Victor 1240-2 calculator "E" message
"E" message. Rubber paper roller had become dislodged. Fixed that. Still "E" message. Cannot re-set. Costs prohibitive to send to Victor for repair.
marsrover
  • 682 Answers
SOURCE: printing
it needs fine adjustment to printer by service center.
Posted on Mar 18, 2008
SOURCE: loading paper into a 1205-3 Victor calculator?
I just got the same calculator without a manual. Fold over one corner of the tape so it almost goes to the other edge of the paper, making a 45 degree angle. Insert the tip of the tape into the slot at the back of the calculator and push it ahead until the corner goes under the black plastic part. I had to push it ahead a little more until it was starting to come upward on the other side. Push the arrow button at the top left corner of the keypad to advance the tape.
Posted on May 29, 2009
SOURCE: Victor 1520A Calculator
buy my victor 1560 for 7 dollars
Posted on Jun 18, 2010
  • 10865 Answers
SOURCE: I need the parts that hold the paper roll for
Hi. Go directly to the company for parts. Here is their link http://www.victortech.com/productLine.asp
Call them and tell them what you need.
Posted on Jul 19, 2010
  • 40 Answers
SOURCE: Please help me to load
Feed the paper through the slot located just under where the roll is sitting. Once you have fed it through as far as you can, press the arrow button (the up arrow) on your calculator until it catches the paper & feeds it through the machine.
Posted on Feb 10, 2011
Casio hr 8l
The rubber roller could be deteriorating from age. If Casio can supply a new roller it would be a good idea to replace it as preventive maintaenance.
Nov 30, 2013 | Office Equipment & Supplies
How to load the tape in the Victor 1297
Push the ARROW at the top left side and watch for the feed roller movement. Push the paper into it and it will feed it through.f319ovy15l9xaaaaaelftksuqmcc
Apr 11, 2012 | Victor 1297 Calculator
I believe the rubber roller that feeds the paper in my Casio HR 8L calculator has come off. How do I replace it, the paper will not feed now.
i don't know this particular calc very well, but on most calcs, the paper feeds between the rubber one and a plastic idler roller that is on a shaft below the rubber one. if you can see the rubber roller turning, check the plastic one as it can sometimes slide to one side or the other, and bind up causing paper to not feed. you can usually get at it with a small screwdriver or something like that and center it back and that will take care of problem.
hth,
razors
Mar 10, 2011 | Casio HR8TM Calculator
I need the parts that hold the paper roll for Victor 1240-2 adding maching.
Jul 19, 2010 | Victor Office Equipment & Supplies
My canon printer/copier does not feed paper in machine. makes all the sound but wont feed. help
1. Try cleaning the paper feed rollers
Instructions how to clean the paper feed rollers.
If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
    Remove all sheets of paper from the rear tray, then click 'OK'.
  4. Confirm the message, and click 'OK'.
    Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
  5. Confirm the message, and click 'OK'.
    After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
  6. Confirm the message, and click 'OK'.
    Note: “Feed roller cleaning is completed” message is displayed when the paper is fed and ejected.
    Click 'OK'.
Roller Cleaning is completed.
Sep 06, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Paper not feeding
This could be caused by rubber that has become clogged with paper fibers or has gotten hard.
If you open the machine and look for the drive mechanism you will likely recognize the part responsible for advancing the paper.
Alcohol can complicate things sometimes as it can dry out the surface that you want to have slightly tacky. I would try lighter fluid (naptha) and a lint-free cloth or paper towel to scrub the surface of the roller to remove built-up fibers and it may also remove some dead rubber that will show up as a black deposit on the cloth.
Parts for these trusty companions has become increasingly scarce since they are passing out of use with time and the advent of disposable printers. Most of those folks using these machines are reluctant to replace them but that may be your only recourse.
Oct 03, 2008 | Casio FR-2650A Calculator
Paper not feeding
The Dell 3000cn & 3010CN both display this fault.
The root cause of the problem is the Rubber pads of the feed roller in the paper tray become warn and fail to grip the paper the paper feeds a few millimetres and then is let go by the worn roller, the paper path sensors pick this up and then a paper jam is notified.
The only remedy for this problem is to obtain a new feed roller for the paper tray mechanism. Unfortunately dell in the UK do not sell maintenance kits to the public, and therefor ehte only place I found them wa on Ebay in the USA.
The kit in quetsion is the vertical paper feed maintenance kit. it costs around $50 plus shipping.
The only other option is to have a Dell approved service agent replace the rollers for you.
If you hear a grinding or cruching noise when paper is fed, then one of the mini plastic guide rollers had detached itself from its position and wound up in the tape path mechanism (very expensive repair)
Jul 12, 2008 | Dell 3000cn Color Laser Printer
Paper Roll Replacement
i work i mservice ,but for that model i don`t have a holder,but if you want i vill send you a universal holder.
beljin sasa
sbeljin@mgnet.co.yu
Feb 01, 2008 | Victor 1240 Calculator
Paper scrolling
Sometimes there is a spring in the paper tray which pushes the paper upwards so it presses against the rubber roller in the body which pulls the paper into the printer. If this spring has become dislodged or similar, it won't push the paper up with enough force for it to work. Also, somethimes in an older printer or one which has seen much use, the rubber roller can become deformed, causing a similar problem. This one is much harder to fix because spare parts are usually either not available or extortionately priced!
Apr 21, 2007 | Samsung ML 1710 Laser Printer
52 people viewed this question
jasbo
jasbo
