Question about Kenmore Microwave Ovens
How to remove stove top
I am trying to replace my ceran glass maintop. This is a Kenmore range part # 316282939. I found instructions and it says to remove the screw that secures the green ground wire to the range. Then remove the screw next to it securing the wiring harness strap. I don't see any green ground wire? So I am stuck not able to remove this maintop. Can you help?
  • Glenn Harrower
    Glenn Harrower Apr 22, 2014
    Sorry this is not a microwave oven, but it is an electric range.
  • 767 Answers
SOURCE: Would this work or burn
This should work just fine as long as the breaker it is going to is at least 20 amps as this is the amount of amps that both fans would be drawing at once if the were both on. The 12/2 wire should be plenty to supply the 20 amps needed for the fans.
Posted on Jan 02, 2010
woodchuck789
  • 4059 Answers
SOURCE: the smooth top glass on
Yes it can be replaced. Using your model number at an on line parts store you can see diagrams and parts list and order it. Here are a few.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
http://www.appliancepartspros.com/partsearch/
http://appliancejunk.com/forums/
Posted on Aug 16, 2010
  • 1456 Answers
SOURCE: Whirlpool gas range, model #
Hello
Turns out one of the unique problems with your type of ignition system is that the spark module is susceptible to noise on the electrical line.
According to the manufacturer Service pointer, the solution to this problem is to install the ferrite bead kit to reduce line interference (electrical noise) from the direct spark ignition module.
You should also make sure there is nothing wrong with the wall outlet and the circuit breaker for the range,
Posted on Dec 18, 2010
  • 99 Answers
SOURCE: need to replace glass top
Please check out the link below. This should help you get it removed.
Hope this helped...Jim... Please leave a comment.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5151290&diagram_id=1241146#d1241146
Posted on Feb 12, 2011
  • 8404 Answers
SOURCE: i removed an outdoor light
If your old light was all plastic, as I suspect it was, there was nothing to ground. Your new light evidently is all or part metal. Fasten all the green/copper wires together and make sure the metal bar inside, if one, is also connected. Use a wire nut to make the connections. My preference is to attach a separate wire to the metal mount bar and then fasten all three ground wires together using the wire nut.
I hope this helps you ... Thank you for your interest in FixYa.com
Posted on Jul 10, 2011
Replacing the ceran glass maintop
Actually if you've removed the 2 or 3 screws at the front (underside) of the cooktop, you can lift up the front. Prop it up with a board, and then remove the 4 screws that hold the 2 brackets that hold the 4 elements to the cooktop. Now pull the cooktop forward a bit, and you should see a green ground wire attached to the back of the cooktop. If not, then don't worry about it! Just pull that cooktop up and off the range. You will need to transfer the 2 tabs in the back of the cooktop, and the silver steel bar located at the front of the top to the new cooktop. Then reverse the process to install the new cooktop and re-fasten the elements to it.
Apr 22, 2014 | Kenmore Microwave Ovens
My range top has got burns n it and I am wondering what can be done about it
what type of range top top is it??
is it Glass -- get a new razor blade
is it a baked on enamel coating,. you can try a preparation and high temperature spray paint
there may be other options, but you have to be more clear -- your post was under microwaves, not stoves -- so I am just shooting int he dark without specifics...
thanks
Best regards
Ck
Jan 05, 2011 | Microwave Ovens
A pan stuck to the glass top on the front right burner when the burner was on. When I removed the pan it took a couple of chunks of glass with it. Now there are two chuncks of glass missing from the...
Sorry to read about your problem, I hope this helps you out.
You are not going to like this, and you did not give the model number of your unit. But glass replacement tops, will range from $600.00 to $800.00 just for the glass top. and their is not a way to make repairs, because it is a special glass.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Microwave Ovens
Good morning we are staying in a house of friends who are on holiday. I would like to clean the Bosch Ceran top but I am not sure which cleaning stuff I can use. Is the use of CIF creamer allowed with a...
Harry -
I would first see if your friend has a special ceramic cleaner in his or her cleaning supplies cupboard. If you can't find a ceramic cleaner, the best thing you can do is use hot water to clean the surface. All-purpose cleaners (like Cif) can damage the ceramic glass so it's best to avoid using them.
Also, look in your friend's cleaning supplies cupboard for a metal razor scraper. Use the razor scraper to scrape off any burnt-on food or spills. Do this by holding the scraper at approximately a 30 degrees angle to the cooktop while wearing an oven mitt to protect your hands. If no scraper is available, don't resort to a knife or abrasive sponge as these could damage the ceramic glass.
When the cooking surface is cool, apply a few dabs of the ceramic cleaner (if you found it) in each burner area and work the cleaning cream over the cooktop surface with a damp paper towel. Then wipe down with water and dry with a clean paper towel.
If no ceramic glass cleaner is available, it is sufficient to wipe down with hot water and a soft sponge. Never use abrasive sponges or scouring pads on ceramic glass cooktops. Also watch out for corrosive cleaners such as over sprays, cleaners containing chlorine or ammonia and stain removers - these will just further damage the surface.
For a list of approved CERAN cleaners see here: www.schott-ceran.com
Oct 28, 2010 | Microwave Ovens
How do I clean the inside glass on the door - GE Profile JVM1870
I have a Kenmore with similar issues.
Model 665.61639100
Anyway, good luck with this. Hope someone has an answer for you (and me).
Mine has a open slot on the top front of the door. Kinda like a double plate window execpt for the opening in front. Why is this there? I don't know. Weird design. But it leaves for the possibilty of liquid to splash in there leaving it hard to clean (like impossible).
I'm thinking I have to completely remove and disect the door.
Jan 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
How do you remove a microwave above the stove
Take the glass tray out and unplug it. Remove the 2 or three phillips screws in the top of the cabinet going into the micro. They should be towards the front. Hold up on it while removing screws. When all screws are out, let it tilt forward and lift it up off of the hooks. Some require help, so be carefull and put blankets on your stove to set it on when it first comes out.
Apr 10, 2009 | Kenmore 63762 Microwave Oven
Down lights/night light not working
I'll do my best w/out model#... remove 2 screws top of the air vent grill to remove grill.. remove 1 screw at top of touch pad.. you will see maybe 2 or 3 diff fuse area...thats how you get to the fuse for your question.. but I think the relay in your control for the light is bad. unforturnately you have to replace the whole board (in most over the range micro) good luck.. mike
Jan 16, 2009 | Kenmore 62622 Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
