Question about Fire Magic Grilling
Remove Burmer control Knobs on Front Avenue Grill
2 Suggested Answers
  • 2550 Answers
SOURCE: Cannot take off/remove knobs on KBNU26TSS grill?
look under the knob for a small screw that holds it in place undo this it should come off
Posted on May 17, 2010
I Have A Jenn-Aie Model 720-0164 Natural Gas Grill. When I Grill, The Control Knobs Get So Hot Theyh Will Burn You. What Could Csuse This?
Can this grill be also used on propane? If so you might be running it too hot on natural gas, check to see if the control knobs have two different set of markings.
Sep 16, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
When using grill knobs get to hot to turn stoves 600 sidl
you are missing the heate plate that stops the knobs from getting hot go to ebay and put your model in and look for heate plate or some thing like that
Oct 12, 2012 | Ovens
Had a fire in the control panel along the front where the knobs melted off. BBQ is a Grill Chef approx 4 yrs old. Took control panel off and cleaned it up. Would it be safe to continue to use or would...
Yes, there could be unseen damage to the gas manifold, that the control knobs attach too. To check this, you will need to remove the control panel cover. Turn the gas ON and paint soapy water on all the fittings. Do this with the control knobs in the OFF position. If you see any bubbles that get larger in size, that's where the leak is. Then turn each control knob one at a time and check for leaks again. DO NOT Smoke or have any open flame close by, when you do this.
Just for my own information, how did the control panel area catch fire? Was there an existing gas leak?
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Grilling
Weber Genesis Gas Grill won't heat up very high
yes the control knobs are what controls the heat, its a saftey thing on the bbq so turn off tank undo gas from tank open knobs release gas from line , turn off control knobs , reconnect gas line to tank ,turn on slowly , turn control knobs to on and light,
Jul 05, 2010 | Weber Genesis Silver B Grill
Flame appearing from in back of front panel
This is usually a regulator problem, or a gas leak where the regulator line attaches to the back side of the knobs. Test for a gas leak first. You can use a mixture of water and liquid dish/hand soap. Saturate the area where the hose connection is, turn on the tank, but leave the knobs in the off position and do not hit the igniter. If there is a leak, you should see some bubbling where it is. If there is no leak, turn the tank off, open the valves (turn the grill knobs on) and bleed the gas out of the lines. Once it has sat for a few minutes with the knobs in the "high" position, turn them off. Then leave them off and turn on the tank, followed by one of the knobs and ignite the grill. see if the flame went away. I've seen this happen where there is not enough pressure in the line. Turning the tank off, the knobs on, bleeding the line, then closing the knobs and opening the tank and letting the gas build up pressure in the line before turning the knobs back on or trying to light the grill should resolve it.
May 11, 2010 | Char-Broil CharBroil Master Flame Gas...
Grill does not heat over 250 degrees
Here is a couple of things to do.
Make sure your tank is filled.
Straighten Fuel hose, so it is not bent or kinked.
Does your front burner light with a match? If it does light then check the Crossover Ignition System.
Also, It could be the way the unit is turn off.
Try following thses steps, this will help to reset the excess flow safety device.
Turn all burner control knobs and the cylinder valve OFF.
Disconnect the regulator from the cylinder. Turn burner control knobs to HIGH. Wait at least 1 minute. Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve on slowly. Then go ahead an light your grill.
Fireplace-girl
Jul 22, 2009 | Weber Genesis Silver C Grill
My grill does not heat beyond 300 degrees.
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly. I HAD THIS PROBLEM JUST LAST NIGHT AND FIXED IT RIGHT THEN.
May 22, 2009 | Weber Genesis Silver A Grill
May 19, 2009 | Weber Genesis Silver B Grill
Burner Knobs stcuk/can't turn
I had the same issue.
Take the lid assembly off and remove the metal shield over the burner controls.
This will allow you to remove the black cover that you see on the front of the grill and will give you access to the burner controls behind the knobs.
there is an almost diamond shaped metal piece with a screw in the top and one in the bottom that the know shaft runs through.. take note how it is currently positioned and then remove the screws and the piece of metal will come off.. dont lose the spring or lock washer.
you will now have access to the valve which is your issue. i sprayed some liquid wrench and i used a large common head screw driver to "beak" the valve to allow it to turn. Test it so you know which position to return the valve to and then put it all back together.
Aug 28, 2008 | Coleman Roadtrip Grill LXE 9949-750
Front burner on grill won't adjust from high
Fireplace-girl
Nov 15, 2007 | Weber Genesis Silver C Grill
Grilling Logo
37 people viewed this question
Top Fire Magic Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
john h
Are you a Fire Magic Grilling Expert? Answer questions, earn points and help others
