Lanier ld 127
The fuser unit hold down assembly has broken, and now has cracked the other side, is there a replacement part without buying whole fuser unit
  • 1,087 Answers
I would get in touch with the makers. Go to
http://www.lanier.com/
Posted on Apr 22, 2014
  • 121 Answers
SOURCE: Fuser / Fixing Assembly
Move the top back like you're going to replace the cartridge.  Then unscrew the control panel (one screw and it will kind of jiggle out).  Then unplug it and set the control panel aside.
Take all the left side panels off.
Look where the control panel was, and you'll see a hole where you can reach a long screw driver in and take out 2 screws.
On the other side, there's another screw that's not so easy to take out.  You'll probably have to get a stubby phillips screw driver, and then cut the handle off THAT.  Very difficult, but that's the last of the screws.
Unplug the three plugs, and jiggle the old fuser out.  Reverse the procedures to put the new one in.
Posted on Oct 27, 2007
EPIJAB
  • 89 Answers
SOURCE: Fuser
You will only need the fuser unit. It is a little complicated but here it is. You need to remove all the covers, the several screws and a bracket. Here are some good directions.
http://www.feedroller.com/Store/Service%20Manual/LASERJET%201150,%201300%20Service%20Manual.pdf
Posted on Jan 22, 2008
  • 4 Answers
SOURCE: fuser error 50.2
1) First thing is check power source. If you have the printer plugged into a UPS (uninterruptilbe power source) unplug it and plug it directly into the wall. If it is plugged into the wall you might want to try a different outlet to see if it solves the problem.
2) Remove and reinstall the fuser. It may not have seated properly.
#) Make sure you installed the correct fuser. Should be RM1-1082. There should be a sticker on the fuser with this number. See the following article for more info. http://www.partsnow.com/service_today/0705.asp
If you still have the old fuser check also that it is a RM1-1082. If not you may have a euro version machine which would require a different fuser.
If the fusers match up you should check the voltage coming to the fuser if possible. If there is 100- 127 volts where the fuser plugs in you probably got a bad fuser or it was damaged in transit. If there is low voltage or no voltage you may have a board problem. Probably DC controller or Power Supply.
Posted on Mar 30, 2008
  • 398 Answers
SOURCE: Replaced fuser on LANIER SP C210SF, machine still
It is not recomended to enter service mode on this model if a service tech replaced the fuser they owe you to reset this fuser counter. -Carl, Ricoh tech.
Posted on Jul 01, 2009
  • 26 Answers
SOURCE: sc 544 lanier ld 122
CALL FOR SERVICE YOU WILL NEED NEW THERMISTORS NEW THERMOSTATS AND MOST LIKELY HOT ROLLER,CLEANING ROLLER AND HR BEARINGS COST OF TIME AND PARTS WILL BE 400 TO 500
Posted on May 20, 2010
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
Hi all Lanier Ld 520c Error code 400 what is it. Thanks
sc400 is an ID sensor error. You probably only need to clean the ID sensor, rather than replace it, but there's a chance it could be something more serious, like a board or the transfer belt assembly.
Getting to the ID sensor is tricky -- you may want to call a service technician. The fuser needs to be removed and the whole right side door needs to be taken off. But chances are that once that ID sensor is cleaned and the machine is turned off and back on, the sc400 error will go away.
Dec 16, 2010 | Lanier UNKNOWN
Lanier LD118d showing a error sc322, how to fix
sc322 is an error with the copier's laser unit. You can pull the laser unit out and clean it up if there is toner on or in it, but more than likely either the polygon mirror motor or the laser unit as a whole assembly should be replaced.
Jun 16, 2010 | Lanier UNKNOWN
Sc 546 lanier ld
This is a fuser error code resetable by entering service mode. -Carl
Jun 10, 2010 | Lanier 1205 Copier
Sc 544 lanier ld 122
May 17, 2010 | Office Equipment & Supplies
Lanier ld 228c says printing will begin after warm up, but it never warms up. Tech says hard drives are bad and need replaced. he put new ones in but still did not correct problem.
Check and measurement the fuser unit components(heater lamp,thermistors and thermalswitch) and check the toner quantity in the copier.If not toner the machine not start to working.
Oct 02, 2009 | Office Equipment & Supplies
Hp laser jet 2430 dtn prints lines on left side of paper
Hi Karent503:
It sounds like you fuser assembly is worn. The part on the fuser assembly that you are having a problem with is the heat roller assembly located in the fuser. You can have a technician replace that for you at you local HP repair center, Her is the part number for the fuser assembly.
Fuser, 110-127 V RM1-1401-000CN
Apr 02, 2009 | HP LaserJet 2430dtn Printer
Fax printing problem
The blue release lever that holds the ribbon cartride may be cracked or broken. The crack may be so fine, that it's not easy to see, so look carefully. Even the slightest crack will cause the ribbon cartridge to fit loosely enough so that the roller is not touching the paper. Whatever side is not printing, that's the lever that you should look at. That's what happened to mine. I was ready to buy a new machine, until I found that solution. To test it, I tried to copy something while pushing down on that side of the ribbon cartridge, and it printed fine--the whole page. I looked more closely at the lever, and found the crack.
Jun 10, 2008 | Brother IntelliFAX 1250M Fax
k24674
jasbo
jasbo
