Question about Asko T701 Electric Dryer
Ge dryer not tumbling
Not tumbling
    New Friend:
    Problem Solver:
  • 11 Answers
If you can hear the motor running, then you have a broken
Posted on Apr 23, 2014
Dryer stops tumbling, but heating element stays on
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat
May 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer gets warm and tumbles but clothes do not dry. Is there a fan assembly that is not working?
Since this is an electric dryer, if it gets warm, that usually means that the heater is working. The drum tumbles so that tells you the motor is working. Which leaves a few things. Clogged exhaust vents could cause it, and even a dirty lint trap could effect it. But on your GE I would most suspect either the thermostat that is located in the dryer blower unit (http://www.searspartsdirect.com/partsdirect/part-number/GE-Parts/Dryer-Parts/WE04X10028/0026/363/Model-DVL223EB6WW/0432/0151200?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=G0407006&diagramPageId=00004&productTypeId=0151200&searchModelNumber=DVL223EB6WW&subCompDesc=Motor&brandDesc=GE&modelDesc=ELECTRIC-DRYER&blt=11) or the blower unit itself. Now remember that the blower is driven by the motor (which also turns your drum - so the thermostat becomes the most likely suspect. It is 1315 on the parts breakdown to give you an indication of where it is located.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DVL223EB6WW/0432/0151200/G0407006/00004
Aug 03, 2011 | GE DVL223EBWW Electric Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
My dryer wont tumble
Your belt is not installed correctly. The weight of the clothes is making it slip.
Jun 30, 2009 | Maytag SDE2606 Electric Dryer
GE Dryer makes deep sounds when hot and tumbling
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
wrytrtrs
Jan 28, 2009 | General Electric GE 7 0 Cu Ft Super...
Asko T701 Electric Dryer Logo
26 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
