Question about Bosch Dishwashers
Sgu 5602 Water inlet not activated
  • Bosch Master
  • 3,247 Answers
If you are able to select wash programs and the panel is responding then most likely the water inlet valve is faulty and needs replacement. I am assuming you are hearing a click but no water comes through. Also check the inlet water tap under kitchen sink.
The valve for your dishwasher should be like this
http://www.bosch-home.co.uk/store/product/Valveaquastop/00263789
However, the problem can be more complicated if your dishwasher uses water softener unit. Will need the full model number to verify this. For example SGU5602/xx
You can also view all the parts at this site http://www.bosch-home.com/us/store/spareparts/Dishwashers60cmbuiltinbuiltunder/SGU5602/03
Posted on Apr 23, 2014
No water coming out of valve in back of refridgerator when button is pushed\
Warning you may have to test electrical circuits with the power live .Is there water flowing into the connection on the unit ? If not look for shutoffs or a crimped supply line. If you have water pressure You will need to know how to an electrical tester or multi meter to test the water inlet valve. You can test for voltage on the solonoid while someone activates the switch for water If you have voltage when the switch is activated the inlet valve could be bad or the tubing feeding the dispenser is frozen or pinched you can loosen the water line that goes to the refrigerator to check for flow with switch activated If you have no flow replace inlet valve if you have flow check that the waterline is not frozen crimped or pinched.If no voltage appeared during the voltage test , Test the switch and wiring and repair as necessary.
Aug 02, 2014 | GE GSL25JFXLB (250 cu ft) Side by Side...
My simpson eziset 550 5.5kg will go through the washing cycle but will not rinse or drain and makes a continuous beeping sound how can I fix this problem?
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, If not check the drain valve and the voltage at the time of the cycle. Now at the time of the rinse the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Feb 07, 2013 | Washing Machines
My washer WA7584c1 is realising water when its on a processes of wahing?
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Jan 19, 2013 | Washing Machines
Spin problems
Jan 14, 2013 | Haier Washing Machines
Machine taking in water but stops after about ten seconds
Jan 14, 2013 | Zanussi Washing Machines
Washer wont agate
Jan 12, 2013 | Washing Machines
Whirlpool washingmachine aweo 9002 was/and is my problem.
I have a tricity bendix dh101 stopped working cold water not going in to manchaine many thanks if u can help
Possible that the INLET valve is faulty /clogged or there is no voltage to switch ON the inlet valve.
So measure the voltage at the inlet valve, also check if the inlet filter is clogged.
Check the water pressure at the inlet to confirm, remove the line from the inlet valve and confirm the flow when activated.
Aug 08, 2011 | Tricity Bendix Dishwashers
Our dishwasher does not seem to be getting any
The anti flood device (polystireene plate and micro switch) when activated due to water leak on floor of washer, shuts off the water inlet valve and puts the drain pump on. Determine if any water has leaked to the floor of the washer and is activating this switch. Dry the water and rectify any leak. The water inlet valve (solinoid) could also be faulty although this is not common.
Jan 18, 2010 | Dishwashers
Water dispencer in fridge not working nut ice
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
If that's not it disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad.
Jul 10, 2009 | Jenn-Air JCB2280HES Side by Side...
Dishwashers Logo
126 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
