Question about Gentec Portable Small Torch Oxy/Propane Kit
Manual for Gentec Oxy Propane torch with regulator
Manual
  • Jane Dreis
    Jane Dreis Apr 24, 2014
    I bought a small torch just before dismantling my art studio to remodel. That was only supposed to be a 2-3 month project, but it took a whole year. I fear I do not remember how to safely turn on and off the tanks, and switch out empty tanks. We're talking propane. This can explode. The torch and regulators did NOT come with a manual. I am surprised, given the hazards. I'd like a manual to refer to regularly.
Propane blue flame heater. Why does it flare/pop when the flame shuts off.Lights well ,flame is nice and blue but when the thermostat shuts it off it pops.?
Its just a small explosion from the mixture of propane and the oxygen rite at the time it gets to the percentage of O2-ph. Its safe. An oxy/acetlene set up does the same thing when the mix is to high in O2.
Feb 07, 2015 | Blue Flame Heating & Cooling
How to detect a vacuum leak
The easiest way is to use an accelerant and spray the suspected lines while the engine is running. Your engine will rev up when the leak is hit by the spray. You can use ether, commonly found as a starting aid for diesel engines,a lot of garages use the oxy/acetalyne torch, you could use a propane torch.
Nov 16, 2013 | 2001 Ford F150 Styleside SuperCrew
Hi there, despite brand new torch, brand new regulators and gas tanks, I cannot get a decent hot flame on my oxyacetylene torch, and what flame I can get, goes out within seconds of heating a...
Hi:
If your flame goes out check the following:a) check your acetylene and oxygen pressure, for this kind of job acetylene should be at 4 psi and oxygen at 10.b) Check you're using the right type of nozzle for the job and this nozzle is clean.
Apr 04, 2011 | Smith 23-1001C OXY/ACETYLENE LITTLE TORCH...
My bleeders are rusted on my car how do i bleed them
Brush the bleeders with DOT 3 Brake fluid and let soak in for 24 hours, or so.
The Brake fluid should free up the rust.
Also, could try to heat it up a little with a propane or Mapp gas torch, or Oxy Acetylene (ideally), to free up the bleeder screw.
Replace if necessary.
Jan 11, 2011 | 1991 Ford Taurus
I Have a DIGISCAN1, plase send a driver for win 7
With Win 7, see this URL: http://www.gentec-intl.com/Default.asp?mode=prd&div_id=&prod_id=DIGISCAN1### for a link to a PDF on how manually update the driver.
The 64-bit OS driver is here: http://www.gentec-intl.com/GentecInc/Drivers/OVT_scanner_x64.zip
I hope this helps.
Aug 02, 2010 | Office Equipment & Supplies
Dual fuel thermos m#461262006 swicth back to propane
You can get the manual on the link below. Make sure you have the right regulator for the propane and not one for Natural Gas.
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0807110.pdf
Apr 28, 2010 | Thermos Stainless Steel Gas Grill
When cutting 40mm mild steel with oxy/propane is it recommended to heat the plate before hand,and would a 1/16 nozzle be sufficient?
No heating the plate before cutting is never recommended and a 1/16 nozzle is small for cutting thicker steel, My recomendation is to get the next to largest tip for your torch and use that for most of your cutting needs as for thinner material you just keep the settings turned down and for thicker you have the capabilities to increase you gasses to addiquitly cut the thicker material. Hope This Helps Don
Dec 03, 2009 | Welding Tools
Gentec Portable Small Torch Oxy/Propane Kit Logo
443 people viewed this question
Top Gentec Welding Tools Experts
Bill Boyd
Are you a Gentec Welding Tool Expert? Answer questions, earn points and help others
