Question about Acer Computers & Internet
Wher is iMy google calender it's moved from Apps google calendar sign in
AsusDRW 24B5ST
    Problem Solver:
  • 5 Answers
Ok
1. Google search and download calander.
Posted on Apr 27, 2014
How do i add gmail calender in iphone
If you are iPhone users with iOS 7 or later installed, you can follow the steps below to sync Gmail calendars to iPhone.
1. Tap Settings > Mails, Contacts, Calendars > Add Account, and add Gmail into your iPhone.
2. Then tap Calendars to ON. Go back to Home screen, and launch Calendars App, then the Gmail calendars will be synced to your iPhone.
add-gmail-calender-in-iphone-oxaxc0rwhkhzilrwacqreyis-1-0.png http://www.leawo.org/tutorial/how-to-sync-gmail-contacts-to-iphone.html
Aug 24, 2016 | Google Computers & Internet
Google Calendar Access
Try checking this link for this concern http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=99358 , you can find there the steps to setup the Google calendar..
Hope that helps.........
Oct 02, 2008 | Google Gmail
Bring up my month calendar that' on my galaxy s3 on the computer so i can copy the information
Hi is it the S planner app you talk about?
I found that S Planner uses several calendars. You can have one in the samsungaccount. Open Splanner app. In menu press MENU button (left bottom), select calendars. Now you have a whole list. facebook, gmail, samsung. I started initially using (and adding things) to my samsung calendar. But I soon found that the samsung was difficult to use. So I changed to using the gamil calendar and reentered birthdays etc. Now with the gmail calendar it is synced at all times and you can access and edit your calendar in PC when logging in to gmail, you select calendar. In to right corner you find a small grey with nine little blocks. This is apps. In here you go to calendar. Hope it helps. Stop using the Samsung account calendar! I guess if you want to access this on pc you must log into your samsung account on pc. I didnt because I switched to gmail calender. Best regards
Lisbeth
Mar 01, 2015 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
I dont know my samsung Gt-19300 imei
Samsung Galaxy S3 GT i9300: How to retrieve IMEI#:
To retrieve your IMEI #.. Here's several ways of doing it:
(1) The easiest way, on the phone call dial pad enter:
*#06#
(2) If you had cellular service on that device. Call your Service Provider for your IMEI #. They will have this available in their own records.
(3) If the phone was not activated on a cellular service yet, contact the Seller who sold it to you.. Many Sellers write down the IMEI # for their records.
(4) It could be on a label on the original box it came in..
(5) The other way to retrieve the IMEI # of that cell phone is to check your Google Account.. As long as you had set up your Google/Gmail account on your phone.
Here's how to do it:
On a computer internet browser, go to:
http://google.com/settings
Sign-in to your Google account and then select the "Expand All" tab which will list all your devices connected to your Google account and all of their IMEI #'s
Dec 29, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Find a google calendar and sync to android devis\
Simply enter your Google account information into your android calender, go to settings, accounts, google, click sync all...
Apr 13, 2014 | Computers & Internet
Forgot password droid 4
Unfortunatley you will have to perform a factory reset. As long as you have a google account synched to your device, contacts, camera, calender, etc. will be re-synched to the device after you run the initial setup again as long as you sign in with the same google account. any apps that you have paid for you can get back after the reset.
Mar 20, 2014 | Motorola Mobility Droid RAZR HD
Message keeps popping up....
Frequently, this happens do to a problem with your contacts or calender. It's a problem with syncing those items with your Google account or PC. If the problem is with one of these, you should try to manually synch the calender and contacts. (Go to Settings > Accounts & Sync > (Go to Gmail account). You'll see the option to sync the Calender, Contacts and Gmail. Select each one to manually attempt to sync the files. Determine which item is providing the error; you will need to clear the data from the problem application. (Note: back up your contacts first. Use the People > Menu > Import/Export > Export to SD card option if you can.)
Next un-check the sync option for the problem app (calender or contacts) under the Google Account > Accounts. Then go to Settings > Apps > Manage Apps > All and clear the data and cache for the problem app. (The contacts may be under the Running list.) Then re-enable the sync feature. If the calender is causing the error, you may need to erase and re-create your recurring item.
For some scrolling down to the Google Frameworks service in the Manage App > Downloads (or Running) menu then clearing that data. Then chose the "force stop" works to fix the problem. (However, this can put your cell phone into a factory reset state and may cause other problems.)
You will need to turn the cell phone off and back on before re-enabling the sync.
I hope this helps.
Jan 09, 2014 | Samsung Galaxy GT-S5570
I have switched from IPAQ with Chapura to HTC w/ Windows. I have multiple calendars on Outlook and want to have them also on the HTC. My tech team told me that I can handle via Catagories, but it doesn't...
you may be able to use google calendars to link your outlook with, google calendar will color code your different calendars. if you are successful with that, then google has a program called google sync that you can use on your windows mobile phone. the steps for setting up your windows mobile phone is on the google sync site. you will use activsync on the windows mobile phone to insert your google credentials and then it will wirelessly sync your contacts/calendar from your phone with gmail/google calender
Nov 05, 2009 | HTC Touch P3450 Smartphone
Yahoo Calendar code 41
Sometimes I get that message but it usually goes away either when I refresh or very shortly I try again and it works. Hopefully your calendar is already working for you.
Mar 13, 2009 | Microsoft Computers & Internet
Moving Calendar dates from old phone to new phone
You can choose to send the entries via bluetooth in the calender.
Mar 17, 2008 | Cell Phones
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
