Question about Kicker 2009 2010 Ford F150 Supercrew Custom Box 2 10 Amp Rack
LR ABS Error Code C1299 and C1175 - Kicker 2009 2010 Ford F150 Supercrew Custom Box 2 10 Amp Rack
Can you tell me what c1165 and c1175 mean on a toyota avalon
Nicole, They are chassis codes, may depend on the year but this is what I came up with.
C1165: Speed Wheel Sensor RR Input Circuit Failure
C1175: Speed Wheel Sensor LR Input Circuit Failure
Apr 09, 2016 | Toyota Cars & Trucks
My car failed inspection for codes P-1000 and C-1175
p1000 is a generic code and is always present, c1175 is a problem with the abs system.
Oct 13, 2015 | 2002 Jaguar X-Type
2006 ford expedition abs codes b1676 and c1175 what are these codes
The C1175 code is your Speed Wheel Sensor Left or Right Circuit Failure. That means you have a wheel sensor bad. These can be hard to determine which one is bad. The front has a longer wire than the back ones. Buy one of each and change one side first. One front and then one back. Most of these can be changed by taking the tire off and follow the wire to the wheel hub assembly. They rust and can be hard to get out.Spray a little Liquid wrench or some other rust lubricant on the bolt and around the sensor and use a small screw driver to lift it out of the hole. It could be as simple as a piece of metal on the end of the sensor. If you find something like metal fillings on it. clean it up good and put it back or install a new one.
You will have to clear the code from the computer before the it the light will go out. If it don't go out, move to the next wheel on the same side. I recommend doing the right side first. I hope this heips you find the problem causing the code.
Feb 11, 2015 | Ford Cars & Trucks
C1175 & p1111
the check engine loght is telling you that the cpu has found a fault in the management system. If the abs light is on as well that would be a good place to start looking for the fault
Jan 19, 2013 | 2002 Jaguar X-Type
2006 ford crown vic abs code b1596
B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart.
Anti-Lock Brake System (ABS) Module Diagnostic Trouble Code (DTC) Index DTCs DTC Caused By Description Action B1342 ABS Module ECU is Defective INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. B1484 ABS Module Brake Pedal Input Open Circuit Go To Pinpoint Test D . B1596 ABS Module Service Continuous Codes NOTE: If other DTCs are present, REPAIR them before installing a new component.
TURN the ignition switch to the OFF position and wait at least 30 seconds. Turn the ignition switch to the ON position. REPEAT the ABS self-test. If any DTCs are retrieved, REFER to the Anti-Lock Brake System (ABS) Module Diagnostic Code (DTC) Index. If no DTCs are retrieved, CARRY OUT a drive test above 15 km/h (9 mph), then REFER to the symptom chart. B1676 ABS Module Battery Voltage Out of Range Go To Pinpoint Test E . C1145 ABS Module Speed Wheel Sensor RF Input Circuit Failure Go To Pinpoint Test B . C1155 ABS Module Speed Wheel Sensor LF Input Circuit Failure Go To Pinpoint Test B . C1165 ABS Module Speed Wheel Sensor RR Input Circuit Failure Go To Pinpoint Test B . C1175 ABS Module Speed Wheel Sensor LR Input Circuit Failure Go To Pinpoint Test B . C1222 ABS Module Speed Wheel Mismatch Make sure the tires are the same size and correctly inflated. INSPECT the wheel speed sensor rings. CLEAR the DTC. TEST drive the vehicle. REPEAT the self-test. C1266 ABS Module ABS Valve Power Relay Circuit Failure Go To Pinpoint Test K . C1296 ABS Module Wheel Speed LF Signal Fault Go To Pinpoint Test C . C1297 ABS Module Wheel Speed RF Signal Fault Go To Pinpoint Test C . C1298 ABS Module Wheel Speed RR Signal Fault Go To Pinpoint Test C . C1299 ABS Module Wheel Speed LR Signal Fault Go To Pinpoint Test C . C1300 ABS Module ABS Hydraulic Pump Motor Circuit Failure Go To Pinpoint Test A . C1805 ABS Module Mismatched PCM and ABS Modules Do Not Match CHECK the part numbers. INSTALL the correct module. C2775 ABS Module TC ON/OFF Switch Stuck Failure Go To Pinpoint Test H . U0073 CAN Bus Control Module Communication Bus Off REFER to Section 418-00 . U1900 CAN Bus CAN communication Bus Fault - Receive error REFER to Section 418-00 . U2023 CAN Bus Fault received from External Node REFER to Section 418-00 .
Jan 14, 2013 | 2006 Ford Crown Victoria
Dtc c1073
depends on the car im guessing that the chrysler one is the one ur looking forChrysler:ABS Pump Motor Control CircuitDodge:ABS Pump Motor Control CircuitJeep:ABS Pump Motor Control CircuitFord:LR ABS Valve coil short to ground.Mercury:LR ABS Valve coil short to ground.Lincoln:LR ABS Valve coil short to ground.Mazda:LR ABS Valve coil short to ground
Nov 18, 2012 | Mitsubishi Cars & Trucks
Abs fault light, engine management light, parkbrake fault (won't go off) DSC fault light, air suspension fault, 2003 Jaguar 3.5 SC V8, ah also discovered water ingress in boot, quite a lot!!, only fault...
try disconnecting the battery both leads and join them together for 5 mins and see what happens cannot find this fault code in teh jaguar OBD codes so consult with teh code reader manufacturers
Feb 08, 2011 | 2003 Jaguar XJ-Series
I have p1000 and c1175 codes
P0128 is a Coolant Thermostat Malfunction
P1000 shows that the fault code has been reset recently (but this code will not bring the warning light on)
C1175 I think is Speed Wheel Sensor LR Input Circuit Failure or Input circuit failure and could be directly related to your ABS fault light indication.
Jan 27, 2010 | 2003 Jaguar X-Type
What does C1175,C1236 and U1900 mean?
For
C1175 - Speed Wheel Sensor LR Input Circuit Failure C1236 - Speed Wheel LR Input Signal Missing U1900 - Communication bus fault
If the cluster is working fine, ignore U1900.
There are so many recalls and so many technical bulletin for the problems on Ford 350.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 04, 2009 | 2006 Ford F 350 Super Duty
Have error codes C1175 & P1000 for a 2002 Jaguar X-type 2.5.
C1175 ABS/TCCM Anti-lock braking / traction control LH rear wheel speed sensor circuit fault ABS/TCCM to wheel speed sensor signal circuit (FH33-21): open circuit, short circuit to ground, short circuit to B+ voltage, high resistance LH rear wheel speed sensor failure
P1000 is for check not complete after last memory clear , dont worry about it , just stick with C1175 , and most probably it is the sensor wire
Jul 25, 2009 | 2002 Jaguar S-Type
Kicker 2009 2010 Ford F150 Supercrew Custom Box 2 10 Amp Rack Logo
156 people viewed this question
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
