Question about Dual XDVD8181 Car Video Player
Gettin feed baq from the subwofer output still
My dual xdvd8181 in dash reciever is sendin feedback to my subwoofers through the subwoofer single out put.. when i used a Y spliter it send feed back to the subs but when i pull out one of the rcas from the y splitter the feedback stops. i tired to use a single rca from the single rca output to the amp and connected a y splitter (1 female 2 male). and i am still reciving feedback . any other ideas?
  • docny1984 Jun 22, 2009
    which is better using the ground loop isolator or a line driver? right now its connected thru the Rear audio output from the radio and it works fine but u can still her mids n highs thru the subs which is y i want to use the sub output.
    Novelist:
  • 131 Answers
#1 you need a ground loop isolator to put on the RCA cables. that should fix the problem... put one off the amp leading to the sub also cause that will also fix it these gorund loop isolators can be picked up at any electronic installer shop.., you might be able to find them at radio shack to but i would not buy those cause they dont work as well as the better ones, i would suggest any auto alarm radio installer shop.... hope this helps you...
Posted on Jun 20, 2009
2 Suggested Answers
  • 11 Answers
SOURCE: gettin feed baq from the subwofer output when Y splitter is attached to feed RCAs to the amp.
use a "y" adaptor on the amplifier inputs instead of the headunit output. In other words run a single rca line from the headunit to the amplifier but connect to a one female into two male y adaptor before connecting to the amplifier
Posted on May 21, 2009
How do I hook it up to my Surround sound reciever?
Hooking up a subwoofer is dependent upon what hookups are availble on the receiver and subwoofer. Does your receiver have a specific subwoofer output? If so, is it set of speaker-wire terminals, or is it an RCA jack? The Wharfedale can accomodate either one of these as an input. There are four speaker posts on the back of the subwoofer, and there is a single RCA jack input.
May 16, 2010 | Wharfedale Topaz SW-10 Subwoofer
2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
Oct 03, 2009 | Pioneer DEH-P690UB CD Player
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Jul 15, 2009 | Wave Audio CS801 Speaker
Gettin feed baq from the subwofer output when Y splitter is attached to feed RCAs to the amp.
May 20, 2009 | Dual XDVD8181 Car Video Player
JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
Feb 20, 2009 | Pioneer VSX-D511 Receiver
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
Dual XDVD8181 Car Video Player Logo
110 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
