Question about SimpleTech (sti-u2f36/250) 250 GB Hard Drive
Need software for simple tech 96300-40001
The simple tech software is not working
QUICKBOOKS 2007 TRIAL
Premier 2007 (General, Contractor, Manufacturing & Wholesale, Nonprofit, Professional Services, Retail)
Pro 2007
Enterprise Solutions v7.0
Simple Start 2007
Mac 2007
Need help installing after you download?
http://support.quickbooks.intuit.com/support/Static/INF12417.html
for more help call 1-855-383-7236 or visitQuickBooks Tech Support
May 11, 2014 | Intuit QuickBooks Pro 2007 Full Version...
Need quickbooks simple start 2010 download
You can downloaded an Updated version on your new Window 7 PC and then back up our previous files and importing them into the new QuickBooks program. For QuickBooks Download follow http://support.quickbooks.intuit.com/support/Static/INF12417.html and read installation help below before. If need help during in any technical solution follow Intuit Tech Support .
Apr 22, 2014 | Intuit QuickBooks Simple Start Edition...
Serial number
If you purchase the product then QuickBook serial no came with software. If need any more help get Intuit official support http://support.quickbooks.intuit.com/support/ and need any guidance for any solution follow Intuit Tech Support .
Jan 23, 2014 | Intuit QuickBooks Simple Start Edition...
My camera doesn't work with my computer
HI IM A RETIRED TECH, 1/ CHECK YOUR CABLE..SIMPLE BUT CHECK IT,
2/ SOFTWARE IS REQUIRED TO RUN THIS TASK, REMOVE IT AND RELOAD THE SOFTWARE, TRY THAT, AS I DONT KNOW YOUR HARDWARE YOU NEED SPACE/ MEMORY/AND CHECK YOUR MANUAL CARFULLY AND FOLLOW INSTRUCTIONS, HOPE THIS HELPS
Aug 02, 2012 | Video Cameras
How can I lock my simple tech hard drive from other users
there are many softwares that you can use. Tryb the following link. it's very user friendly.
http://www.newsoftwares.net/folderlock/
Mar 24, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
Oct 20, 2008 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
Does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Unable to download video from 8cm disc to PC
Can I ask what software is giving you this message?
Try this, insert your disk, double click on My Computer, then right click on your DVD drive and select Open. Do you see anything at all?
Dec 09, 2007 | Sharp Viewcam VL-Z1U Mini DV Digital...
Graph plotting
Dear rachana, In MS word 2007 you can go to Insert then there are multiple graph patterns given in it, like column, pie and scatter chart. Just put your values in it and it click ok, you will get the chart on worksheet. Its that simple.
Please press fixya if that was helpful.
Nov 29, 2007 | Computers & Internet
SimpleTech (sti-u2f36/250) 250 GB Hard Drive Logo
316 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
