Question about Blenders
Troubleshooting nutribullet My nutribullet is plugged in and I pushed the cup into place in the base. Nothing happened. I have only used this three times and haven't had a problem. I tried another outlet, just in case the first outlet wasn't working. The motor still won't start.
Cup wont press down onto motor grips
Have you got something caught in it? Is it still under warranty? I am guessing but the mechanism inside the base should drop when you push to twist. Check is this is happening. If not then that may be the problem
Apr 21, 2015 | Magic Bullet Nutribullet Blender
I went to plug in my bullet and it won't turn on.
There's 3 tabs on the inside of the base that get pushed down when you push the cup in. Two of them have switches on them, sometimes they can break. Make sure they are being pushed down. If not, it could be one of the switches inside.
Apr 09, 2015 | Magic Bullet Nutribullet Blender
I bought a nutribullet less than a yr and it just stop working it does not smokeor smells like it burned.
ck where the cup goes onto the top make sure it turns on to lock on that is were the switch is to turn it on
Jan 20, 2015 | Magic Bullet Nutribullet Blender
Ridges inside base catch cup so it won't seat properly
The cup rim had gotten into it while stored. It looked like part of the base. As another user noted, the inside of the base is flat, with no ridges.
Sep 17, 2014 | Magic Bullet Nutribullet Blender
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Sep 11, 2014 | Magic Bullet Nutribullet Blender
How to open nutribullet jar stuck on blade base?
try heating the jar with hot water before removing it
Jun 30, 2014 | Magic Bullet Nutribullet Blender
Nutribullet manual
www.nutriliving.com/forums/were-listening/nutribullet-support
Jun 15, 2014 | Blenders
Magic bullet nutribullet is on base and does not want to start when I twist
There are 3 white plastic posts on the top inside of the power base. Push these downward to loosen it. Its full of sticky stuff because of overfilling. You can also put some oil on it. Buy parts from ebay and amazon seller amazingearth.
Mar 09, 2014 | Magic Bullet Nutribullet Blender
Gasket came out from around the blade on my new nutribullet and will not go back into place. How do I get it back on?
have to disassemble the base and manually re-install it..may need clear silicone to seal/hold it in place..
Mar 04, 2014 | Blenders
Cup wont lock into place
I am having the same problem and have only been using mine for a week!!
Jan 08, 2014 | Magic Bullet Nutribullet Blender
Blenders Logo
159 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
