will loosen things up and get it running again
Posted on Sep 15, 2009
  • 4 Answers
SOURCE: Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Posted on Sep 20, 2010
Hi! I have a Pioneer PL 530 record player went on the fritZ!! Wont shut off?
Go to the vinylengine website. There are forums full of experienced users to help
Apr 07, 2015 | Pioneer Audio Players & Recorders
How to fix my thorens TD 158 turntable that doesn't start automatically?
If the device opertated after you moved something then the chances are there is a switch attatched to the device you moved. This might have either got bent out of place or broken completly. Generally removing the bottom cover will reveal the inner workings. Where you can look around for the switch etc.
Sep 12, 2014 | Thorens TD158 Turntable
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
A manual for a SANYO Record player - Model JXT4404K.
The old style turntable had one common problem, the grease would get hard over period of years grinding them to a halt. Remove center spindle, "anti-clockwise turn and pull up", now remove the c clip with a flat head screwdriver and remove pladder,"may take some wiggling to work it loose because the grease is like dried rubber" When pladder is removed be carefull in taking out the metal ring,"tiny ball bearings underneath, also! there is a large cogwheel with a small leaver," check to make sure it moves freely, now the tricky part, get rubbing alcohol Q-Tips and paper towels, remove the old grease from all parts, phono grease, fine grease, or general purpose will work, apply as you assemble. "note to find a manual would be next to impossible"
Apr 07, 2012 | Televison & Video
Cr79 tone arm stops too early
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
/uploads/images/cr79-tone-arm-stops-early-34896944-4-1.jpg
May 09, 2010 | Crosley 0187SST Turntable
Hope this helps!
Mar 25, 2009 | Panasonic Audio Players & Recorders
Sep 08, 2008 | Kenwood KD-291RC Turntable
Easrly stop
You will have to disengage the mechanical switch off lift. Pretty nice for an automatic turntable.
Keep me posted.
Oct 21, 2007 | Thorens TD-190 Turntable
108 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
