Question about Honeywell Programmable Thermostat Heater
Honeywell STC 6400C problem
I have a honeywell ST 6400C system(we've just moved in). I set a programm for the hotwater to come on with no heating and the heating comes on as well. any ideas?
Buffalo12980
  • 625 Answers
SOURCE: installing a honeywell CM900 wireless programmable thermostat
the analog unit uses just two wires for heat. red - white. there is a heat anticipator setting that must match the burner current. check your programmable specs and follow instructions.
Posted on Dec 07, 2007
SOURCE: honeywell deluxe programmable thermostat 69-1402m
Solution #2 as above worked (thank you very much!) to get to the programming mode, but on mine keeping Function #13 on the default setting of "0" maintained the AIR.  Toggling the Temp button to "1" changed the system to conventional on/off at the programmed times.
Posted on Feb 07, 2008
hotuna
  • 288 Answers
SOURCE: honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Posted on Mar 14, 2008
  • 68 Answers
SOURCE: replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Posted on Dec 14, 2008
Therinnaiguy
  • 1420 Answers
SOURCE: installed my thermostat and the heat keeps
Make sure red wire is on R terminal, white wire is on W terminal. Also look for a short in the thermostat wire.
Posted on Oct 17, 2009
I am unable to connect to the Internet even though the email address and password are accurate. This just happened.
Trouble Shooting - - FAQs ' FWD - Honeywell
lyric.honeywell.com/support/troubleshooting/
How do I delete that thermostat from my Lyric app? If you've moved and ... How do I change the email address I use to manage my Lyric? If you already have a ...Missing: programmable ‎accurate
Wi-Fi 7-Day Programmable Thermostat ' Honeywell
yourhome.honeywell.com/.../thermostat/wi-fi-7-day-program...
HoneywellThe Wi-Fi 7-Day Programmable Thermostat is designed for the way you live ...Features such as Smart Response and precision temperature accuracy bring ... your home heating and cooling system, and then remove your existing thermostat. .... Whileconnecting to Wi-Fi, my model RTH6580WF or TH6320WF thermostat is ...
FAQs - Total Connect Comfort
Dec 29, 2015 | Honeywell Programmable Thermostat Heater
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Our heating and hot water keeps turning off
Sounds like a glitche in the thermostat. First, override the program & see if it does the same thing over the next few days.
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Dont no how to work central heating system
Honeywell Focus Pro 5000 non programmable is the easiest heating cooling thermostat that I've seen.
Dec 23, 2011 | Heating & Cooling
My Honeywell ST 6400C won't heat the hot water the light comes on but pump doesn't run or boiler fire. But does work on C/Heating.I can get hot water only by running the C/H and manually opening the hot...
it sounds like the motor in the motorised valve is not working on some models you can just change the head /motor , check cylinderstat (hot water stat) is working
Dec 14, 2010 | Honeywell Heating & Cooling
I need to find a copy of the instruction manual for a Honeywell ST6990, so that I can set my heating and hotwater programmes.
I looked at site on the internet that sold the programmer that I wanted, and one of them had a free downloaded manual, so I printed it off and it was perfect!
Sep 09, 2009 | Honeywell Programmable Thermostat Heater
Honeywell st7000
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Installing a honeywell CM900 wireless programmable thermostat
Dec 04, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
