Question about Clothing
Can I get for good price
Can I get wholesale prices on underwear and sock and tees for my store
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clothing Master
  • 575 Answers
You can try to talk to Amazon seller
Posted on Apr 22, 2017
    Master:
  • 519 Answers
You can try to talk to Amazon seller, maybe you can get a good price
Amazon com YELLWWORS 2 Pack 10ft Extra Long Denim braided Charging Cable...
Posted on Dec 24, 2016
    New Friend:
  • 41 Answers
Hi Charles, yes you can get wholesale prices and with the global economy there are many options available to you. www.aliexpress.com is a good place to start as it www.alibaba.com
Posted on May 26, 2014
My washing go out of balance on spin allthe time
If it happens all the time, you need a service engineer. It will be either broken balance springs or worn out shock absorbers, or both.
Normally it is bad loading or washing single large bulky items. If it doesn't is with socks, underwear and tee-shirts, then there is a fault.
Nov 16, 2016 | Washing Machines
Tip
You really rock!!!! I have had the Whirlpool people out 9 times in 3 years at a...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jun 07, 2010 | Washing Machines
What are best deals and Wholesale Prices Of Computer And Laptop?
Compare Prices
Compare millions of prices from the most trusted stores and auctions!
Jul 03, 2015 | Computers & Internet
Is ralph lauren make underwear and socks?
Yes! he definately does: http://www.ralphlauren.com/family/index.jsp?categoryId=2877584
Jan 10, 2013 | Clothing
I'm looking for matching Hallo kitty underwear and socks
This is what I found, I'm sure they have socks too but I'm not sure they match...
http://www.bhs.co.uk/webapp/wcs/stores/servlet/ProductDisplay?beginIndex=1&viewAllFlag=&catalogId=34096&storeId=13077&productId=6587682&langId=-1&sort_field=Relevance&categoryId=471126&parent_categoryId=471108&pageSize=201
I use a galaxy y smartphone i tried installing UC WEB browser,which was succesfull but i am not able to browse the web on it it just keeps failing on mobile carrier bt works fine on wifi
I get android 2.3 smart phone few days ago on a a wholesale online store ,I think that is a good smartphone that has good quality and reasonable price .You can choose the latest, quality and competitive-priced cellohones that they provide different will make you satisfied,.Hope these to be useful for you. good luck.
Jun 03, 2012 | Android Apps
A new cell phone
u can buy the nokia or sony if u want to buy the phone go to ebay and buy
May 22, 2009 | Nokia N73 Cellular Phone
Clothing Logo
1,224 people viewed this question
Top Clothing Experts
ray gallant
Da Doc
Are you a Clothing Expert? Answer questions, earn points and help others
