Question about Polaris Garden
My 1999 polaris 400 xpolorer 400 doesnt start with the starter only the pull rope. I installed a new starter and stator.
  • 38 Answers
SOURCE: When trying to start our 1998 Polaris Explorer ATV
your battery is going bad you always have it check by going to battery shop or garage and get them to run a lod test
Posted on Oct 02, 2009
  • 3 Answers
SOURCE: I HAVE A 1999 POLARIS EXPL 400 THAT WILL NOT GO
The problem sounds like your speedometer. I just fixed mine with the following solution.
Pull the 6 pin plug from your speedometer, On the plug, short the brown wire with the Brown/White wire. Tape it up and do not place back on your speedometer.
Your speedometer will not work but your AWD will.
Let me know if this helps
Joe
Posted on Jan 18, 2010
Testimonial: "Yes it worked got to go fishing thanks have a great Day !!!"
  • 18 Answers
SOURCE: i have changed my stator and cdi box on a 1999
According to my polaris manual, is says'' The regulator / rectifier is tested by process of elimination ( when all other possable causesof chargingsystem failurehave been checkedand eliminated, the rectifier is defective). I had to replace my stator and then had a simular problem as you have and it was that the ignition pulse coil wasn't properly guaged ( sometimes the metal retainer will allow slight movement) You might want to also check the coil resistance 0.3 to 0.5 ohms the coil secondary resistance spark plug cap installed 11,300 ohms spark plug cap removed6300 ohms. Hope this helps out. Good luck
Posted on Mar 27, 2010
  • 18 Answers
SOURCE: 1999 Polaris 500 ATV: Battery went shot. Just use
I had a simular problem with my 99 sportsman 500 and it turned out to be my pulse coil somehow became out of alinement. The pulse coil air gap should be between0.016 to 0.040 inch, But I would start by checking the coil it should read 0.3 to 0.5 ohms. Good luck and hope this helps
mcgyver331
  • 11 Answers
SOURCE: POLARIS 2001 325 TRAIL BOSS WERE IS THE STARTER
The engine kill switch on the left handlebar has an up position as well push that up and the starter will go.
Posted on Aug 24, 2010
400 polaris xplorer 4x4
Hey Randy,
Sounds like the battery needs to be replaced. Take the battery to O'Reilly, Autozone, Advance Auto and have the CCA, (Cold Cranking Amps) checked..(load test).. this will tell you whether the battery is good or not. When you get a new battery.. make sure the connections are clean and tight..put a little heavy grease on the connections to prevent corrosion. This should fix your problem.
Aug 29, 2017 | Polaris ATV
How do i pull start my 1998 Polaris 400
you pull the pull rope until it startes
Dec 07, 2011 | Polaris ATV
I have a 2003 Polaris 400 sportsman. probel is witht he starter and recoil. When yiou turn the key, the starter just makes a fast whining sound ( like it doesn't engage), in addtion, the recoil is...
its the bendix stuck on the flywheel,take off recoil cover and inspect bendix teeth, and operation, you will have to remove right hand footwell to get recoil cover off
Dec 21, 2010 | Polaris ATV
No spark could it be the coil
polaris factory stator (not starter, STATOR) are junk and are prone to failure. The coil can be checked by checking the resistance with an ohm meter. To check the stator, follow the wire harness coming out of the engine by the recoil rope. Follow them to where they connect to the CDI, coil, and rectifier (should be around the headlight area, under the plastic. Remove the pair of three wires in one connector (should be a green, a red, and a red/black). Check for ohms between each. If any show open, the stator is gone. To replace, you have to remove the recoil cover, flywheel, then the stator coil comes out with four screws.
Dec 03, 2010 | Polaris ATV
I have changed my stator and cdi box on a 1999 polaris xplorer 400 i have one spark at the begin of starting but its not contounious how do i test the regulator rectifier
Mar 26, 2010 | Polaris ATV
The atv{pollaris 400} will start with the pull pope but it the starter runs good but the engine never starts
sounds like the stator to me. get an ohm meter and check the output on the stator wires coming from the crankcase
Feb 24, 2010 | Polaris ATV
Fixing a Polaris Indy 400 snowmobile pull cord - I took it apart and cant get it back together
hello usually on any pull start, you have to wind the spring inside,the cover, on my atv i put the rope on the pulley burn the end of the rope and make a point on the end of the rope. put the pulley back in the case, turn the pulley backwards untill you get a lot of tension on pulley and turn the case up wright where you can see hole where rope comes out, turn pulley untill you see end of rope through hole. fish rope out with a pair of tweezers or a pair of themostats
Feb 06, 2010 | Polaris New Genuine Polaris Snowmobile...
Garden Logo
35 people viewed this question
Top Polaris Garden Experts
Paul Bade
john h
Are you a Polaris Garden Expert? Answer questions, earn points and help others
