Question about Audiovox VE727 7 in. Under Cabinet TV
How to fix a television burn la7833 when i turn my tv
When i turn my tv the ic la7833 burn
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 136 Answers
The LA7833 is a monolithic linear IC for vertical deflection
output for large color television sets,this ic will need to be replaced after finding the fault that caused it to burn in the first place.
Posted on Jun 01, 2014
Shorted la7833
Replace it with a new IC. It won't cost more. http://www.rem-tv.odessa.ua/datasheets/v_def/LA7833.pdf
Try this link to know more about this IC. Electro help
Apr 22, 2014 | Goldstar GLV-B1000 4 in. Television
TV Picture shrinks down more and more until it gets to a line.
You may have a cold solder joint around the Vertical circuit. Resolder the pins of the LA7833 IC and the components around the IC.
Check the C308 220uf/35V & C320 100uf/50V.
Nous Sabre.
www.aaatvservice.com
Jan 28, 2012 | Toshiba 32A33 32" TV
Vertical lines on screen of Toshiba rear projection Model 57H84
Check for bad capacitor in vertical circuit where vertical IC is LA7833.
100uf 35v 1uf 50v 2.2uf 25 47uf 50v
Dec 03, 2010 | Toshiba Televison & Video
Toshiba 32A41, Audio works, but video is
The vertical circuit is malfunctioning. This can be as simple as poor solder connections at the vertical IC or a defective IC. If you can solder, you can fix this yourself. Please use caution as there are potentially dangerous high voltages present inside the set even when unplugged.
Locate the vertical IC, which is a small flat IC attached to a heatsink. It should have 9-11 pins and be karmed LA7833 or something similar. Resolder the pins first. If that does not resolve the problem, replace the IC (about $15-$20). It is possible that some of the capacitors in the circuit are also defective. If that is the case, the above actions will at least change the symptoms. Update this with any change other than complete resolution of the problem, and additional instructions will be supplied.
Dan
Nov 11, 2009 | Toshiba 32A41 32" TV
Whent he tv is on, we see a thin horizonal line. the sound is good...you can hear what's going on, just a black screen with thin horizontal line. TV is only 2 years old. Toshiba TheatreView SD
HELLO
I wish I had a £1 for every time I answered this! This is field collapse where the probable cause is the Field Output IC itself, or dry solder joints on the board where the IC is soldered in.
If you are not familiar with electronics then I urge you contact a service centre in your area.
ALL THE BEST (:-)
Nov 09, 2009 | Toshiba 32A33 32" TV
I am repairing my sister TV {Toshiba TN61X81}. The original was no picture and with sound. Upon troubleshooting the vertical deflection, ihad move the screen control for all 3 crts to see the horinzontal...
The easiest way I have found to set the screen controls is to tune into an old black and white show, turn the green up until you see retrace then slowly turn it down until it just dissapears then adjust the blue and red for a true black and white picture.
Sep 08, 2009 | Toshiba TN61X81 61" Rear Projection...
Toshiba 32a32 chassis tac 245 powers up for 1 secopnd then red power light flashes.
just fixed one with that problem it was the vertical output ic Q301
that was shorted. try wicking it out. it is a LA7833S.
Postings say to be sure to use the Toshiba part
Aug 17, 2008 | Toshiba 32A32 32" TV
Toshiba 32A32 won't turn on
Feb 27, 2008 | Toshiba 32A32 32" TV
Where buy la7833s
The LA7833 is a vertical IC and available several places here in the states. If you can go online try acme enterprises in Florida for the best prices. http://www.acme-sales.net/index.shtml
At ACME they're 1.79 american and they do ship to Canada and Mexico...
Hope this helps!
Bill
Nov 13, 2007 | Toshiba TP55G60 55" Rear Projection...
No picture
In the late 70's I was OJT for America West TV, the ink still wet on my CET diploma. I can remember my instructor Bod Fagren saying, "if you're not certain you can do it don't attempt to guess, ask questions..." It sound like what youre describing is a loss of vertical deflection. This is usually caused by the vertical IC having shorted out. In the 61H60 that IC is Q301 an LA7833s Toshiba p/n#23319787 and costs about $20 bucks. But other components feeding that IC, resistors and caps should be tested to determine if the IC failed due to heat or was stressed because of higher than normal voltages. In all a shop usually carries that part on-hand or has access to it. And the repair can usually be completed in a couple of hours. In short, I'd have it done by a reputable shop. Taking the TV to them will help keep the costs down too. If you're not too sure where to find a good repair shop try calling NESDA (National Electronic Service Dealer's Assn.) and they can usually give you a couple of referrals to one of their member's shops in your area. Good Luck Bill
Jun 05, 2007 | Toshiba TP61H60 61" Rear Projection...
Audiovox VE727 7 in. Under Cabinet TV Logo
64 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
