Question about Dryers
Duracraft fan Model dv518
Doesn't work when turned on; and doesn't make any noise. It's a three-speed fan.
  • 24 Answers
SOURCE: dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
Posted on May 19, 2009
SOURCE: Replacement Blade Knob for Duracraft Table Fan Model No.DFT-218W
I thought the same thing. It was hiding in one of the stryfoam pieces.
Posted on Jul 25, 2009
heatman101
  • 43501 Answers
SOURCE: My Duracraft Model DV-519 Commercial
Check to see if the fan has a capacitor on the motor...
Often when you get a hum and no spin it is because of a bad cap.
Also check that the fan spins freely, it may need some oil...
If it does need oil, first work in some WD-40 and then some light small motor oil at each end of the motor...
heatman101
Posted on Aug 19, 2010
caroldon
  • 17130 Answers
SOURCE: My fan works but the
If this is new piece and has not worked you need to recheck teh wiring before the unit is suspected.
Check the seperate line for the light circuit. If the connections are correct then the light unit can be faulty . If this is new get a replacement.
Posted on Jul 17, 2011
Testimonial: "It was new unit and the lighting unit was faulty. Triple checked the wiring diagram. Thanks."
  • 148 Answers
SOURCE: tower fan doesn't turn on
see if the timer is set to the desired setting
Posted on Jul 20, 2011
Hi, I have a Duracraft commercial model fan high velocity I need motor DM514
did you check already the thermal fuse and capacitor??
Oct 02, 2015 | Duracraft Dryers
I own a Duracraft commercial grade high velocity fan, model DV-518. When I turned it on, the blades started to turn. Then there was a loud click and a small smell. I quickly turned the switch off. When...
Hi, I had the same pop noise and turned off immediately. So my question is, where is the capacitor, in the switch assembly or inside the motor?
Aug 30, 2013 | Duracraft Dryers
DS 1910
Hey Anon,
You will probably spend more on trying to fix this than just BUYING A NEW ONE!!!! https://www.walmart.com/browse/home-improvement/pedestal-fans/1072864_133032_1230511_1230520
Jun 19, 2017 | Duracraft Dryers
Interior fan want work
First, check the fuse block for an open / blown fuse. You didn't provide the make & model of your car, so you'll have to find out which fuse is used for the fan. Replace any open / blown fuse found with the correct size as determined by the manual. If it still doesn't work, keep reading:
Many cars and trucks use what is called a "resistor pack" that is used to determine various preset speeds for the heater & A/C blower or fan. When you switch the fan from one speed or another, power is passed through a different value of the resistor - which changes the voltage to the fan motor. The different voltages provides different speeds.
The resistor pack is usually the problem if the fan works at one or more - but not all speeds. It can be the problem if the fan doesn't work at all either. The location of the resistor pack varies with vehicle make and model, but is often very close to the motor itself and accessible from the passenger compartment. Consulting with a employee at an auto parts store or Chilton's (or similar) auto repair manual should get you to the right spot. Resistor packs are relatively inexpensive at about $25 or less.
I hope this helps & good luck!
Mar 25, 2012 | Cars & Trucks
Turned on interior fan speed and heard a loud noise, then nothing. Air speed now doesn't work.
More than likely the squirrel cage fan attached to the blower motor has broken or come apart causing it to bind up in the housing making the vehicle blow a fuse. Check the fuse block for the blown fuse then try the switch for the fan speed again if no noise, you may want to inspect the fan for damage.
Nov 03, 2011 | 1995 Honda Civic
My Hunter ceiling fan make a clicking noise whenever I have it on a high speed. If I put it to medium it doesn't make that sound. I actually have the same problem with my other fan. One is in the...
You need to balance the fan blades. There should have been some small metal pieces that came with the fan. I you can not find the pieces, your local Lowe's or Home Depot carries them in the lighting area.
Jun 22, 2011 | Heating & Cooling
1993 CORVETTE AC PROBLEM
Are you fully charged though? If you don't have a full charge the clutch will not kick in.
Aug 18, 2009 | 1993 Chevrolet Corvette
Light works, fan does not
Is it a multi speed fan and it doesn`t work on any speed?? Does the fan spin easily?? If not, the bearings have failed. If you can spin it easily, you`ll probably find that the ground wire in the coil has burned away in the connector or within the field coil windings themnselves. If it was just one of the coils, you would be missing one speed only but if it doesn`t work at all, it sounds like the grounding coil that`s failed. Ian
Aug 05, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Dryers Logo
67 people viewed this question
Top Dryers Experts
