Question about Garden
I am trying to find a manual for a yth150 ride-on mower.
  • Garden Master
  • 2,478 Answers
Try Goggle it.
Posted on Apr 22, 2014
2 Suggested Answers
  • 640 Answers
SOURCE: Husqvarna Model YTH150 riding mower.
The alternator is located under the flywheel. You can not see it with out removing the flywheel.
Posted on Aug 23, 2011
Yth150 954140108 does nothing when you try to start it
read your manual .set the brake on it and make sure the PTO is in the off position .
Aug 28, 2015 | Husqvarna Garden
ON MY HUSQVARNA TRACTOR MOWER,YTH150. WHEN I TAKE MY FOOT OFF THE BRAKE/CLUTCH IT CUTS OUT.
This sounds like the seat switch has either gone bad or is not connected properly. Remember you cannot jump over or avoid the seat switch. Check to insure the wiring is connected to the switch on the seat, if it is connected, I suggest replacing the switch.
Mar 10, 2015 | Husqvarna Garden
My husqvarna yth150 died while I was mowing. It starts fine but dies when blades are engaged or put in gear.
It sounds like a safety switch is open or closed. I would use a multimeter and test pto switch, drive switch, etc. Just as you have a safety switch under your seat that stops mower if you get off , you also have these very same switches for pto,drive,etc. Set your multimeter to check continuity when testing. Hope this helps!
Aug 10, 2013 | Garden
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
Jul 19, 2013 | Husqvarna Garden
YTH150, 15 Kohler engine will not turn over, battery fully charged, starter is ok. Any ideas?
here we go on the positive(red) lead on the battery there is an in-line fuse you can either follow it from the battery to the starter or from the starter to the battery. The other causes may be that the PTO is not fully disengaged, or the seat safety switch is not working( which you can bypass by taping them together). Hope This Helped Tim
Apr 16, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
YTH150 Mower. with the clutch pushed in it will start and run. let the clutch out or engage the blades while the clutch is in aand it shuts off
Sounds like the seat switch isn't working. It should be an open circuit. Use an ohm meter to test it for continuity.
Jul 11, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
WHERE IS THE FUSE ON LAWN TRACTORS?
on my yth150, its up under the battery tray.  its on fixed to anything, just dangling.
Jun 27, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
How do I check fluid level on YTH150 Hydrostatic Transaxle?
My Husqvarna hyrdrostatic transmission is sealed, and yours may very well be also. That means no changing the fluid.
May 13, 2009 | Husqvarna Garden
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
