Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Door open all day Amana SXD22S2w
After I found out that the door was open I shut it and the refrigerator inside is not getting cold again?
  • 23 Answers
The evaporator is clogged with frost, just as if the defrost heater went out. Two options, remove all food and leave ref unplugged and doors open for half a day, or remove the back wall(evaporator cover) and defrost it with a hair dryer.
Posted on Jun 20, 2009
I have an Amana side by side refrigerator. Last night I noticed water running from underneath and the ice cream in the freezer melting. I found dog hair clogging a vent and cleaned it. This morning the...
usually when the bottomof the freezer is cold and the top isn't it's the evap fan motor isn't working and all the cold air sits at the bottom.when you open the freezer door you should hear the fan running inside the freezer,also tried to look up your model but it didn't come up.open the fridge door,look up on the right and hear the cieling and you'll see a tag with the model and serial numbers,i just need the model number and i can help you better
Jan 30, 2011 | Amana ARSE66MB Side by Side Refrigerator
The freezer area makes constant noises groaning whne door is closed, stops when door is opened
I'm going to say it's a bad bearing in the fan. It shuts off when the door is opened so as to waste as little coldness as possible.
lp
Dec 29, 2010 | Amana ABB1927DE Bottom Freezer...
Amana sxd22s2w p1190416ww refrigerator. The Evaporator fan isnt running (compressor and condensor fan running fine) How can I tell if the problem is the fan motor itself, or something else, like temp...
Remove the cover to the fan, then remove the plug from the back of the fan. Connect a voltmeter to the 2 leads. Close the door switch and turn the fresh food thermostat to the coldest setting. This will call for cold and the fan should have 120 volts. If there is power to the motor replace the fan. No power check the thermostat. For help replacing the fan try this link http://appliancehelponline.com/sxsevapfan.html
Aug 11, 2010 | Amana Refrigerators
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
REFRIG WILL NOT GET ANYTHING COLD
make sure there is no frost buildup behinde the freezer back panal and the ducts to the frig are clear. Leaving the door open will make a lot of frost and diminish the cooling capacity.
Eric
Jun 24, 2009 | Amana ARB190ZCS Bottom Freezer...
Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Mar 13, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Amana refrigerator fresh food control does not work at all
first of all, check to make sure your fan is working, also check the inside compartment for the damper should be open when your rise or lower the temperature settings on your dial. when you rise your temperature dial to 5 you should feel air flow coming out of the damper, if not check to make sure that the evaporator fan is working first, if it is than check the damper door should be open sometime this damper door gets stuck on something or they break off.
Dec 26, 2008 | Amana ABB1927DE Bottom Freezer...
French door refrig..right door pops open when left door is closed
i would check the door closure, uderthe refrig door , sort of a "cam" style washer the wants to have the door close.. part number 67003638. $5 for the part
Nov 28, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
260 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
