Question about Proscan 26LB30H 26 in. LCD TV
Proscan lcd tv model 26lb30h blows fuse on power board
Took apart and replaced blown fuse and it blows it again
  • Anonymous Mar 30, 2014
    Replaced blown fuse twice. do not see any obvious cause.
  • 2,336 Answers
If the fuse blows again after replacing it, there's a shorted diode, bridge rectifier, capacitor or transistor in the power supply.
I repair these power supplies. If you need furhter assistance, write to jah2mil@hotmail.com
Posted on Jun 20, 2009
Sylvania LC320SLX 32 in. LCD TV wont turn on
There is short circuited component/s at its main power supply regulator board. Check and replace them. It is best to replace the circuit board as card bassis, rather than trying to repair it.
Jun 13, 2013 | Sylvania LC320SLX 32 in. LCD TV
TV will not turn on, 3.15amp fuse keeps blowing on power board
I have an ln40b630n1fxa and my fuses keep going out as well i took it all apart and seen nothing blown. What would be my next step
Nov 06, 2012 | Samsung LN40B630 40 in. LCD TV
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
I have a 26lb30h proscan 26
Hello
There are two possibilites for this fault. The first one is shorted inverter transformer in the backlight inverter board. The second one is the fault with main board. For both faults, card base replacement is only possible. Check out which board has the short, and replace it.Image of the digital board is given here. Baclight inverter board can be located aty the panel itself, will be fitted vertically at the right or left side of it.2_8_2012_5_34_32_pm.jpg
Feb 08, 2012 | Proscan 26LB30H 26 in. LCD TV
26la30q wont turn on
Hi
You have to start checkin from its main ON/OFF switch itself. If the switch have any contact contact trouble, the set will not turn On, even though you hear the click sound from the switch. If switch is Ok, then you have to come to the power supply regulator board. It can be easly recogonized the powe supply regulator boad. The main supply line will go straight to it. There will be more that 5 or mor secondary voltages from it, according to Tv model. These secondary wupplies will energzed only after the power supply switching circuit work properly.
Ther is a fuse [ a cartridge type; replaceable]. Check the fuse first. If it has blown; be carefull when you replace it; because there must be some reason for the blowing of that fuse. It is really a protection device. Before replacing it, you have to check the entire power supply board for some short circuit. If you have sound knoledge in repairing Switched Mode Power Supply [SMPS]; just proceed. Otherwise get it repaired by any experienced service technican or by authorised service center for Proscan. OK.
Jul 08, 2011 | Proscan 26LA30Q 26 in. LCD Television
Bought a 26 inch proscan from Costco on line. Tv won't turn on, led light is off as well. own TV approx 2 years wah can i do besides leave TV curbside?
Hi sglassgold,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated. I would advice also to replace the entire power supply for your convenience if finding technician there is not possible.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 14, 2011 | Proscan 26LB30H 26 in. LCD TV
House took lighting strike and my LCD TV will not power up. Have TV apart and the fuse is good. Heat sinks are warming up and do not see any burnt spots or blown capacitors.
All the ICS on the boards are dead.Replaced the power supply board,it dead.Be prepare to replaced the Tuner board too.50% it dead also.Tries websites like Shopjimmy.com,Ebay.com to buy refurbishes boards like the power supply board and the Tuner board.
Sep 30, 2010 | Philips Televison & Video
Red, Green, and blue
sell it on ebay as broke they go for 100 just a idea look like u tryed alot
Feb 05, 2008 | Sony KP-46WT500 46" Rear Projection...
Insignia LCD TV 26"
A blown fuse is a symptom not the cause... You might take a look at the caps E919,E920,E921 (all 680uf/35v). The board can be accessed by removal of center cover w/o removal of the entire back.
Bill
Nov 15, 2007 | Insignia IS-LCDTV32 32 in. Television
Proscan 26LB30H 26 in. LCD TV Logo
415 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
