Question about Canon PC-735 Copier
Black streak on copies
Black on most of the paper
3 Suggested Answers
  • 4 Answers
SOURCE: Large black streak down the back of the paper
This is a fairly common problem. More common when you use junk cartridges from printcountry.com.
1) you will need some cotton swabs, isopropyl alcohol and "canned air" or any pressurized computer cleaner.
2) lift up the top console while the unit is on and wait for the cartridges to reset to the center position.
3)Release the grey lock on the LH side of the cartridges and remove cartridges.
4) take alcohol soaked swabs and clean bottom of ports and nozzles.
5) blow out with air.
6) go into program and run clean and align programs. (if you don't have them go to google and type canon mp830 support)
7) retest.
8) if this doesn't work, give to someone you hate or throw out window.
Posted on Aug 20, 2008
  • 1297 Answers
SOURCE: I have a black solid streak on my Canon D320 copies.
Change the OPC drum cleaning blade and clean used the vacuum cleaner the development station.
Posted on Dec 02, 2009
When using the auto feed, copies come out with black streaks down center of page
If you only get streaks when using the automatic document feeder, then in most cases it is dirt on the scanner glass. You do not state model but if you can also scan flat objects, trying copying a piece of paper that way. If that copy comes out fine, then you definitely have dirty glasss, if that copy has streaks you either have dirt on the scanner itself or a faulty scanner unit.
May 08, 2015 | Office Equipment & Supplies
Why do copies in color have multicolored streaks while black & white are fine?
There is a good chance that your color ink cartridge needs replacement. You can tray wetting a paper towel and putting in the microwave for 5 to 10 seconds then placing the cartridge on it for a few minutes. This sometimes will correct that type of problem...Be careful the paper towel will be hot (handle with care).
Aug 04, 2014 | HP Officejet Pro 8600
I have an hp LaserJet 3015 PCL-6 all in one printer, copier & fax. When I use the copy function, there is a black streak running down the length of the copied paper. I tried replacing the toner...
Clean the thin glass strip that sits to the left of the flat bed glass.
That is the glass used when the ADF is being utilized.
There is dirt on it causing the black streak.
Oct 11, 2011 | HP LaserJet 3015 All-In-One Printer
Wide black streak
Yes, you have a burned out scanner block element. It's cheaper to buy a new fax machine
Mar 30, 2010 | Brother BRTPPF4750E...
When copying a black streak
probably a defective toner cartridge, try another one.
Jun 03, 2009 | Office Equipment & Supplies
I have black streaks on my copy
Before you installed the cartridge was it in the box standing on end, If so remove the cartridge from the printer and gently shake the cartrige from side to side then reinstall, the toner may be packed mostly on the one side.
Feb 17, 2009 | HP Color LaserJet 2600n Printer
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
HP Officejet 6300 All-in-one machine makes black streaks
The problem is that that there a small piece of glass that the doc feeder use's to scan the orginal. You will have to clean the small glass it's about a half of a inch piece and is normally under the doc feeder unit. It will either be to the right side of the main copy board glass or it is under the doc feed unit where the paper goes down through the feeder. It is mostly some white out on the glass, just clean with a dam cloth with water or windex..... Good Luck
Nov 15, 2008 | HP 190 Copier
Black steak on copied paper
Clean the scanner glasses, check the little glass, if it have scratches. There is a white strip across between the 2 glasses, be shure to clean it up.
Oct 23, 2008 | HP LaserJet 2840 All-In-One Printer
Canon PC-735 Copier Logo
old marine
old marine
