Question about Sylvania SDVD7015 7 in Portable DVD Player
Repair for DVD player
When i put a dvd in the player, it says loading and you can hear it spinning. If i push down of the cover, then it starts to play. It's like the cover isn't tight enough.
techman
  • 3130 Answers
SOURCE: sylvaniadvc 865f dvdplayer/vcr cannot get the dvd to play
First try to clean the laser lens with a lens cleaning disc. Next if that doesent work clean it manually
Posted on Aug 24, 2006
  • 2973 Answers
SOURCE: My DVD is stuck in the DVD player and will not come out .
There is always a small pin hole in the DVD tray. Insert a pin through it and press lightly when you feel the resistance. Just slightly. It would unlock the tray lock and the tray would open.
Posted on Apr 01, 2010
  • 7 Answers
SOURCE: The dvd player does not turn on. While being
Power surge most likely.
Posted on Jan 07, 2011
gopakumarg43
  • 74251 Answers
SOURCE: hi,my portable dvd player just
Hello
There is a switch which activates when you shut the lid. The lid has a small powt in its edge which in turn activates this switch inside the set. In your set, the switch inside is struck and does nor release when you open the lid. look keenly whether there is andy foreign material has been made it locked. OK.
Posted on Jun 26, 2011
  • 51 Answers
SOURCE: how to play dvd player on this tv
This may help
http://www.sylvaniaconsumerelectronics.com/support/connection.php
Posted on Apr 07, 2012
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My Mintek 1770 dvd player will not load the disc because when the lid goes down the little plastic pointer does not properly engage the button that starts the DVD spinning when the lid is closed. If I try...
if you look on the top cover inside you should see a round plate that sit on the DVD when you close the cover if this plate press hard or loss it will not have the correct speed in this plate there is a clutch see if its not to lose
hope it will help
Aug 24, 2010 | Mintek MDP-1770 Portable DVD Player
I have a Polaroid pdm-08228bd that whenever we put
when you open the cover for the DVD you will see the laser ..its a small lens like device mounted on a spring like assembly .. you can manually clean that laser with a soft paper towell soaked in eyeglass lens cleaning solution .. dont spray the solution on the laser directly .. make sure the spindle spins freely in the center where the disk mounts ... when you close the lid and turn power on you should be able to hear the disk spin .. if you can hear it spin and hear some clicking but still wont play then you likely have a worn out laser .. unfortunately the cost of installing a new laser is often greater than the cost of a new DVD player ...
here are a few models that might be worth looking at ..
http://www.consumersearch.com/portable-dvd-players?gclid=CITHuImPjaICFchD5godvmnzUw&ef_id=1953:3:s_241d3be5bdd1ae954a703c1c03b3e8bb_3674119072:TAxys0NIYWYAAGzz04MAAATA:20100607041651
Jun 07, 2010 | Polaroid PDM-0723 Portable DVD Player
Akai DVDP5851 dvd player. 'Loading' but disc doesn't play
the lens of dvd player is weak so replace the lens it will start working or use the lens cleaner it will hep you to check the lens either it is ok or not
Apr 29, 2010 | Akai DVDP5851 DVD Player
I load the CD put I don't hear it spinning at all
No it isn't, because your switch isn't tripping when you close the DVD. Try holding the lid down with your hand and listen for spin. If your DVD starts spinning you will need to locate the plastic pin protruding from your lid and extend it with superglue and a piece of cardboard. This will make up for the warp in your lid, and allow the switch to close.
Mar 09, 2010 | Mintek MDP-1810 Portable DVD Player
Audiovox D1998 Portable DVD Player will not load DVD
you need to clean the disc and make sure it fits in wright if that dose not work try another disc.
Sep 15, 2009 | Audiovox D1917
My Sony DVP-cx995v stopped playing DVD's
I had the same "Cannot play" problem - happened suddenly, I don't think I was doing anything unruly at the time.
After checking repair (exchange) prices in excess of $250 from Sony, I decided to open the cover to see if I could see anything wrong - normally a futile exercise with electronics except that in the past I have cleared errant disks that have lodged themselves near the drive/player at the rear of the library.
Upon opening and watching the library try to load and play I noticed the drive itself was not spinning the disk once loaded. It would sit for awhile, thinking about it I'm sure, then would unload and load the next dvd, again failing to spin.
I thought okay, maybe try to spin the dvd while in the player to see if it's jammed or otherwise hard to turn. It was not hard to turn and spun freely. In fact, when I put my finger through the hole at the exposed side of the player at the hub to spin the dvd, clockwise, it suddenly started to spin - and play!
I put the whole thing back together to test and all seems to be working fine at this point. Not sure what would cause the motor to stop spinning and remain in that state through poweroff/on cycles etc. but I'm sure this is not the last time I will have trouble of this kind.
I would note that when replacing the library back in its home on the shelf, be careful not to tip the library, especially toward the player area because the disks will spill out of the carousel near the player and become jammed when you power it on and attempt to load. A final tip of the library away from the player area may clear this if you hear the disks rolling out of their slots and you don't want to open the top again (it's a darned heavy box when fully loaded).
Jan 05, 2009 | Sony DVP-CX995V Multi-disc DVD Player
Audiovox D1020 DVD player
I opened up the dvd player & determined that the dvd was not spinning or took too long to start spinning, so the reader stopped. It looks like the arm that holds the dvd against the motor mount that turns it does not have enough strength to push against the dvd so that the motor mount does not spin without making the dvd spin with it.
For now, I'm using a small wooden prod inserted into the dvd slot to gently nudge the dvd to get it spinning. When the time comes that that doesn't work, I'll try to adjust the arm, but that's a last resort before I buy a new player.
Sep 18, 2008 | Audiovox D1020 Car DVD Player
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD player problem
you allneed to make sure the disc is spinning in the player you should hear it whirr as ut builds speed listen closely to it and keep a hand on it to feel when the disk quits if it starts. its supposed to spin v ery fast do you think you could tell by the sound of it if its spinning fast. some times they make a clicking noise because the drive mounts have slid down in the case and allows the disk to rub or tap the case. please let me know what you find out. this is for all three problems. let me know the results so i can further advise you.
Nov 26, 2007 | Cyberhome CH-DVD 300 DVD Player
Sylvania SDVD7015 7 in Portable DVD Player Logo
18 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
