It says frequency response as 40 Hz to 170 Hz (Subwoofer) and 200 Hz to 20 KHz (Satellite speaker). How it will manage frequency from 170 Hz to 200 Hz. Will this be affected
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
It's certainly not a matter of hookup. I will assume that your speaker outputs from the receiver, hook the sub directly, and the satellite speakers hook to the sub ad ? If so, this type of connection is seriously out of date. No matter. I would need to know the exact hookup of your speaker system.
Posted on Dec 14, 2014
    Top Expert:
  • Audio Player... Master
  • 74,383 Answers
The sub-woofer will handle a frequency of 40Hz to 170Hz of the sound spectrum, and the satellite will handle 200Hz to 20KHz. There is frequency hollow that is, 170Hz to 200Hz; and it is not quite audible and noticeable to human ear. Gopakumar Gopalan Google
Posted on Apr 22, 2014
Testimonial: "The full question is "Can I buy Intex IT 2000. It says frequency response as 40 Hz to 170 Hz (Subwoofer) and 200 Hz to 20 KHz (Satellite speaker). How it will manage frequency from 170 Hz to 200 Hz. Will this be affected" Can I go for this system?"
2 Suggested Answers
  • 38 Answers
SOURCE: Home theater
Brave and hands on!I like that from a user,but you should pay a professional to connect it for you for your first time.Since you have paying him to do this,you should learn from him so next time you know what is the right way and avoid problems.
Joe
Posted on Feb 04, 2008
Aiwa tw60 subwoofer have power but no woof sound
Aiwa isn´t a good subwoofer. The best are Rel, Sonus Faber, etc.
Here is the characteristics:
.1 20 watts, Min. RMS at 4 ohms, from 40 Hz to 160 Hz, with no more than 1% Total Harmonic Distortion
The subfrequencies are below 25 Hz, but TS-W60 work over 40 Hz!.
Bass frequencies (woof) are from 25 to 50 Hz.
Bad, very bad.
Sell it and buy a good subwoofer.
JMG
Jul 18, 2011 | Aiwa TS-W60 Subwoofer
Is it totaly ok to just connect one pair of JBL Control 1 speakers to this receiver? Here are some of the specs. Frequency Response: 120 Hz to 20 kHz Power Capacity: 150 W Sensitivity 87 dB SPL Nominal...
The only relevant speaker spec is the impedance. As you probably realize the Pioneer SX-255R recommends 8 - 16 ohm speakers.
Four ohms is on the hairy edge of too low. You could certainly try it but if any strain or excessive volume is used you could see something go poof!
The low end of 120Hz says don't push the bass to them.
Jul 14, 2011 | Pioneer SX-255R Receiver
I need specifications about the power supply for for the Maxell FPS-1 2 speakers ...
Input Voltage: 110 V AC
Power Source: Power Supply
Frequency Response: 70 Hz to 18 kHz
Mar 04, 2011 | Maxell Flat Speakers With Subwoofer and...
Can i hook this amp to a 2 channle out put stereo?
Sure. Specs are listed below. I think it's designed for regular 2-channel input, isn't it?
Front Channels: 100 W RMS x 2 @ 1.5 ohm-4 ohm (11V-14.5V)
  • Rear Channels: 25 W RMS x 2 @ 1.5 ohm-4 ohm(11V-14.5V)
  • Subwoofer Channel: 250 W RMS @ 1.5 ohm-4 ohm (11V-14.5V)
  • THD at Rated Power: <0.03% @ 4 ohm (F&R), <0.05% @ 4 ohm (Sub)
  • S/N Ratio (F&R): >108.5 dB below rated power S/N Ratio (Sub): >95 dB below rated power
  • Frequency Response (front and rear): 5 Hz-30 KHz (+0, -1dB)
  • Frequency Response (sub channel): 5 Hz-500 Hz (+0, -1dB)
  • Damping Factor (front and rear): >200 @ 4 ohm/50 Hz
  • Damping Factor (sub channel): >500 @ 4 ohm/50 Hz
  • Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS
  • Differential-Balanced Input Topology: (3 pairs of inputs)
  • Front Crossover: fully-variable (50 Hz-5 KHz), selectable- slope BP or HP (12 or 24 dB per octave)
  • Rear Crossover: fully-variable (50 Hz-5 KHz), selectable- slope HP (12 or 24 dB per octave)
  • Sub Crossover: fully-variable (40-200 Hz), selectable-slope LP (12 or 24 dB per octave)
  • Preamp Output: 2-channel (full-range or LP)
  • Bass EQ: Variable boost up to 15db
  • Infrasonic Filter: defeatable 24dB/octave at 30 Hz
  • Left minus Right Ambience Circuit: ambient effect for rear channels
  • Front and rear speaker output connections: accept up to 8ga. wire
  • Dual mono subwoofer output connections: accept up to 8ga. wire
  • +12V and Ground connections: accept up to 4ga. Wire
  • Dimensions: 19.7"L x 9.25"W x 2.36"H
  • Dec 02, 2010 | Jl Audio 500/5 Car Audio Amplifier
    What is the voltage polarity ac or dc of the power adapter for SP-613 speakers?
    this is actually the product description for your speaker
    Product Description
    Front
    Speaker Unit: 1inch +6.5inch *2+8inch
    Power: 10-100W
    Sensitivity: 88 dB
    Impedance: 4 ohm
    Frequency Response: 45-20K Hz
    Production Size: (H*W*D) 1087*210*336mm
    Package Size: (H*W*D) 1162*500*400mm
    CENTRE
    Speaker Unit: 1inch +4inch *2
    Power: 10-60W
    Sensitivity: 86 dB
    Impedance: 8 ohm
    Frequency Response: 75-20K Hz
    Production Size: (H*W*D) 160*500*179mm
    SURROUND
    Power: 10-60W
    Sensitivity: 85dB
    Impedance: 8 ohm
    Production Size: (H*W*D) 225*160*158mm
    Package Size: (H*W*D) 550*273*415mm /3PCS
    ACTIVE SUBWOOFER
    Speaker Unit: 10inch
    Impedance: 8 ohm
    Crossover Point Control
    Handling Power: 120W
    Production Size: (H*W*D) 405*328*350mm
    Package Size: (H*W*D) 465*330*465mm
    Jun 24, 2010 | Juster SP-615 Computer Speakers
    I am trying to find the output power, watts?
    bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
    Jun 08, 2010 | Audio Players & Recorders
    What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
    TS-W307D2
    Design and Specifications
    12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
    Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
    Equalizer setting help
    try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
    Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
    Low pass crossover
    Low-pass crossover
    Both sets of inputs sum the left and right channels together and the
    resulting signal is passed through an adjustable low-pass crossover before
    being amplified. The crossover control allows you to adjust the upper limit
    of the subwoofer's frequency response from 40 to 120 Hz. The subwoofer's
    response will begin rolling off above the frequency you set this control to.
    You should set the crossover frequency to obtain a smooth and seamless
    transition from the subwoofer to the main speakers in your system. If your
    main speakers are smaller units with limited low frequency output, you
    may wish to choose a higher frequency (such as 100-120Hz) than you
    would with larger speakers which have greater low frequency output. With
    larger speakers, you might start with this control set lower, such as 80Hz.
    Jan 05, 2009 | Velodyne CHT-10 Subwoofer
    61 people viewed this question
     Grubhead
    Grubhead
